Question about GE WPRB9220C Top Load Washer
I have a GE Select washer mod. # S2000DOWW.... It is overflowing the tub when I select SUPER for Load size, but doesn't doesnt do this when SMALL or LARGE load size is selected. I figure theres a float or switch or something that shuts the water off when it reaches a certain point??? What do I do to fix this problem? Thanks Brent
  • 3 Answers
SOURCE: water doesn't stop filling tub
water not stopping filling is the pressure switch its a long thin tube that goes from the bottom of drum to the front top about the thickness of a pencil this needs taking off clearing through and checking for pin holes then refitting this should solve water problem
Posted on Jun 19, 2008
SOURCE: GE WJRR4170 washer comes out of overflow tube on super load
I have a 2005 model GE washer that would overfill only on SUPER size load. After looking around on the web, then inside the machine, I checked the tube from the tub to the switch, no problem there. Then I found an adjustment screw on the load size selector / pressure switch (all one piece). I moved it one turn clockwise, then ran a test cycle. I got lucky on the first try... no more overflow, the water comes up just above the top holes in the tub. I hope this will help others.
Posted on Jul 12, 2009
  • 82 Answers
SOURCE: washer agitates so vigorously water sloshes out of
sounds like to much water check diaphram switch this controls the amont of water taken in this is not normal operation also check that the drum dampers are working ok or have not come adrift, when empty if you was to push the drum back and forth you should feel quite a bit of resistance if it moves easly then i would check the dampers
Posted on Jan 16, 2010
kel1guy2002
  • 3740 Answers
SOURCE: washer tub wont stop filling and overflows,i
Actually it is kind of a float but the proper name for what your looking for is the water level pressure switch. Without a make and model number I can not show you where it is but on the majority of all models top and front loading it is in the top area of the unit. Most pressure switches that are the manaul select type are inside the control panel and have a small 1/8 inch line connected to the diaphram side.
Reasons for over filling are
1. the pressue swicth is bad (stuck) or defective contacts
2. the 1'8 inch line has become disconnected or has a hole in it due to chaffing somewhere inside the unit.
This should give you an idea of where to look and what to do but for a more detailed description of the location I need a make and model number.
Posted on Jan 20, 2010
  • 2468 Answers
SOURCE: My kenmore washing machine mod.
the pressure switch underneath the control panel is bad it is a pressure switch and will have a plastic hose connected to it along with some wires
Posted on May 22, 2011
I HAVE A GE WASHER THAT FILLS WITH WATER AND OVERFLOWS. DOESN'T MATTER WHAT SIZE LOAD, IT CONTINUES TO FILL WITH WATER AND OVERFLOWS. IT STOPS WHEN I HIT THE STOP/PAUSE BUTTON.
There is a pressure sensor that needs to be looked into. USUALLY, there is a chamber, on the outside of the washer tub, and out of the top of it is a small plastic hose. This hose runs up to an electrical switch.
Too much soap, over time, can plug up this system, so the machine has no idea how much water is going in...and keeps filling..... Sometimes the hose comes loose, but this makes a fairly immediate water leak, so I suspect something is plugged.
Doc
Jul 06, 2011 | General Electric WHDRE526EWW Top Load...
GE wbsr1060T washer overflows on 'Super' load size setting
HI, there is a pressure switch for the water level regulation that seems to be malfunctioning in your unit at this time. You will need to replace this switch asap. this will correct this issue.
Click here to order
Jul 26, 2009 | GE WVSR1060A Top Load Washer
Washer tub overflows and wont stop
The water level in a washing machine is determined by the pressure switch. The switch is located behind the load selector, water level, load size (has various names depending on model and manufacturer) knob on the operator console. If the switch malfunctions, the water will not shut off and the washer will overflow.
Now...before assuming the switch is defective, a common problem that occurs is the small air hose on the pressure switch coming loose or leaking. This air hose attaches from the wash tub to the pressure switch. The pressure swtich senses the change in air pressure as the tub fills and shuts the water off at the selected level. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
To access your pressure switch, unplug the washer and open the operator console. Look for a clear plastic hose. If it is NOT attached, you may have found your problem. Reconnect and test operate.
If it IS attached, check the entire length of the hose all the way to the wash tub for any cracks of leaks. In addition, remove the electrical connection(s) and check for corrosion. Clean if necessary.
If all these preliminary steps don't solve your problem, replace your pressure switch. Read through the link I provided and let me know if you have any questions. I hope you find this information helpful.
Jun 10, 2009 | GE WBSR3140DW Top Load Washer
Washing machine overflows no matter what load size
there is a sensor that tell the valve when to turn on and how much water should go thru the machine, it is a selinoid valve in the water line with a wire commming out of it,, you will either need to replace this your self or have a tech come out and tend to it
Jun 07, 2009 | GE WBSR3140DW Top Load Washer
GE WJRR4170 washer comes out of overflow tube on super load. It does not on Large load size. I have the front off and can see a large difference in water level from large to super size. Is this adjustable?
Mar 15, 2009 | GE WVSR1060A Top Load Washer
Whirlpool ultimate II water level problem
does it still fill when you unplug? if it does then the fill valve is no good.if it turns off the check your hose going to pressure switch.will be a small clear hose going from tub to your pressure switch.
Nov 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Ge washer leaks when you let it fill to top
feel in the back of your outter tub towards the top and chances are you will find a hole ge's love doing this if it is not under warranty you can repair with some JB weld with out replacing the tub
Oct 09, 2008 | GE WBSE2090A Top Load Washer
Open Questions:
See all GE WPRB9220C Top Load Washer Questions
GE WPRB9220C Top Load Washer Logo
61 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
