Question about Scotch Tl901 Hot Laminator Bonus 100 Pack Pouches
I have a scotch TL901 laminate and it shut off on its own before the ready light even came on. I have unplugged it and plugged it back in and that did not work. I have let it cool down and then tried to plug it back in and turn it on. I have only used it twice.
2 Suggested Answers
  • 1212 Answers
SOURCE: my new TL901 just stopped working.
It is probable the heating element burned out. The heating element is just a long tubulat incandescent lamp.
You could try returning it to the store and exchanging it for another one. Otherwise in the documentation there is a contact information page, probably the phone number would be the best, and work with them that way should you get any issues from the store.
Posted on Dec 22, 2011
I jammed the laminating machine, so I unscrewed and opened the machine...but now I don't know how to roll out the paper? Please help me find a way to take this out without breaking the machine!
Carefully try to turn the roller one direction and then the next. If they move, you will see the feed direction the paper loaded from. Carefully move the rollers in the opposite direction letting the paper unwind. Do not force the gears. Hopefully the paper is not fused to the rollers.
Mar 03, 2015 | Scotch 9" Tl901 Hot Laminating Machine /...
Scotch Thermal Laminator not heating up.
well it sounds like you may have cut a wire or pull one somewhere. i would go ahead and take it apart carefully and check everything. may have unplugged something hopfully! let me know whwat happens!
Jan 31, 2014 | 3M TL902VP Scotch 9" Thermal Laminator...
Laminator won't heat up
This is just rediculous. Where's the friggin answer?
Mine won't even come on. JUNK!
Jan 28, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Please help!!! I put a pouch into my scotch TL901 laminater the wrong way and it is completely Jammed in the middle of the machine!!! I used a flashlight to see how bad it was ad it is completely shredded...
Unplug laminator. If it does not open up -check to see if the machine has a pouch jam lever. The lever will make it easier to remove the jammed pouch. Put the screw back after you clear the jam.
Jul 12, 2017 | Office Equipment & Supplies
DO YOU HAVE A MANUAL
I do not have a manual for that laminating machine. Over the years I have used a number of different units, and dismantled a few as well.
Essentially to use it, you let it warm up, and if you are pulling the laminate off a single roll, it should be folded over on itself, you roll an edge to see which side opens and slide in the item you want laminated.
The one thing that may be a source of bubbles in the finished product is you need to lightly roll a perforator over the item to pierce the laminating plastic so air can escape. Also make sure to have about 2 inches of extra palstic at each end for consistent results.
Feed it in straight, that 2 inches will allow you only a little room for adjustment- if at all possible, just feed it in, supporting the document so it does not flop over, and once it is feeding, you can see it come out.
Because it is nothing more than a heating element, and in the case of the smaller types, it is just a long halogen light bulb for the heater. It will always smell hot when in operation, because it is, and small amounts of plastic do peel off from time to time. So it is susceptable to damage if jarred while heating or in operation, and the tube can break if the laminator hits the floor.
To clean rollers of the laminator, normally they have a cleaning sheet, but not always, and if you do not have one, you can improvise by taking a section of craft paper bag, fod it over and trim to width of the laminating material. Feed it through and once it feeds, with gentle resistance held against the paper, this will help clean the rollers. Once through, open and refold so the inside is now outside and feed it through again with same procedure. Repeat with a new sheet until it feeds through clean.
If unit does not heat, check fuse if it does not turn on at , no motor, no light; and It may be an internal fuse on a circuit board. There is also a thermal fuse in the heater circuit as well- these can fail if the unit is left on all the time and not used. They should be powered down between uses. The exception is the industrial sized laminators used by many of the office supply stores as they take a while to heat. Otherwise the lamp is the chief suspect for no heat. If you plan to service it at hone, or to at least check the condition of the ttube, with an Ohm meter, you should be able to measure across the filament. It should be less than 20 Ohms resistance. Finding a replacement halogen is not cheap, and it may just be more cost effective to replace unit than try repair it if you are in an office type setting. It also requires you wear cotton gloves so not to leave any trace of oil or contaminant on the glass as they will fail at that point if there is any oil or other residue.left on tube when it lights up.
Jan 10, 2012 | Scotch 9" Tl901 Hot Laminating Machine /...
My new TL901 just stopped working. A few days ago when I first got it I lminated a piece of paper to try it. Then today went and turned it on to laminate again and it just shut off? what can I do
Dec 22, 2011 | Scotch 9" Tl901 Hot Laminating Machine /...
SCOTCH TL901 MANUAL
I have a scotch tl901. The laminating sleeve went into the machine and must have rolled around the roller inside. Is there a way to get it out? Is there a way to open the machine? I must have put the sleeve in open side first.
Oct 03, 2010 | Office Equipment & Supplies
I have a scotch brand laminator tl901- it is jammed...and making a clicking noise...is there a way to open the system and try to unjam it?
First, make sure that the unit is unplugged and has sufficient time to cool off. Then remove six screws on the bottom of the laminator. The screw driver shaft must be thin enough to fit into the holes where the screws are located. Two are very easy to find -- one on each side in deep holes. The other four are hidden under small black rubber disks that the laminator rests on. peel up the rubber disks and remove the rest of the screws. At this point it is easy to remove the cover and remove the jam. To replace the cover you must use a thin tool to pull back the release level so it will fit into its opening in the cover. Replace the six screws and you should be able to ready to laminate again.
Jul 10, 2010 | Office Equipment & Supplies
Scotch Tl901 Hot Laminator Bonus 100 Pack Pouches Logo
142 people viewed this question
Top Scotch Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Scotch Office Equipment and Supply Expert? Answer questions, earn points and help others
