Question about Linksys Wireless-G WRT54G Router
I have correctly set up the router, but, even without ethernet cable, it shows unflashing power and link lights. And it doesn't work.
  • 591 Answers
First reset the router (by holding down the reset switch in the back for 20 seconds), then if after configuring it (acording to manual and ISP information) it's still not working, i suspect the router is defective...
You could also try updating the FIRMWARE from the Linksys web site even if you are at the latest version, some times re-flashing the firmware helps solve bugs that could be in your present firmware
After all of the above you unplug the WAN ethernet cable from the router and the corresponding WAN LED is still ON, ther is defenetely something wrong with the router, return it for exchange.
Posted on Dec 30, 2010
Testimonial: "Looks like it really is defective: nothing worked. But still, thanks for your help."
Can i hook up wrt120n to laptop without hooking up to cable modem to fix?
Try this: Unplug EVERYTHING(related to both the router and modem). BEFORE you plug in power to anything, connect all of your ethernet. So, first ethernet goes from modem to router. Make sure they are in their proper places. Next, take another ethernet cable and attach that from modem to computer. NOW, power everything up. Google the linksys router splash page login. Im sure it'll be something like: 192.168.1.1 or 192.168.0.1 or something along those lines. From there, you should be able to set up your wireless. Once thats all good, unplug just your computer and everything should be fine. If that doesn't work, its either time for a new router or you're having wifi card issues.
Apr 28, 2012 | Linksys WRT120N Router
I am trying to access the internet wirelessly from a lap top through a D-Link DI-624 I went throught the steps 1. plugged up the router 2. unplugged the DSL box 3. plugged up the ethernet cable to the DSl...
Unplug the power cables from both your DSL modem and D-Link router.
Verify the Ethernet cable is plugged into both your DSL modem and the D-Link router.
Plug the DSL modem power cable back in and wait for the self-test to finish.
Plug the D-Link router power cable back in and wait for the self-test to finish.
Plug your laptop into the D-Link router using an Ethernet cable.
Can you access the D-Link configuration page now?
Check to see if your computer is getting an IP address from the D-Link router.
Here's how to do that, assuming you're using Windows.
Hold down the Windows key on your keyboard then press the letter R.
In the Run dialog box type 'cmd' (without the apostrophes).
Click OK.
In the command prompt window type 'ipconfig /all' (without the apostrophes).
Press Enter.
Look for the line that reads 'Ethernet adapter Local Area Connection'.
Verify that 'Dhcp Enabled' is set to 'Yes".
Mar 14, 2011 | Computers & Internet
Modem router(quest gateway) works on one computer but won't connect to two other computers. was working on two ,and now only the one wired to it.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
1. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
2. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
3. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
4. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
May 11, 2010 | 2wire (1000-400108-001) Router
I need to enter my code
How to quickly install and use your Belkin wireless G router 1. Step 1
Position your Belkin wireless G router.
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Apr 23, 2010 | D-Link 802.11g Wireless Router WBR-1310...
The ''wireless'' light on my wireless router is flashing amber
Contact Belkin for Care at 1-800-585-2494 Toll Free,,
Jan 09, 2010 | Belkin F5D8236-4 Router
Linksys WRT160N will not finish installing. On the 4th step it says your ethernet cable does not appear to be connected properly. Error 321. I don't really think its the ethernet cables because i tried 2...
error 321 or 322shows that the cable is not connected to the router and the computer.
That is actually a bug in the CD. Even if the cable is connected it shows that it is not connected.
You can set up the router manually, without the CD.
Click Here for step by step solution
Nov 03, 2009 | Linksys WRT160N Wireless Router
I have no computer or cable and need to set up internet on my PS3
??? A router will NOT replace your modem; the router won't work without the modem. If you're going to give advice, please make sure it is somewhat correct.
Okay. So first you need the telephone cord to go from the phone jack into the DSL port on your modem. Then you need the Ethernet cable that came with your modem (looks like a phone cord but much bigger) to go from the ethernet port in the back of the modem into the wan or internet port on the router. Verify that the DSL and internet lights are on on the modem.
For the rest of the setup, watch this . It will walk you step by step in connecting your PS3 to the wireless internet. Thanks and please take a moment to rate as fixya.
Feb 04, 2009 | Sony Playstation 3 (PS3) Console
When i first connect my daughters computer with an belkin wireless router than i stop working than i purchase an d-link not thinking it would make a different but it didn't and still not working do i ahve...
No you can't use two routers (without being an expert to set them up correctly!). Make sure the Belkin isn't plugged in while you're setting up the D-Link. To diagnose the culprit, try these steps:
1) Plug your daughter's computer directly into the ethernet port of the DSL or Cable Modem. You'll need to do this to rule out your Daughter's PC as the problem. If it works fine, then move to step 2. If her computer still isn't working, and another computer connected the same way DOES work - then you need to work on your daughter's computer, becasue that's where the problem lies.
2) Ok since you confirmed your daughter's PC is just fine - and also the DSL or Cable connection is working as well - this indicates most likely the router(s) are at fault. So let's work with the D-Link, since we're not sure if the Belkin is working. Like I said, be sure the Belkin is completely unplugged and powered OFF. Now plug the D-Link into your DSL or Cable modem ethernet port. Turn on the D-Link, make sure the correct indicators are lit on both the DSL/Cable modem and the router. Reboot your daughter's PC and right-click on the wireless networking icon on her taskbar. Choose view available wireless networks - if you see your D-link listed, then the router is working! If you still can't connect - try disabling WEP/WAP and try again. Most likely it's just a security setting that's off.
Good Luck!
Dec 31, 2008 | Computers & Internet
2wire 2700 HG - Many problems and can't reset it!
you need to set up the 2 wire using an RJ45 ethernet cable and not wirelessly initially, and you need to set your ethernet lan adapter to obtain an ip address automatically and then type the default 192.168.1.254 in your browser to get in the settings and then set or enable dhcp, and also enable wireless as by default it is dissabled and check the the adsl light is lit
Some 2wire routers normally come with WPA-PSK security already set up with the passkey on a sticker on the side of the router, so that may be why it stays set when you reset it.
Check that your wireles adapter is using the same type of security when you enter the passkey when wirelessly connecting.
Nov 21, 2007 | 2wire 2700HG-B Router (2700HGB)
Linksys Wireless-G WRT54G Router Logo
396 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
