Question about Scotsman C1030MA32A
My Ice Machine is not making any ice, it will give me different codes, it will show b sometimes or it shows a 3..
  • 425 Answers
Try adjusting the thermostat settings or the condenser is dirty. try cleaning it but off course, unplug the unit first.
Posted on Dec 29, 2010
Which error e1 of hoshizaki ice maker fm-170ake
E1, means low ice production
Ice machine cycle takes to long to call for a harvest. When this happens it should shut the whole unit down and then show the error code. Reset power supply, Turn off then Turn on the machine. Check for these problems. Gas leaking by the hot gas valve when in freeze mode, this valve should only let hot gas by when it is in a harvest mode. Check water control valve to make sure it is not letting water in during freeze cycle. Check water float switch to make sure it is not stuck calling for water during freeze cycle. Also make sure the machine is not in a hot location, the hotter the ambient surrounding air entering the condenser coil the longer it takes to make ice.
Mar 20, 2015 | Kitchen Appliances - Others
Have a scottsmanc1448 ice machine shows codes 1 an an 2 longharvest cleaned all water sensors descaled machine works threw all cycles water flows over both curtain coils ...
ok, what you have not told me was the temp of the ice plate. If you have an inferred thermometer now is a good time to use it. what is the Temp of the plates or ice collection try. Ice will never collect if it is not below zero C. 32F my guess is it must be below 28F. you need some kind to thermometer.
Dec 09, 2014 | Kitchen Appliances - Others
We have ice maker which shows off /on mode
Make sure it's not in clean mode... needs to be in ice mode
Aug 24, 2014 | Manitowoc ID1202A-261 Dice Cube Air Cooled...
F1471 vi Miele freezer showing fault code 01 21 _F
From a previous post for a different Miele freezer: "I emailed Miele and this is what they reply: Thank you for your interest in Miele products. That message is a ice fault. If the ice has stopped production, please turn the toggle switch off under the electronic touch panel. To find this please reference the owners manual on pages 7 and 9. I have included the owners manual in case yours is missing. If your machine still produces ice fine just shake the cubes around making sure none are built up along the back wall of the ice drawer. If this continues please contact our service department. Please reference incident number 2698767 should you need to call in. For more detailed information, please visit our web site at www.miele.com or to speak with one of our representative call 800-999-1360." Haven't tried yet, but will post again if it didn't work, otherwise should be the answer"
Nov 17, 2013 | Miele Freezers
My scotsman ice machine have a switch board that keep showing me red light on refrigeration and won't make any Ice.
Scotsman provides a lot of service manuals for their ice machines. It will really help if you could provide a model number so I can possibly find the correct manual and information that just may help you, Thanks Sea Breeze
Apr 04, 2013 | Kitchen Appliances - Others
Scotsman ICE MACHINE SHOWS NUMBER 6 IN DISPLAY
does it look like "6" or "b" , the "b" just indicates the ice bin is full. If the unit is not making ice, check the curtain on the outlet of the ice making coil to see that it is not stuck open. There is no listed "6" error code in the service manual.
Oct 09, 2012 | Scotsman Prodigy Air Cooled Cuber C0530SA...
My scotsman model 506as 1f, serial no. 06021320015994. Was running fine until i had it sent in to a local shop for routine check up during the normal winter down time for the machine. When i started using...
Have you pulled the cover off so you can see the code it is giving really need to know it. sounds like either low charge or hot gas valve not opening during harvest. I really need the code to be able to help you out.
Jul 07, 2011 | Scotsman Ice Maker CM3 30inW Cubed Ice...
I own the Scotsman Prodigy CU1526SA model. My machine is not making ice, the machine's Code Display shows code 3, which according to the manual, code 3 is for "slow water fill". But the...
chech water inlet valve to make sure there is no trash blocking it. if it is cleare then i would check the water supply to the machine and make sure the supply line is not kinked.
May 16, 2011 | Scotsman Ice Machine - 290lb...
I have a Uline CLR 2160 ice maker. I am trying to
Your display will only show ice or off. There is no temperature settings.Now when I give the directions to put it into clean make sure the green led above the symbols is on steady. If you hold down the on/off key and hit the light key 3 times then release the on/off key last.(give a 1/2 second delay from releasing on/off key. It should go to CL. If led lights dont comeon then let me know.
Aug 08, 2009 | U-Line Refrigerator Ice Maker
Beeps 3 times when turned on
3 beeps means the machine has ran two 1 hour cycles back to back to make ice an average timeframe for ice making is 25-30 min. Could be several issues, float switch dirty, water valve leaking by, dirty spray tubes, dirty evap., then go to refrigeration Expansion valve, compressor, charge, Hot gas valve leaking by,,,,,
Jun 23, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Scotsman C1030MA32A Logo
190 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
