Question about Garland H283 Gas Kitchen Range
Uneven stove or turns on and off-i.e. not high enogh temperature The burners on top do not always start either
  • babafirst Dec 29, 2010
    thank you so much for your help-I just need to know what 1100 ohms is is that the oven temp or something else? Am so grateful for this help.
    Is there some special garland repair co. in Connecticut?
    Any information is greatly appreciated. Barbara
  • 4,323 Answers
Hi
The issue can either be a bad door switch/lock assembly or the oven temp. sensor itself that has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 29, 2010
  • Daniel Scott
    Daniel Scott Dec 30, 2010
    Hi
    You would need a multimeter to check the oven temperature sensor for 1100 ohms, if the reading in multimeter shows more or less than 1100 ohms then you would need to replace the sensor. Garland has service centers in connecticut---
    Garland service centers link 1
    Garland service centers link 2
    Hope this helps... Please post back if you need more information.
    Daniel
Burners turn on sometimes as does the oven but then may not turn off
Hello, when you turn on one of the burner, can you hear some clicking while you turn on one of the burners? This is an electric ignitor, and when you turn one burner on all the burner ignitor will click.
It is possible, that you are turning your burners on the stove to quick. Take a look at one of knobs and you will see ignition--low---medium---high. To get the burning ignited the knob needs to be position at the ignition site. You'll hear it click-click-click and the burner will ignite.
Now, the oven. The oven ignitor is on a time delay. You will push the bake button and across the screen will say something like this "Please set oven temperature" You'll set the oven temperature to---let say 350 degrees---. Then the screen will say "push start button" then you push the start button to turn your oven on. Now, the screen will say "pre" this means that the oven is pre-heating the oven to your desired temperature. Before all this happens there is ignitor in the oven and it has a heater on the ignitor in oven. This heater will heat up to desired temperature and once it reaches the that temperature the ignitor will ignite and the gas will turn on.
Why--one would say for this procedure. The old kitchen stoves had a very bad habit of of flash over---that is gas will built up in the over and once the pilot light ignited the gas---wussh and it blow the oven door open. These ovens would sometimes huff too.
Therefore, take your time and your biscuit will be OK
I am sorry Sandan2. I didn't finish reading your question. Never mind on what I said here.
If the burners will not shut off sometimes, then there could a gas regulator problem.
One very important question. Is your kitchen stove using Natural Gas or LPG--liquid Petroleum Gas?
If it is using either type of fuel as mention above. It is very important that you contact Appliance repair person that is certified by the state that you live in that he/she is license by the state to work with gas appliances.
I wish you luck, but it very it important that you contact a certified Technician... Also, move the stove away from the wall and look behind it. There a black gas pipe and at the end is a brass valve, Take wrench and turn the gas valve off. The gas valve will have a stainless steel flex line attached to it, and the other end is to your stove. Don't use your stove.
If those gas burners and the oven are leaking gas. There is possibility to blow you and your family with your home up. Don't use the stove, Until you have it check out...please. GB you/your family...stewbison
Sep 07, 2011 | LG LRE30755ST Kitchen Range
Hi there The oven burner is always on high ,even when I turn it on 200..
The oven burner will usually always be on high, until the thermostat reaches the desired temperature and then will shut off the burner until the temperature drops and then restart on high again. If your oven is getting hotter than what is selected then it could be the thermostat that is not working right.
Jul 13, 2011 | Ovens
Oven too hot and uneven heat
We had the same trouble with our electric range a few years ago. We had the thermostat replaced and it has worked great ever since. Douglas
Jul 10, 2010 | Premier Kitchen Ranges
No clicking noise when turning the nob..
Most modern gas ranges do have an electric pilot light. This one however does not. Normally you should always get the ignition (clicking noise) whenever you turn the temperature control knob. Provided that the stove is plugged into an electrical source. If you are not, then your ignitor could be out. Replacing it is fairly easy with a difficulty scale of 5/10.
But on to your problem. If you lift the lid on the stove top you will see two holes about halfway between the front and rear burners. Just connect the stove to a gas source and put a match or lighter to this hole. Don't worry, it won't blow up or flare up on you. You will need to do the same thing to the oven. If you open the broiler part of the stove, use a flashlight and look inside. You will see a similar type of gas line. Do the same with a match or lighter.
As with all gas appliances, ALWAYS check your gas lines for leaks using soapy water. If you see bubbles after spraying the solution on, then you have a leak and shouldn't turn the gas on until it's foxed. Use yellow Teflon tape or "pipe dope" on all gas connections.
Sep 30, 2009 | Sears 61301 Gas Kitchen Range
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
Dec 06, 2008 | Frigidaire FGF326AS Gas Kitchen Range
GE Stove
check all holes on burner make sure all air/gas holes are unclogged do not use any ajax or any cleanser that will leave a powdery residue.
Nov 30, 2007 | Cooktops
Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove.  Must be a constant 220.  Let me know what you find.
Oct 15, 2007 | Frigidaire FED300AS Electric Kitchen Range
Garland H283 Gas Kitchen Range Logo
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
joneable
Level 1 Expert
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
