Question about Keurig Special Edition B60 Coffee Maker
Why is the keurig not brewing coffee, just hot water is coming out everytime
  • 1,772 Answers
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
Posted on Dec 29, 2010
How do I get my keurig off the hot water setting back to brew
try inserting a K cup instead and see if it reads that and automatically returns to brew.
Nov 23, 2014 | Keurig 2.0 K550 Brewing System
Keurig b31 mini. Power light on, brew light not on
Water reservoir may not be seated properly or filled above the Max line. Did you do a purge and establish filling the hot water reservoir?
Feb 08, 2013 | Keurig B30 Mini Coffee Maker
Water is hot but it does not brew the coffee.
Hi. How do you know that the water is hot if it wont brew coffee. They have different boilers to do each function. Hot water function. steam function and brew funtion. Sounds to me that you have a clogged brew unit. If hot water is coming from the water outlet, the you do have a fault with the brewing side of things. Dazza REPAIRER
Sep 23, 2011 | Keurig Elite B40 Coffee Maker
Won"t brew the coffe right and hot water coming
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 22, 2011 | Keurig Platinum B70 Coffee Maker
I have a new B31 mini plus keurig brewer and I put the water/coffee in, hit the brew button, it flashes red then turns off after about 2 minutes without brewing the coffee.
MODEL B31: I made the mistake of not running water thru the machine first (the Initial cleaning) and was unable to get water to come thru to the K-cup. Reservoir was hot and full and would not come out. SOLUTION: I took a bendy-straw and completely covered the inside needle coming from the top (that goes into the K-cup) and pushed it up with a fair amount of pressure and blew hard into the straw. Then sucked on the straw (BE CAREFUL IF THE WATER IS HOT) and water and some coffee grounds came out. The brewer worked perfectly after this!!
Nov 27, 2010 | Keurig B30 Mini Coffee Maker
No water coming out makes noise and slite water and its not hot
Use vinegar as water and soak over night. Use the same vinegar as water the next day as if brewing coffee. Then use fresh vinegar as if brewing coffee. Next use water several times until you don't smell the vinegar. Now try brewing a pot of coffee. good luck.
May 12, 2010 | Keurig Elite B40 Coffee Maker
Keurig Special Edition B60 Coffee Maker Logo
146 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
