Amana Heavy Duty Extra Large CapacityTop Loading Washer 2 speed - 10 cycle Mod. LW8413W2 Mfg. No. PLW8413W2A S/N R-9504056772 Occasionaly,At the end of a wash cycle it will continue on to the next cycle and run the next cycle.
  • Anonymous Jul 09, 2008
    I'm having the same issue with my Amana washer. The only difference is mine is the Heavy Duty 2 speed 7 cycles.
  • Anonymous Mar 16, 2014
    amana heavy duty washer heavy duty 13 cycle model NAV3335aww
My heavy duty 7 speed motor cut off because of over heating and the belt was changed can you suggest a suitable model of fan belt for it. ?
Posted on Aug 20, 2008
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
My kenmore heavy duty extra large capacity 2 speed motor when drying my clothes squeeks when turning to dry clothes can I spray wd40 to make it stop squeeking and how or what do I oil?
Most likely a wheel bearing on the tub of a front loading washer, or the belt tensioner pulley on a top load washer. Either is not fixed by lubrication but replacement is called for. There are usually 3-4 wheels on front loaders that could be out. Replace all of them if you are going to replace one. The belt tensioner is a single assembly that can be ordered from any appliance parts warehouse or Sears.
Aug 01, 2012 | Kenmore Washing Machines
Vibration
With the age of the machine, although Speed Queen's are built like a tank, the suspension systems are one of the most worked systems on a clothes washer,so, that being said, I would check all related parts of the suspension system, springs,pivot,etc,.these parts do get tired, think of the amount of loads of clothes that you have run through the washer over those 15 years.
Good Luck !
Feb 14, 2010 | Washing Machines
My 15 year old Amana Heavy Duty Washing Machine (top loading) has developed a very bad squeak during the wash cycle.
sorry its the clutch and trasmission its going out either repair or replace the washer my wifes washer started doing the same thing somedays it did fine and others times started squeaking.
Dec 22, 2009 | Washing Machines
Squeaky washer in spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
How good are you and your tools?
Mar 27, 2009 | GE WBSR3140DW Top Load Washer
Jammed agitator
Some further checking indicated a bad transmission. As the unit is 15 years old, I decided the best solution was a new machine! ..
Dec 03, 2008 | Washing Machines
Kenmore washer out of balance
go to sears.com and find the parts listing for the 110 model number you have listed above .http://www.searspartsdirect.com/partsdirect/retrieveModelActionHome!retrieve.action;jsessionid=8mJfynqZfmsdSyTnd9kaQw**.shcapp3005?modelNumber=110.16502694+&pop=flush
You might need one of the springs. unplug the washer and take the cabinet off first. look around for broken or missing parts
May 12, 2008 | Washing Machines
Washing Machines Logo
974 people viewed this question
Top Washing Machines Experts
