Question about Microwave Ovens
GE spacemaker II microwave gets power but won't heat. Is it the microtron tube that needs replacing or something else?
  • 1 more comment
  • 9lives9lives Oct 21, 2008
    all of the controls suddenly say 'locked' when i press them. it is a ge spacemaker and has been working perfectly. i can't even turn off the exterior light.
  • celebrity Nov 08, 2008
    microwave just says locked, how do you unlock it.
  • William Miller
    William Miller May 11, 2010
    Are the inside light and turntable coming on when you try to cook?
    Any unusual noises or odors?
    Please reply back with your brand and model number so we can help you.
Hold down the "Clear" key until it becomes unlocked.
Posted on Jan 01, 2009
Controls locked and can't get them unlocked
Posted on Aug 04, 2008
F3 message on Pad of GE Micowave Spacemaker II #jem32gy001
Kill its power and reset by the circuit breaker
usually f3 is do to something in microwave that shouldnt have been in there
Jul 13, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave JVM 1542WF 002 : everything works except the turntable and it won't heat. Have tried the TT on/off nothing happens. Have tried the power setting...nothing happens.
Usually, power for the turntable motor and the magnetron tube (the microwave source) are controlled by a couple of things. One is a relay on the control circuit board, and the other is a switch that's operated by one of the door latches. It's possible the control board has gone bad or bad connections have developed. It's also possible the door switch has failed or is out of adjustment and the oven thinks the door isn't closed.
Diagnosing this kind of trouble may require working on the oven while it's operating. MICROWAVE OVENS USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU. You might want to leave the repair to a professional because of safety concerns. Unless the circuit board requires replacement, it's probably worth having this repaired. Unlike some repairs, this one won't cost as much as a new oven.
Jun 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Problem with the GE Spacemaker (JVM1640SJ) Microwave Oven GE Spacemaker XL1800 won't heat food anymore....It worked this morning, now won't heat. What should I do?
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
Jun 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Why would my microwave no longer heat or cook?
micro waves use a tube inside that generates micro waves and like a light bulb they eventually blow out. the tube is not considered replaceable and cheaper to just get new unit.
Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker brand new, just installed will not heat anything
Have you tested the electricl outlet to b e sure it is working? If so: Return it! The unit is defective and the megatron tube either got broken, wasn't installed, or something.
Nov 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven stays on continuously and won't heat food.
Spacemakers have had problems with there magnatron, part is around 170.00. Depending on the year it is covered under a warranty however the labor is not. I have replaced 3 spacesavers for people already due to this issue. Unit runs but will not heat.
Jan 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker II - Burning smell and no heating
You may have a failure of the H.V. rectifier. I would recommend that a trained technician replace this part due to the high voltage potential.
Jun 02, 2008 | Microwave Ovens
Microwave Ovens Logo
1,090 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
