Question about Ricoh Aficio AP3200 Laser Printer
My problem with the Aficio is that I get the error message Close R Cover but I dont have the R Cover on the printer it was given to me without it is there any way that i can bypass this
  • 77 Answers
Look at the right side. the 'r' cover is most likely the right side cover.
it might appear closed, but make sure. and look to see if the switch that senses it being closed is not bent or broken.
Posted on Dec 29, 2010
How do I troubleshoot drum error message?
Is any information given on the nature of the problem? In my experience the majority of problems with this printer is the correct prompt not being given to the printer when a new drum was installed. As such I would recommend trying the following:
-Open the front cover of the printer.
-Press Clear/Back.
-To confirm you have previously installed a new drum, press 1.
-Assuming the LCD now shows Accepted, close the front cover.
I hope this helps.
Oct 26, 2012 | Brother MFC 7840W Printer
Ricoh Aficio SP 4100N SC 590 power off on
YOU DONT FOLLOW INSTRUCTIONS VERY WELL,,DO YOU???!!! CALL SERVICE PROVIDER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Aug 13, 2012 | Ricoh Aficio SP 4100N Laser Printer
My Lexmark printer when turn on it makes noise and it can not print with a error code 2200
Hello thanks for using Fixya
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Step1.
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes:
Continue to step 2.
No:
Attempt a test scan. If the error message does not reappear, the error is resolved.
Step2. Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.Did the error message return?
Yes:
Continue to Contacting Lexmark.
No:
Continue to step 3.
Step3: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes:
Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No:
Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Step4: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes:
Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No:
Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Feb 11, 2011 | Lexmark P4350 All-In-One InkJet Printer
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
Printer keeps saying it has a paper jam and to remove the jam from the back. There is nothing there! I think it just wants me to open and close the rear door, but that only fixes it sometimes. How do I...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 22, 2010 | Ricoh Aficio CL1000N Printer
I HAVE A PROBLEM WITH MY COPIER,NASHUATEC D435.
Enter in the service mode(SPmode),open the front cover and turn OFF the copier.Unpluged the machine,wait 10sec.amd pluged ON.Before clean the thermistors and thermofuses in the image fusing unit.Close the front door and turn ON the copiers.
Feb 08, 2010 | Ricoh Aficio 450 Copier
Error message stats 'pull out trays clear jam, close cover A. but can't find any paper in machine and cover a is closed
a very usual problem steve. try removing power to the printer and let it stay idle without power for abt 20-30 minutes and then try again.this should clear the error message from the memory.
Feb 04, 2010 | OKI B6200 Laser Printer
Error "close front cover"
make sure the protrusion that activates the switch telling the machine that the door is closed is not damaged.
Apr 02, 2009 | Ricoh Aficio 1018 Printer
Error Message
Thats an interlock switch, you can fold a piece of paper into a one inch long piece and then stick it in th "plug" this will over ride the switch, you probably have broken the plastic piece that is located on the cover that tells the printer that the cover is closed.
www.mfpsolutions.blogspot.com
Sep 28, 2008 | Ricoh Aficio CL3500N Laser Printer
Error msg..."close ADF cover". Where is it?
Adf : auto doc feeder
the top that you put the pappers in to copy mare than one sheet.
make sure all doors are closed.
lift doc feederas if making copy on glass look where the hinges are there should be a plunger next to one of them, that is the switch to tell it if it's open or flat. try pressing it down to see if message goes away, it may need adjusting.
Jul 15, 2008 | Ricoh Aficio 1013F Copier
Ricoh Aficio AP3200 Laser Printer Logo
64 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
