SOURCE: Fuse keeps blowing
This is probably a water heater problem Try operating on the lowest temp eg.15C If it goes through the cycle then its more than likely your water heater You will need a refit
SOURCE: fuse keeps blowing out in my maytag washing machine
replace the complete lid switch ***'y. be sure to adjust properly.
SOURCE: Machine keeps tripping the fuse at the fuse box - WD61 Aquarius Hotpoint
I believe the problem is in the fus(breaker). I would say that it is the thermal fuse in the machine but it usually goes out before the breaker does. The breaker has gotten weak over the years. You have a hi limit on the machine as well but I doubt this is it. Let me know how you do.
SOURCE: my washing machine keeps blowing he fuse in the plug
That means that there is a short or a contact inside the machine.
The short can be on power cable, on control panel, on in the internal wiring harness.
SOURCE: 125 v 4 amp fuse keeps blowing
if you plugged a 125 volt tv in to a 220 volt outlet you more than likely fried alof of the componets in the tv. Putting a bigger fuse in there is only going to increase the risk of it catching on fire so i would not recomend that. you might replace the power supply and cross your fingers and hope that nothing else cooked when the 220 volts hit it
