Question about Dryers
When the dryer starts turning there becomes a screeching sound while drying clothers.
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Dec 29, 2010
Obnoxious screeching sound when the drum turns. Short consistent screech on revolution, which turns into one long non-stop screech. Stops after 45 seconds or so, then starts all over again with longer...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Maytag MDE9316AZW Clother Dryer won't start
Make sure that nothing has gotten caught up in the blower wheel which is located in the exhaust housing at the front section of the dryer. You can try turning by had and listen for noise, but sounds like something may be in the exhaust housing. If not it will be motor.
Feb 01, 2010 | Maytag MDE9316 Dryer
We have to hold the start button down when for
if you have to hold down the start button to keep it running then the motor is shot-mike
Jan 29, 2010 | Kenmore 63952 Electric Dryer
Screeching noise until dryer heats up. After the dryer has run for about 5 minutes, the screeching stops.
Sounds like you have a dryer drum belt that's getting bad. Once the belt gets warm enough, it becomes more soft and pliable, lessening the noise. Needs to be replaced. Hope this helped!
Nov 08, 2009 | Dryers
Loud noise when running
Roper RGV4634KQ1 gas Dryer Starts to dry, turns 2-3 seconds, stops turning and makes loud screeching sound. Turn off to stop noise. Retry same situation.
Apr 16, 2009 | Roper RGX4634KQ Gas Dryer
Dryer makes screeching noise runs for awhile then shuts off.
The 1,5 year new dryer makes a terrible screaching noise when it has a load of clothes in it. It still dries fine, no problem with the heating element. No noise without clothes, only when it has a load.
Nov 23, 2008 | Dryers
Dryer not working
Sounds like two problems.
First, the screeching noises are probably from your belt tensioner wearing out and needing replacement. Or the belt is not properly seated on the tensioner and needs readjustment. No biggie there.
BUT...
If you have to keep the start button pressed for the dryer to keep spinning, you may have bad centrifugal switch. That switch is built into your dryer motor. Therefore, the motor will have to be replaced... BIGGIE!
Nov 18, 2008 | Whirlpool LER4634J Electric Dryer
Dryer will not stay running through entire cycle or it will just stop before clothers are dry and sometimes get a E1 error message. Mostly it will just stop and clothes are not dry, times that is runs...
Most customer manuels have a code listing in the back? Have you checked to see what E1 is? It sounds like its not sensing properly. the sensor works off the vent...so the most common problem is the vent or venting. Please check and advise
Jan 02, 2008 | Kenmore Elite HE4 Electric Dryer
ED55 dryer making screeching noises
sounds like the rear tub bearing has worn out that would explain the noise and if it got too bad the bearing can break causing the drum to stick and not be able to turn
Nov 26, 2007 | Fisher and Paykel DG05 Gas Dryer
Dryers Logo
Top Dryers Experts
