Question about Dryers
Ge dsxh43 guru,i appreciate your help.when i open the door clothes are stuck at the top of the dryer.some torn or have burn marks.i moved the barrel around empty.i could see how a piece of clothing could get caught.can you take the top off to get to these glides or seals?how many does it take.?raymond
  • hounddogcrj Jul 08, 2008
    dave,i took the top off.i see one glide on the left side.is there supposed to be one on the right?is the glide supposed to be inside the barrel?i ordered the glide kit.i hope thats the answer.thank you,raymond
  • hounddogcrj Jul 09, 2008
    ok,i saw one plastic glide,the upper left of the barrel.more like 10 am.theres none on the right side.when i get the part i'll pull the front off.i ordered the glide kit.thank you dave.raymond
  • 525 Answers
This link goes directly to the exploded view/tear down page for G.E. dryers at Repairclinic.com. From there you can navigate back to the parts breakdown/order page. Just enter your model no. in the search box and click search Most G.E. dryers have 3 or 4 screws holding the top panel to the front panel. Open the door andd they should be accessible at the top of the door opening. After removing those, then should be 2 screws at the bottom to loosen, then the front lifts off the 2 screws. The diagram should help guide you through the rest.
http://www.repairclinic.com/0100_20.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 08, 2008
  • David Emmel
    David Emmel Jul 09, 2008
    There are glides at the 7 o'clock and 4 o'clock levels that the drum sits on. If one fails it will make the drum rotate elliptical and allow clothes to become snagged.
    Replacing those should fix ya!
    Daave E. (Illeagle)
My dryer gets hot but doest dry my clothes i lifted the top and spun the barrell around and noticed that the seal is torn could that be the cause
Sounds like a belt problem with no clothes in the dryer turn the dryer on for a minute or so open the door if the drum is spinning it not belt if drum is not spinning it's more that likely the belt that turns the drum.also need to check the exhaust hose in back of dryer it could have a blockage check lint screen also.Hope this helps.
Oct 20, 2016 | Dryers
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
My clothes have brown marks on them that look like burn marks. has this been a problem with maytag neptune dryers? if so, what is going on?
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Grease type substance inside
Hello. I know exactly what is wrong with your dryer.
Rollers
Rear seal
Front glides
Front seal
Jun 07, 2009 | Dryers
Clothes get stuck between dryer and barrel
If your clothes get stuck, marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
May 31, 2009 | Electrolux Kenmore 5.8 cu. ft. Super...
Drum spins off center and clothes get stuck between drum and casing
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
My ge dsxh43 dryer is chewing up clothes and leaving brown burns on the end.what can i do?
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Here are some things to look for:
Rollers
Rear seal
Front glides
Front seal
Thank you,
Dave E. (Illeagle)
Jul 07, 2008 | Dryers
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Torn clothes
Rollers
Rear seal
Front glides
Front seal
Thank you,
Dave E. (Illeagle)
Mar 30, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
396 people viewed this question
Top Dryers Experts
