Question about Kenwood Audio Players & Recorders
Kenwood - Compact Disk Player DP-SE7 Serial No. 80802769 When I put a CD into the player and press play it spins the disk and then showes a mesage on the display "No disk". I have tryed fliping the disk to be sure I have it on the correct face and get the same results. I tryed cleaning the lasor lense and found no change. What do I need to fix this problem? Rob Arnouts
The Marv
  • 72 Answers
SOURCE: CD Player Not Working
You could take the unit apart and clean the lens with some rubbing alcohol. Or thy running a lens cleaner through it. But most likely the problem is a bad lens assembly and if this was not an expensive unit it is time to replace. But only disassemble if you know what you are doing.
Posted on Jan 05, 2007
  • 36 Answers
SOURCE: CD won't play; continually shuffles from one CD to another
did it just start doing this....how long have you had the unit for?
Posted on Dec 31, 2007
VOTIT
  • 2071 Answers
SOURCE: I-Pod Connection to Kenwood R-SE7
it's better to auxiliary,but if the cord of the optical digital it's ok..
Posted on Jul 25, 2008
SOURCE: Can this be fixed?
i have an audiovox dvd player model D1718 . i put the disc in and it says it is loading but then comes up no disc . how can i fix this problem?
Posted on Oct 14, 2009
  • 99 Answers
SOURCE: technics sl-pg580A
this player uses a philips mechanism, spindle motor failure is very common on these mechanisms, yours may be on its way out. take the lid off and insert a cd and if you can hear the laser trying to read the cd without it spinning, it's definately the spindle motor.
Posted on Dec 20, 2009
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Feb 10, 2016 | Panasonic Technics 5 Disc Compact Disc...
CD player plays some CD but some of the others it spins them and tosses them off the cone
The center cone on the hub could be a problem if the player was not for the right juke. Each brand has their own style. (If you still have the old player, check and make sure the the hubs are the same.) The center cone on the hubs are glued in place so if they are different you might be able to pop the old one off and replace it to the new player. One other problem could also be the magnetic pressure disk that is supposed to hold the disk on the hub. Is it centered in the hold down arm or does it rub the sides? Does the disk wobble as it spins? The magnetic disk is supposed to hold it down on the hub to prevent it from wobbling and coming off the turntable.
Oct 20, 2014 | Wurlitzer Jukebox 1015 One More Time...
Car radio cd player error 43
The motor that spins the disk no longer works, disassemble the cd player and replace your cd motor with a new one. Radio shack has them, but I suggest replacing your player with an aftermarket unit like sony, kenwood, audiovox, or any other high quality cd players.
Dec 07, 2013 | Hyundai Cars & Trucks
Does not play has e22 on display on my kenwood dp-m6010 disk player
On the kenwood dp m6010 6+1 cd player, the e-22 and e-21 codes are for the laser head movement limit sensors. More than likely the drive belt is broke or stretched.
Jul 27, 2013 | Audio Players & Recorders
My kenwood dp-r99 reads ee
I just took my DP-R99 out of the closet and powered it up in my garage. After a short delay it reads EE. I took it apart and the belt that drives the laser head up to the CD and pressure disk to make it spin is slipping and never raising the head enough. It looks like the belt has stretched over the years. I am now going to look for a replacement belt and the belt that rotates the carriage since it is also stretched. I will let you know for sure when I install new belts. Hope this helps...
Jun 06, 2009 | Kenwood CD-206 5-Disc CD Changer
Compact disc player, put disc in, pressed play the display is showing 00 0000 but not playing
Ensure first that there is no disk stuck inside.
If there is a disk stuck inside, try pressing repeatedly the eject button while you power up the unit. Do this a couple of time.
If there is no disk inside, or you get this same problem with all disks, then the lens are dirty, try using a lens cleaning product like the ones here.
Oct 15, 2008 | Denon Audio Players & Recorders
Jul 22, 2008 | Kenwood R-SE7 Shelf System
Dec 16, 2007 | Kenwood CD-223M 200-Disc CD Changer
Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
71 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
