I attempted to replace my RUUD 41-20804-16 thermastat it's an old mercury thermastat but after taking it off I decided against it and need to reconnect the old one back only now I can't remember where all the wires go. HELP!!! I have a white, yellow, blue, green ,red , orange, black,brown wire. There are six places on the thermastat that are marked with letters that had a wire connceted to them. They are G,B,R,Y,X,and E. I know the blue goes to B, red to R, G to green yellow to y, But I can't remember what color wire that remains goes to the X and E. The 2 remaining wires where never connected. If you can help I would be so grateful.
chillmaster
  • 104 Answers
SOURCE: Manual Thermostat replcaement with Programmable Digital unit.
Hopefully there are markings on the old t-stat as to what terminal is what.
on the honeywell 8000 use the heat pump labeling and then the standard wiring would be
R- red
AUX-white
Y- yellow
B- O/B
C- black
G- green
There should not be a bare wire, it probably just has the insulation stripped back way too far.
You should probably open the furnace and compare the terminal label in the furnace to the wire color. normally yellow and blue pass through the furnace and are wire nutted to wires going to the outdoor unit. In the furnace the white wire will connect to the w or w1 terminal. also, you will need to set the Honeywell stat to have the following parameters.
170-7
190-1
200-0
other parameters that I did not specify, you may read the manual and make your own decision but I recommend factory settings for the other parameters
Posted on Jun 18, 2008
koolbreezes
  • 540 Answers
SOURCE: ac heat carrier thermastat model no.hh01ad042
GOto the iside unit itself. and remove the door and look for a terminial strip that the thermostat wires from the thermostat connects to and write down the colors wires and the letters they're connected to and connect the same to the thermostat .... they should be... r--red=power w-white=heat y--yellow=cool g-- green=fan! See which wires/ colors they're not using and bend back! Thank-you-very-much!
Posted on Sep 01, 2008
  • 56 Answers
SOURCE: Trane Weathertron XE1000 Thermostat Wiring
Check to see if you have the system switch accidently on em. heat. The way you have it wired is correct except for the having brown on e. disconnect brown wire and cut ofbare end just in case they have the wire hooked up for constant run on roof.
Posted on Feb 16, 2009
peyton32034
  • 410 Answers
SOURCE: thermostat wiring goodman model aruf032-ooa-1b
is this a heat pump or straight cool with heat strips?
Posted on Mar 16, 2009
  • 30 Answers
SOURCE: Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Posted on Apr 12, 2009
Do I have to take any other parts off or replace antifreeze after I replace the thermastat/
Probably not, but do top up coolant and if dirty, drain and fill with clean coolant mix. Good to dry off any belts which got wet, too.
Dec 19, 2014 | 1989 Mercury Cougar
1995 Mercury Sable will not start
If the starter is the original, I would suspect it needs replacement.
Mar 07, 2017 | 1995 Mercury Sable
"RUUD Achiever 90 Plus" Propane
Hello bikejocky,
MOST LIKELY you have a "hot surface" element
with a tiny crack in it...
About 25 years ago... I put one of my poor abused
fingers on the element to see if it was at all warm...
In so doing I touched the spot where the crack was...
and it did INDEED have a full 120 volt, 60 cycle AC
current waiting for my FINGER to complete the
circuit... (not a recommended procedure)
My 25 year old RHEEM... finally kicked it.
I keep spares... and bought 2 more when I used
the last
Since these parts are pretty cheap... I get spares
62 22868 93 Rheem 62 22868 93 Hot Surface Ignitor
Take a look... There are two basic configurations
The WISEST APPROACH is to use a "meter"
to verify the "line current" is present (not finger)
and check the "SURFACE" for continuity.
Once you copy the number DIRECTLY from
YOUR OWN part... look it up... internet... eBay
and AMAZON (like Robert Shaw #41-408).
http://www.ebay.com/itm/ROBERTSHAW-41-408-Hot-surface-ignitor-NORTON-271N-/121727955205?hash=item1c578d3105:m:mJR3I8e9mTI60A-dtmvdVrw
>> It is the plug & mount that is important...!!
(consider that spare you always wanted
(If you get it... you will probably never need it)).
The cycling limit & fan
(never touched a RUUD... (so... I presume)) is to clear accumulated GAS FUMES to avoid any explosive
situations.
I do know RHEEM... (ERGO... I have every confidence)
((RHEEM & RUUD, in my opinion, are design twins)).
Carnac the Magnificent
May 10, 2017 | Ruud UBHC Air Conditioner
I need to know where the thermostat is located on the engine
follow top radiator hose to engine where hose stops thats where the tstats at.
Sep 03, 2010 | 1997 Cadillac DeVille
I have an old ruud achiever 10 i shut it off by the thermastat to change filters and now my outside unit will not come on at all, we replaced the fan motor and we checked the power , power is going all the...
High, sounds like the time delay relay went out when you shut it off at the stat, and has failed. It is a small 24 volt circuit board or small black timer box that is adjustable and if it fails will keep the outdoor unit from ever coming on. If you know what terminals to jump across, it can be bypass completely. If it fails which happens many times as I carry many different types for the people who want a new one, it keeps the outdoor unit from starting at all. When it is working, it prevents the unit from short cycling.
Shastalaker7
Aug 14, 2010 | Ruud UAMB Air Conditioner
Wireing a honeywell thermostat
Bill ..You dont have a heat pump.This controller will not work for a conventional system. Get the right thermostat
Jul 24, 2009 | Heating & Cooling
Hunter thermastat, model 44860 not working
Is the compressor running? is the outside unit clean and free from debris? does this unit work in the heating mode during the winter, and is it still capable of that now.
Jun 01, 2009 | Ruud UAMB Air Conditioner
Samsung 42 inch rear projection not working
If you have no prior experience repairing TV sets, I wouldn't recommend opening it up under any circumstances. There are voltages inside that can kill, even when unplugged.
Your safest bet would be to go with a repair guy. Shop around for various prices. In the end you will have to weigh the cost of repair against a new set and decide..
Oct 26, 2008 | Televison & Video
Central air conditioner
check the filter also sounds like a low freon charge.
Jul 29, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
327 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
