Question about Hampton Bay 24002 Ceiling Fan
Daughter was shaking out her bed sheet when it hit the ceiling fan and all the lights went out, looks shorted. Do I need to buy a new light unit?
  • 425 Answers
No, you don't need to buy another unit as long as your ceiling fan motor still in good condition. most probably the cause of the blackout is the overload of the fan motor when the fan blades entangled with the sheets and it trips the breaker due to over current.
if your fan still runs by now then it is ok. to be sure, have it checked for a qualified person.
Posted on Dec 29, 2010
Ceiling fan and light not working after short trip.looking for wall switch,gfi,or breaker.no wire ring diagram
Ceiling fan and light Bruce, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Wire Fan Light With Black White Blue Wires
Install or Replace Ceiling Fan
Wiring Diagrams Ceiling Fan and Light Kit
How to Wire Ceiling Fan With Light With Different Switches Ceiling Fan...
Mar 23, 2016 | Dryers
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
I have two minka aire ceiling fans in the m bed rm, controlled by two separate wall remotes which are hard wired and have dip stwitches on there back sides, one fan/light works and the other will n
I think you have a mixed or a connected wire problem. It looks like your breaker has tripped, doesn't need to spark... :) to trip. Is everything the same voltage ? Are you sure there's power at the switch mentioned..
Don't take anything for granted, respect electricity..
Jan 27, 2013 | Minka Aire Ceiling Fan
Hunter ceiling fan fan is working but lights are not
Make sure light wire is connected at the ceiling & at the bottom. Otherwise it's probably the receiver. 1-888-830-1326 ( Hunter parts )
Jan 05, 2013 | Hunter 52" Ceiling Fan With Light And...
We have a Broan/Nutone 763RLN Ceiling Fan/Light in need of cleani
The grille is held in place by the reflector. The reflector is hidden by the the lens. The first step is to remove the lens, then you will remove the light bulb. You will see one wing nut above the light socket. If you unscrew that the reflector and the grille should come down. The replacement motor assembly for the 763 RLN is the S0503B000, if you are looking for a little more power you could also purchase the S0504B000
http://bit.ly/ax4Upk
Jul 12, 2010 | Broan-NuTone N-763RLN Combination Light...
My light and fan combo has worked fine for the last three years or so. Yesterday when I went to turn on the lights, there was pop sound and my remote receiver was shorted out. What is going on?
I believe you answered your own question.  Shut the breaker off to the fan unit, and get a visual of the control module pcb.  If it looks repairable, have at 'er.  If it looks real bad, replacement may be your best option. http://www.eceilingfans.com/pc_boards_-_ceiling_fans.html If the price scares you, have another look at the one in your hand!
Jul 15, 2009 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan lights won't work
Possibly, your switch has a short in it.Outside of that, it may be a broken wire somewhere. Hope this helps. Good luck.
Aug 25, 2008 | Aloha Housewares (93645) Ceiling Fan
Ceiling fan lights do not work
You may have shorted out the light kit. Did you remove the other bulbs and put in new ones? They may have all blown when you heard the noise. Try that first, and if it still doesn't work, you may have to buy a new light kit. They are not expensive, and you can buy one without the glass bulb holders or cans, whatever you have. Then you can still use yours after you install the new light kit. Good luck!
Jan 05, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 24002 Ceiling Fan Logo
44 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
