Question about Goodman GMS90703BXA Heater
What is code flashing 6 times mean? - Goodman GMS90703BXA Heater
  • 1,772 Answers
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Sorry to read about your problem, I hope this helps you out.
Circulator blower runs continuously. No furnace operation. Integrated control module diagnostic LED is flashing SIX (6) flashes.
6 FLASHES
1 Rollout limit circuit is open.
2 Flame rollout. i? Misaligned burners, blocked
flue and/or air inlet pipe, or failed induced draft blower.
3 Loose or improperly connected wiring.
4 Check burners for proper alignment.
5 Check flue and air inlet piping for blockage, proper length, elbows, and termination. Correct as necessary.
6 Check induced draft blower for proper performance. Replace, if necessary.
7 Tighten or correct wiring connection.
Turn power OFF prior to repair.
i? See i?Vent/Flue Pipei? section for piping details.
i? Ensure the correct pressure switch replacement is used.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
Posted on Dec 29, 2010
HOW DO I FIX AN AIR CONDITIONER DISPLAYING E6?
Hi this link is a13 page error code manual for air conditioners, Hope this helps....
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
Apr 03, 2016 | Heating & Cooling
Why does my Sony kds-50a2020 power light flash 6 times?
I would talk to whoever rebuilt the optical block and see if they have any suggestions. It could be that the rebuilt unit is causing the problem.
Jul 20, 2014 | Sony KDS-50A2020 Television
What does red led standby light mean 6 times flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Jun 21, 2014 | Sony BRAVIA KDL-46W3000 Television
Meaning of fault codes vt commodore
no the code is not 1013
it should flash this same sequence 3 times (one flash small pause then 3 flashes large pause) and then repeat it if there is no other code. if another code is present then it will flash a different number 3 times and then start again with your original code.
DTC 13 - Right Hand (RH) Oxygen Sensor No Signal
Apr 28, 2014 | 1998 Holden VT Commodore
What is service engine light code 12 mean
READING CODES USING MIL (CHECK ENGINE) LAMP
Be advised that the MIL or CHECK ENGINE light can only perform a limited number of functions and it is a good idea to have the system checked with a scan tool to double check the circuit function.
  1. Within a period of 5 seconds, cycle the ignition key ON - OFF - ON - OFF - ON .
  2. Count the number of times the MIL (check engine lamp) on the instrument panel flashes on and off.
The number of flashes represents the trouble code. There is a short pause between the flashes representing the 1st and 2nd digits of the code. Longer pauses are used to separate individual 2-digit trouble codes.
An example of a flashed DTC is as follows:
Lamp flashes 4 times, pauses, then flashes 6 more times. This denotes a DTC number 46. Lamp flashes 5 times, pauses, then flashes 5 more times. This indicates a DTC number 55. DTC 55 will always be the last code to be displayed.
Fig. Fig. 2: Diagnostic trouble code chart (1 of 2)-1995-97 engines
Fig. Fig. 3: Diagnostic trouble code chart (2 of 2)-1995-97 2.0L engines
Jul 26, 2012 | 1995 Dodge Neon
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
Can I reset my motor on a 6 flash code?
Let us just see what 6 flashes mean:
Aha 6 flashes: locked motor check for objects between tubs
Once yall remove the objects yall might have to reset the motor inverter to do so:
Shut off the control. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. You might have to repeat this more than once.
How it works
Feb 13, 2011 | GE WJSR4160DWW Top Load Washer
I have a 96 dodge stratus es with the 2.5L V-6. When I do the engine code thing with the key the check engine light flashes 21 times. What does that mean?
You have to count the number of flashes between delays. For example, the light flashes twice, pauses briefly, then flashes 4 times. This problem code is 24. The end of the trouble code is 55, which is 10 flashes so you have at least 2 trouble codes on your vehicle.
Jul 09, 2010 | 1996 Dodge Stratus
I have a code of 6 red flashes on my KDS E50-A10 Sony TV. I was told to replace the lamp and I have just done that, but I still have 6 flasing re light code and no picture. any idea what's next?
6 times red light blink shows error in power supply (GT) board because of no 12 volts output for some reason.
Replace GT board to fix the problem.
Let me know if you need GT board part number info.
Thanks.
Dec 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
My TV is flashing a code
Try unplugging the set for 30 seconds then re-trying operations again.
Apr 10, 2007 | Philips 55PW9363 55" Rear Projection...
Goodman GMS90703BXA Heater Logo
339 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
