I have replace the inserted cartiage with a new one and inserted more paper and still the display screen says "drum error" or "no tray". I have also taken out some paper and moved the blue tab side to side more then several times, and now it says "drum error" and "no tray"
  • 52 Answers
Switched off the Printer and reinsert the cartiadge, and switched it on and the reset button for 7 seconds. And then give a print from your pc. If you facing the same problems, then without doing any thing just again press the reset bottom of your printer for 10seconds. I think this will solved your problems.
Thanks You
Posted on Dec 29, 2010
Risograph 3770 Drum problem
Seems the 'synchronisation' between paper feed and drum ist lost. Maybe you have heard a ripple sound? This means the toothed belt has jumped one or more teeth.Remove back cover loose paper feed clutch to readjust the belt accordingly ...
Sep 03, 2012 | Riso RP 3700
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one.
did you do the reset procedure? if not it's in your owners manual under the section "replacing the consumables".
hth,
razors
Nov 29, 2011 | Brother HL 5250DN Laser Printer
Canon iR2022, now: "drum is
check the drum insert flag in the drum unit(front side).it has to be intact as it has to match the sensor when the drum unit is inserted. u can see it when u insert the drum unit it is it at the front of he machine.u can also bypass it by placing a paper int the sensor
Jul 21, 2011 | Canon iR 2016i Black and White Copier
My HP Laserject Printer can print out the paper, but nothing show on this paper. And then this show the message "Paper Jam carridge check." So how do i fix this?
It sounds like the drum of your printer has a problem. Try inserting a new toner to see if it behaves the same way. If it does it is the drum and your printer is gone. If not, it could've been the toner.
Jul 04, 2011 | Computers & Internet
Moved and plugged in printer and it won't wax. I get a message remove and check cartiages. Relpaced cartiages and still won't clear the error message. please advise... leener_hines@yahoo.com or post. ...
Hi
if you have replace with new ones and you still
get that error
try cleaning cartridge carrier with a paper towel
if nothing is happening
you need to take it to an Hp support point
near to you
if i helped you pls vote
Sep 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Panasonic KX-FL512 fax drum life error
You need to follow the instructions that came with the drum as you need to reset the internal counter.
Dec 06, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Paper jam at around toner cartridge
paper jam usulay case by the heat of our toner cartiage. our cartiage became like magnet to our paper.
in my case i use a wet tissue (for baby type, non alcohol), i clean the drum (i hope u know where).
for sometimes the paper jam didn't happen.
i think our SCX is old enough
Sep 29, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Printer cartiage error
This page may help.  One of the things it's supposed to help with is 'cartridge error'.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00094661&dlc=en&product=374581
If that doesn't help, can you provide more detail about the cartridge error message?
Dec 28, 2008 | HP PSC 1315 All-In-One InkJet Printer
Toner cartiage and drum replacement
Go to menu to reset drum settings. I think you leave the front cover open press the right arrow then 1 one the lcd shows replace drum then after the lcd says accepted close the front cover.
Dec 18, 2007 | Brother MFC 9700 All-In-One Laser Printer
New cartiage/not reconized
It says there is no cartridge, or does it say that the cartridge is empty?
First, you must realize there are two cartridges. A drum and a toner. If you bought a new toner, pulled out the drum and put the new toner in, you have pulled a DOH! You can't just put the toner in. You have to take your old drum cartridge, remove the toner portion and install the new toner into your old drum and then install the entire assembly back into the machine. I hope you didn't throw your drum out thinking it was all one cartridge (I've seen it happen). This is where reading the owner's manual helps.
If not, then one of the contacts must have been damaged. Remove the cartridge and look inside the machine. See if you can find any of the metal contacts on the side of the inner chamber that is bent or damaged and try to bend it back.
Check the drum and make sure none of the contacts are damaged.
If the unit is still saying Toner Empty, try this. On the left side of the toner there will be a while lever in a semi-circular notch.
Unplug the unit, use a small screwdriver or a key to push that white lever back to the front of the notch. Put the drum and toner back into the machine and plug the power back in.
Nov 29, 2007 | Brother IntelliFax-2820 Laser Fax
29 people viewed this question
jasbo
jasbo
