Question about Samsung SCH-u340 Cellular Phone
Samsung phone does not ring
My samsung phone does not ring. I only can feel the vibration when someone calls. I have it turned to the highest volume using the volume outside button and the settings. Please help.
  • guessmyname2 Apr 30, 2009
    my u340 does not ring. I selected ringtone
  • Anonymous Mar 12, 2014
    phone not ringing or vibrating s8300v samsung
Thanks for the help it worked
Posted on Jul 11, 2008
Hold the number sign down for a couple of seconds (you know, the little tic tack toe thing(
Posted on Jul 08, 2008
How do I turn the ringtone volume up? i set the ring setting to "vibrate and ring" and when I get a call from someone I sometimes feel the vibration but I don't usually hear my ringtone...how...
Hello patty,
Depending on the brand and model of your phone, there usually is a volume control on the side of your cellphone. If it doesn't have one, please reply here and indicate the brand and model of your phone.
Oct 16, 2011 | Cell Phones
Can the jitterbug ringer be turned off?
You can set your phone to Vibrate or silent mode so that the phone vibrates rather than rings. With the phone on and open, look at the inside screen while adjusting the ringer volume using the rubber volume button on the outside of the phone. As you adjust the volume, the inside screen will display the ringer volume level. It ranges from Max to Vibrate. Simply turn it down until the level reads Vibrate.
If you would like more step-by-step instructions, please call our Customer Service department at (800) 733-6632. We are available 24/7.
Feb 14, 2011 | One Touch Jitterbug One-Touch Cellular...
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
I have LG GM205 phone and have 2 problems.\r\n1st
Change profile to silent, then go back into general profile & select 'personalize'. Go to Keypad Tones & turn off, then click back & select 'activate'. You should now have no keypad noise and the phone should ring.
Jun 04, 2010 | Cell Phones
I have a Samsung Smooth (U350)using Verizon. The alarm only icon is on and the phone does not ring when I have an incoming call. If I put it in vibrate mode, it does vibrate for an incoming call. How do...
To get the Phone to Ring - open the Phone and on the side there is the Volume Control buttons up and Down - press the Up button and than press the OK button to "set" the Volume to high.
I am not sure what you are trying to you with the alram - follow dirctions above and if it is not sloved let me know
hope this helps
thanks
Mar 19, 2010 | Samsung Smooth SCH-u350 Cell Phone
No ring when phone call is received
Hello. Most likely the ring has been turned off. The volume adjustment setting goes from loud to soft to vibrate only and finally to no ring and no vibrate. The volume key is on the outside of the phone on the right hand edge.
Regards, Joe PS - kindly rate my answer as helpful. thank you.
Feb 18, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Samsung T629 does not ring when someone calls
your ringing style is either set to only vibrate or you made the phone silent. (hold the # key to off and on silence)
Please Don't Forget To Rate "FIXYA" Me For The Help
Dec 21, 2008 | Samsung SGH-t629 Cellular Phone
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
BUTTON ON THE OUTSIDE TO TURN THE VOLUME DOWN
try a full facroty master reset, if still persists,
take it to someone who knows how to 'flash' it
Mar 12, 2008 | Motorola Mobility RAZR V3
Samsung SCH-u340 Cellular Phone Logo
3,625 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
