Question about Sony Cyber-Shot DSC-F828 Digital Camera
Lubricant Does the lubricant go right in between the dial and power switch or should I take apart the camera?
  • 10,594 Answers
I think, lubricant is not so intelligent to reach there.
Posted on Jul 08, 2008
Does the walking belt need to be lubricated? If yes what type of lubricant
down load the manual if you don.t have one
if it needs lubrication it would be a dry lubricant like graphite powder
contact the service agent for the machine and get the right lubricant
Dec 17, 2015 | Proform Exercise & Fitness
Screen states Lube Belt , do not have user Manual , Where are lubrication points and what type "lube" can I use ?
hi,
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
Dec 26, 2010 | Horizon T91 Treadmill
Volume knob only increases volume
Try spraying some electrical contact cleaner into the volume potentiometer - i.e. take off the volume knob, then spray the cleaner at the base of the plastic stalk.
Feb 22, 2010 | Denon CDR-M30 CD Recorder
My 2000 Nissan Maxima power window switches work intermittently. The driver's side master switches control all windows just fine. Each passenger door switch only works to put the window up. If you cycle...
The switches are done. If you dont want to bother with them again- just buy new ones-....or just take them apart and clean them every 3 days.
Dec 02, 2009 | 2000 Nissan Maxima
The self timer lever is stuck in the activated position of my Yashica-D. Is there an easy solution?
If the shutter release does not activate your timer and release the shutter, it probly needs taken apart by a repair guy. They can free the timer, clean out the old dried up lubricant, put in fresh lubricant, adjust everything and return it to you...working.
lightspiritphotography.com
Oct 27, 2009 | Photography
Lubricant for coffe machine
Hi, you shouldn't really use any other lubricant apart from the one recommended, but I have used vaseline on a similar coffee machine, and as long as you keep it away from the brewing head, it should be fine. Do not rinse the brewing head in very hot water as it will wash away any lubricant that is there.
Jun 15, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Mode dial on my Kodak DX6490 camera is hard to turn!
dissmantle the back case (watch for 1 hidden screw under rubber covers), lift plate on back of lcd screen, remove screw on back of dial, clean where it sits on both sides (most probably from a liquid spill...tea, coffee...) , apply some lube with a cottonbud ore a bit of tisue and rebuild.
hope this helps
stewart
Apr 04, 2009 | Kodak EasyShare DX6490 Digital Camera
Inside lights
Remove "Door Ajar" switch. Clean the switch and use a graphite type lubricant (I recommend "Dry-Slide") to lubricate the actuator on the switch. Reassemble the switch.
The switches are located inside the door panels, attached to the catch mechanism.
1) Remove interior door panel.
2) Using a T-27 Torx driver, remove the 3 bolts holding the catch in the door.
2a) The door ajar switch is the only part on the mechanism with the 2-wire harness.
2b) The switch is located at the rear catch for the sliding door.
3) Using a small flat screwdriver, gently lift the black tab on the catch mechanism and rotate the switch to remove it from the catch assembly.
4) Using a rag, clean the small round actuator and apply a small amount of graphite lubricant to the actuator and work the switch so it moves freely.
5) Reassemble the catch and the door.
Jul 20, 2008 | 2003 Ford Windstar
Random "mode flipping"
Mode dial has connection problem in built-in switch. try to use W-40 lubricant 1 drop.
Jun 05, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
Sony Cyber-Shot DSC-F828 Digital Camera Logo
44 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
