Question about D-Link DI-808HV Router (280006OB)
D - Link Router and a switch
A client using a D-link Router and switch. They just upgraded to DSL 1500 mbps. They are currently still having problems getting acess to the internet and it occassionally goes down. Also, on occassion it is very slow. The have about 5 machines connected to the network. I am thinking the D-Link Router needs to be reconfigured. What do you think
    Problem Solver:
  • 14 Answers
If you don't have the latest firmware for your Dlink router which is 1.43, please download it first. You may want to download the software here: http://drivers.softpedia.com/progDownload/DLink-DIHV-Firmware-Download-20625.html
Access you router by going into 192.168.0.1, then look for the firmware upgrade option. Point the location of the .bin file that you've downloaded and that should fix your intermittent problem.
Hope this helps.
Thanks.
Posted on Jul 07, 2008
Problem with D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
What HW version is your router?
What FW version is currently loaded?
What ISP Service do you have? Cable or DSL?
What ISP Modem do you have? Stand Alone or built in router?
What ISP Modem make and model do you have?
Ensure DNS IP addresses are being filled in under Setup/Internet/Manual?
Turn off QoS options.
Turn off Advanced DNS Services if you have this option Setup/Internet/Manual.
Turn on DNS Relay under Setup/Networking.
Setup DHCP reserved IP addresses for all devices on the router.
Ensure devices are set to auto obtain an IP address.
Set Firewall settings to Endpoint Independent for TCP and UDP.
What wireless modes are you using?
Try single mode G or mixed G and N?
What security mode are you using? WEP, WPA or WPA2? Preferred is WPA2 and Cipher type to AES only if your device support this.
Feb 18, 2012 | D-Link DES 1016D (DES-1016D) 16x10/100...
I have a D-Link DSS-16+ and I was wondering if I could plug the dsl modem in any port on it and will it work? Thanks
The DSS means that this is a switch, not a router. This means that you will need a router between your modem and the switch. Switches are usually used in workplaces where there are many machines connecting to the internet with wired connections. For home use, most things connect wirelessly. The reason why you need a router is because a switch cannot create internal IP addresses like a router can. It can only pass on the IP information.
Jun 17, 2011 | D-Link DSS-16+ (dsdldss16p) 16x10/100 Mbps...
My current router is rated to handle 108 Mbps, but its only running at about 0.61 Mbps, going by this handy website http://www.speedtest.net/?s=234 My current plan is setup as 1Mbps Where am i going...
The speed test only gives you information on your internet speed, not the internal transfer rate, which is the 108MB advertised. This rate will not be acheived in a home connection.
Mar 06, 2011 | D-Link DSL-G604T Wireless Router
Hello, Got a D-Link 1005D 5x100 Im having 2 computeres atm, but i cna only get one to work. When i plug the internet cables from the computers to the D-link router, only one can work, please...
Your D-Link is a "switch", not a "router".
So, every computer that you connect will require a _UNIQUE_ IP-address.
However, your account with your Internet Service Provider is only granting you *ONE* IP-address.
Upgrade your account to pay a few dollars more per month, to get additional IP-address(es).
Buy a D-Link Router, for under $50, and connect both computers to the 'LAN' ports,
and connect the 'WAN' port to your cable-modem (or DSL-modem).
Dec 08, 2010 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Use 2 wire to run laptop
Yes you can use the laptop with this router because this is a wireless router.
Details of the router are:-
Manufacturer: 2wire Product MPN MPN 1000-400108-001 Key Features Router Functionalities dtrquestion.gif Wireless Access Point • DSL Modem • Firewall • DHCP Server Connectivity Wireless Interfaces Built-In 4-port Built-In Switch LAN Interfaces 10/100 Base-T Additional Interfaces 1 x USB Standards and Protocols LAN Standards IEEE 802.3 CSMA/CD or Ethernet • IEEE 802.3u 100 Mbps (Fast Ethernet) Protocols dtrquestion.gif AAL5 • ARP • ATM • DHCP • ICMP • IP • PPPoA • PPPoE • TCP • UDP Remote Management Protocol dtrquestion.gif SNMP • HTTP Firewall / VPN Firewall Features Stateful Packet Inspection (SPI) • NAT VPN Protocols IPSec Pass-Thru • PPTP Pass-Thru • L2TP Pass-Thru Authentication CHAP Wireless WLAN Standards IEEE 802.11b 802.11b Data Rates 11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps Modulation dtrquestion.gif CCK • DBPSK • DQPSK • DSSS Security dtrquestion.gif WEP Antenna Type dtrquestion.gif Internal / Integrated Antenna x 3 Modem DSL Standards ADSL Lite (G.Lite ITU G.992.2) Other Features LED Indicators Power • DSL • Link Additional Features Auto Crossover (MDI/MDI-X) Dimensions Width 2 in. Depth 10 in. Height 8 in. Weight 1.4 lb. Miscellaneous Release Date December, 2003
May 03, 2010 | 2wire (1000-400108-001) Router
I need to connect dsl to a router then to 9 pc's
connect the router configure the settings give by the internet provider and configure the NAT then u can attach a switch if required and can access....
Dec 29, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Dec 31, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
Connecting xbox live to my d link 1005d
Is the PC's connected to the D-Link able to browse the Internet? Sometimes the MAC Address will bind to certain IP's and must be cleared out when the Router is replaced. Please unplug the power to the router, X-Box and Cable or DSL modem. 1st plug in the power to the DSL/Cable modem until the "Ready" light comes on. 2nd plug in the power to the D-Link Router, wait 30 seconds then plug in the X-Box, power on and test. If a computer plugged into the D-Link will browse Internet then this is the solution to your problem.
Adam
Oct 26, 2008 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
D-link 2640
i think your problem is the configuration,in the security of your wap.try to configure it again.
Jan 27, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
D-Link DI-808HV Router (280006OB) Logo
79 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
