I have a Visionquest Picaso HDTV. The screen goes black. Audio OK. Tried both rear and side video/audio input. Problem appeared when TV was mounted on wall. My name: Jean-Marie Lepage Adreess: 111 rue Gérard-Gauhier Apt:319 Gatineau, QC, J8L-3C9 819-483-1347 jean.marie.lepage@videotron.ca Hope you have a solution. Thanks, Jean-Marie
  • 3,267 Answers
Yes, this is a very common problem. Often times it is the inverter capacitors that wear down (they look like small batteries with a white stripe and are close to the transformers). If you can get in to the circuit boards, these capacitors are often visibly swollen on the tops; they are normally flat with an embossed X.
If you are going to replace the capacitors, pay very close attention to which way the stripe is; if you reverse this, the capacitor may explode
Posted on Dec 29, 2010
Has audio, but why did screen go black?
since the self generated menu displays ok id say you don't have a monitor problem , could it be that maybe somehow it got switched over to maybe an "open" input port (example: hdmi-2) as this would explain things a bit , also when you tried the other tv did you use the same cables to connect it as the non working tv ? as that also would explain things
Feb 09, 2016 | Panasonic Viera TC-P46C2 46" Plasma HDTV -...
Where do I plug in headphones?
Looking at the specs for your TV, it does not appear to have the jack for earphones.
You will have to connect an audio receiver to your TV and use the reciever's jack.
Connectivity
  • HDMI ports qty4
  • PC interfaceVGA (HD-15)
  • Input/Output connections3 x HDMI (19 pin HDMI Type A) - Rear,
    1 x HDMI (19 pin HDMI Type A) - Side,
    2 x Component video input (RCA phono x 3) - Rear,
    1 x Composite video/audio input (RCA phono x 3) - Side,
    2 x USB (4 pin USB Type A) - Side,
    1 x Ethernet (RJ-45) - Rear,
    2 x Audio line-in (RCA phono x 2) - Rear,
    1 x VGA input (15 pin HD D-Sub (HD-15)) - Rear
  • Video interfaceHDMI,
    Component,
    Composite
Jul 14, 2012 | Samsung PN50B650 50-Inch 1080p Plasma HDTV
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
Need to locae he audio outputjcks on my 32 in LG
Here is the list from the spec. sheet of all of the connections available on your TV
1.0 x HDMI ( RCA phono x 3 ) - Rear , 1.0 x Composite video/audio output ( RCA phono x 3 ) - Rear , 1.0 x VGA input ( RCA phono x 2 ) - Rear , 1.0 x Remote control ( 4 pin mini-DIN ) - Rear , 1.0 x S-Video input ( 19 pin HDMI Type A ) - Rear , 1.0 x Serial ( 4 pin mini-DIN ) - Rear , 1.0 x Composite video/audio input ( RCA phono x 3 ) - Rear , 2.0 x Composite video/audio input ( Mini-phone stereo 3.5 mm ) - Side , 1.0 x Audio line-in ( 15 pin HD D-Sub (HD-15) ) - Rear , 1.0 x S-Video input ( RCA phono x 3 ) - Side , 1.0 x Audio line-in ( TOSLINK ) - Rear , 2.0 x Digital audio output (optical) ( 9 pin D-Sub ) - Rear , 1.0 x HD component input - Rear
Nov 20, 2009 | LG 42LC2D 42 in. LCD HDTV
Need specs on Tru Tech TV from 2006
Technical Details
  • 32" Screen Widescreen HDTV Monitor with LCD Technology
  • Wall Mounting
  • Inputs: D-Sub VGA, Coaxial TV Antenna, Composite Video for Analog NTSC Video, Audio In, S-Video for Clean and Crisp Video, PC (RGB) Component, L/R Audio
  • Outputs: Left/Right Audio, Headphone
  • On-Screen Hi-Scan 1080i
  • 1366x768 Resolution
  • Contrast Ratio: 600:1
  • 25ms Response Time
  • 2 Speakers Side Panel Speakers
  • Operational Features: Closed Caption
  • Operational Modes: Brightness 500 Nits
  • Viewing Angles: 170 x 170
  • Accessories Included: Detachable Base Stand, Remote Control
  • 39.45(L) x 6.30(W) x 18.39(H) "
Nov 18, 2009 | TruTech PLV16320 Television
TV ranking
Hi. You could look up reviews. I personally usually never offer advice on choices, because what I like, may not be what you like..its a matter of personal preference. But in this particular case, I'd go for Panasonic. Why? Better features, better service, easier availability of parts, and better resolution.Plus some nice features. If this answers your question, PLEASE don't forget to rate as fixed. I'd really appreciate it. Enjoy your new tube!!!
Jeff
May 12, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Cant play My ipod on my Samsung TV
not detecting the side inputs?....try plugging the ipod into the audio input 1 and select video 1 on the input...if you hear sound...your ok
Apr 23, 2007 | Samsung HCM422W 42" Rear Projection...
Video input from dvd player shows as black screen w/ squigly color lines
have you tried other devices for input...vcr, or other dvd players to see if it is a problem with the player or with the tv? Check the output setting for the dvd player (1080i etc) and ensure you are connecting to the proper inputs for either analog or digital signals (RCA inputs or RGB).
Aug 15, 2006 | Hitachi 57S715 57" Rear Projection HDTV
Open Questions:
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
