Every time i need t set date and time in bios. Is any software or update solve this problem or any method to solve pleas send me as early!!!!!!!!
  • 600 Answers
If you keep losing the date and time..you need to replace the CMOS battery
Posted on Dec 29, 2010
How do I fix my PC bios problem: After shutting down the PC, the time & date of the PC is wrong , what can I do?
Replace the battery on your motherboard.
I used to have that issue. Replacing the battery should fix that.
Apr 14, 2015 | Computers & Internet
How to change to a different date in advanced booting options
To change your system date through Advanced Booting options, you first need to enter BIOS setup menu of your system. To enter BIOS setup menu and to change your system date, you can follow the instructions below:
1.Boot your system and enter BIOS setup menu using the designated key. Though the key to enter BIOS may vary depending upon the computer manufacturer, usually keys like Delete, F12, F10, and F2 are designated to enable a user to enter BIOS setup. To know how to identify the key your system is designated to enter BIOS setup, you can refer to the image under "Method 1 of 3: Enter the BIOS" section on the following webpage:
Important: Following link is of a third-party website. We recommend you to update your security software thoroughly before clicking on the link.
http://www.wikihow.com/Change-Computer-BIOS-Settings
2.As soon as you identify the BIOS setup key, strike it rapidly and repeatedly (while the booting is on) till the time you enter BIOS setup menu. You may get just a few seconds to do this. If you are not able to enter BIOS setup menu by pressing the key repeatedly, reboot your system and follow the same steps again to enter BIOS setup menu.
Note: BIOS menu do not support mouse input. Hence, you will have to navigate through the menu using the arrow keys on your keyboard.
3.Once you enter BIOS setup menu, you can change the date of your system by going to "System Date" option. This option is generally located in the "Main" section of the menu.
Important: The layout of BIOS menu varies from manufacturer to manufacturer but most of them share a few common settings. If you are not able to detect "System Date" option in the "Main" section of the menu, you may need to look into other sections to locate the option.
To get a pictorial explanation of the above steps, you can refer to the following link:
Hope this will resolve your issue.
GuruAid.com
Aug 09, 2014 | Dell Microsoft Windows XP Home Edition
Date/time not set, OK button will not make contact to allow setting of date/time
you need to update the software of your digicam.
The service centre would do the updation part for you,and after that your problem would be solved.
Nov 26, 2010 | Fuji FinePix F460 Digital Camera
System date error! Pleas check NDS system date.
Change date to 13/04/2010 in ds system settings
Apr 14, 2010 | Nintendo DSi Black Console
System Date Problem in EEE PC 1005HA
As if you have tried changing the date & time in your control panel plus BIOS.There is nothing left to be done regarding changing date & time.
But If your CMOS battery in the motherboard fails,it will always goes back to it deafult date & time.Replace the battery and it will solve your problem.
I recommend to use Sony Lithium Battery
Dec 21, 2009 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Unable to save date in m/b bios
make sure your using new cmos battery not yet been use and then set date in your bios and save it after finish.
still doesn't work?
try update your cmos that migth be the problem note! remember always take care of the risk on updating flashing cmos on power interuption never power off if still flashing. or if you update and flush it before it might be a bad flash of your cmos try bring it up to early state or restore your backup cmos firmware or download it to its main manufacture
Jun 30, 2009 | MSI 945GCM5 Motherboard
Windows vista has does not response when i install it , and i find the problem that the bios software is out of date so i will work to update the bios but i cant know how can i update the bios can you help...
To explain how to update the bios, would be very difficult, as it is a strict method to complete.
And would be a very lengthy conversation.
below is a link to the procedures for you
(WARNNG) you must get it right first time.
Flashing the Bios is not difficult, it must be right.
http://www.wikihow.com/Update-Your-Computer's-BIOS
Take your time, soak up the method's and procedures, practice the procedures in the steps,
Go for the BIOS update, only when you are confident that you have understood all the topics involved.
You will need a working, online Pc system,
so you can download and get the updates.
Hope this helps
Regards.
Richard.
Apr 20, 2009 | Computers & Internet
Loss of calendar & clock when no power
ok the only way to check if the battery is working on your mobo is to look in the bios, im not sure if you are good at looking into bios,or you may be wanting to get someone to look at it for you,it does have a internal clockin bios that can be adjusted to the proper time/date.If it is not holding the time correctly(usually found by checking bios after reboot) then your battery on the mobo needs to be replaced,and can be reasonable cheap. HOWEVER, chances are it might be in the O.S. and if this is true can be changed (RIGHTCLICK ON TIME IN THE TOOLBAR--ADJUST TIME/DATE),,,,,, but if this doesn't hold your time/date after another boot up then there is a bigger problem i.e. software issue. Sometimes illegal downloaded software containes a patch that fools software into thinking that its too early to try and oudate(renew) or search for updates that wont make a program work any longer. Good luck JLS
Oct 21, 2008 | Evesham Axis PC Desktop
No text
i had a problem like this and i called tech support, they told me to turn the phone off & then back on... it worked. maybe you should tell your sister to try that too
Nov 05, 2007 | Motorola Mobility MOTORIZR Cellular Phone
Thinkpad 380ed
1) This is a typical problem when the CMOS battery is very weak or dead, it will continually display the date and time and reboot with the same errors until you change the CMOS battery. On this model it is behind the door that houses the memory chip, above the battery, if you have the laptop turned over and battery closest to you. <--best bet, its a dead CMOS battery.
2) You can get to the BIOS to run tests, one of 2 ways, either hit the ESC key and other keys to get a 301 error or hold the F1 key and boot, you should get into BIOS. (You probably won't be able to do this until you replace the CMOS battery.) From there you can run diagnostic tests on various components.
3) Lastly, you can update the BIOS. From inside the EASY-SETUP bios you should be able to copy the BIOS part number, date, etc. Look for the BIOS update based upon model # either thru a search on the web or directly on the IBM website (a search on google of "bios update thinkpad 380ed" will bring up a link for the IBM page.) If you choose to do a BIOS update, read the directions carefully and remember not to power off the machine while the update is happening. If you've never updated a BIOS before, get someone who has to walk you thru it before attempting it by yourself.
GOOD LUCK :)
Sep 19, 2007 | IBM ThinkPad 380ED
Computers & Internet Logo
David Payne
David Payne
