Question about Univex Food Mixers
I have a M30 mixer and need toget the pin out so that i can put a new one in. I have tried pin and hammer. I dont want to keep hammering away as to not destroy the bearings in the encased shaft. I have started to drill at it but, no luck in drilling through. Is that supposed to go all the way through?
  • 3 more comments
  • lbrisku Dec 30, 2010
    Well how do I go about getting a press since I dont have a diamond drill. Is it somthing I can rent?
  • dalekushmasr
    dalekushmasr Apr 12, 2014
    univex makes a tool to replace the pin contact tham, they show you how on u tube
  • dalekushmasr
  • dalekushmasr
  • dalekushmasr
    go to u- tube type in univex miser pin replace.....
  • 22,326 Answers
The retaining pin wears causing it to stick inside the shaft ,best thing i can think off is to leave it alone as it could run forever like this,trying to drill it is useless without a diamond drill bit as the pin is hardened steel ,possibly in excess of 60 rockwell C .As and when it shears then its easy to remove but hammering it will only welt the end making it jam in even harder .The motor could burn out before it wears away or a bearing go ,the only way to remove it is a press as this will not damage the end too much ,unless their is a secondary cotter pin locking this one in
Posted on Dec 29, 2010
  • Colin Stickland
    Colin Stickland Dec 30, 2010
    you would have to take it to an engineering shop they will have the right equipment
How do I put the silver ring back on my Kitchen Aid Classic
Tip machine upside down on a towel and try and encourage it back on again with a rubber hammer. Sometimes they just keep springing off. A small piece of sellotape on opposite sides will sometimes give it the grip it needs to stay on. Trim off any overhangs when you're done.
Jan 11, 2015 | Food Mixers
Help! Groove pin won't come out of the planetary shaft after repeated hammering.
Get the mixer onto its side, use the correct size punch and a bigger hammer. The last thing you want to be doing is drilling the pin out. If you cannot get the pin out it will not render the machine useless, it just means that the job is beyond your capabilities and you need to get someone with experience to do it for you.
Dec 13, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Help, the groove pin won't come out of the planetary! I already chipped so much paint of the mixer!
Kitchenaid KSM150PSOB speed switch will spring back to 3rd speed setting when trying to turn off. Noticed when its off and a little downward pressure is applied to the switch, it'll spring. Attempted to...
It probably is the worm gear but you must remove the planetary roll pin to be able to split the gearcase. You will find another smaller roll pin in the worm gear. Your speed lever problem will be either a loose screw that it pivots on or the lever is bent. Hammer and correct size punch is only solution for those roll pins. Bigger hammer sometimes helps.
Sep 15, 2013 | KitchenAid Food Mixers
I just bought the ice cream maker attachment and the metal collar on the beater shaft is stopping me from attaching the ice cream maker driver. How do I remove the metal collar from the beater shaft?
You need a small steel hammer and a pin punch. Do not try to drive
out the Groove Pin any other way (i.e. don't force it out with a regular
size hammer and a screwdriver), you will only damage the Planetary plate
and/or the Agitator shaft. Lay your mixer down on the floor and support
the Beater shaft with a wooden block before driving the Groove Pin out.
Jul 30, 2011 | KitchenAid 5KSM150PS Mixer
I've broken the agitator shaft pin on my Hobart A200T. I can find replacement pins online, but the local Hobart tech. is MIA. How do you remove the pin? How do you secure the replacement in the...
Drive it out with a punch and hammer. It's best to take the planetary off the machine so you can support the shaft. If not it puts a lot of unnecessary stress on the bearings and other parts.
Jul 08, 2011 | Hobart A200 Stand Mixer
The accessory attachment pin in the agitator shaft broke off. What is require to remove the pin?
Hammer and punch. Best to remove planetary so you can support the shaft. If not it puts a lot of unnecessary stress on the bearing and other parts.
Mar 28, 2011 | Hobart A200 Stand Mixer
Shaft keeps coming out
tighten the screw under the base that catches the pin. Turn the mixer upside down you can see the flathead screw in the casting. With the pin centered tighten the screw.
Apr 07, 2010 | KitchenAid K45SS Classic Stand Mixer
Trying to fix my KA mixer, and cannot get the planetary housing o
A screwdriver is for turning screws. What you need is a drift pin slightly smaller than the diameter if the pin you are trying to remove. If you can back the shaft up with something heavy like a hammer head and then try to drive the pin out you will be successful. They are pressed in with a light press fit and should yield to the above technique.
Mar 07, 2010 | KitchenAid K45SS Classic Stand Mixer
Planetary ring
ok im going to take a shot at this its been a while since ive been in a school kitchen
with the planetary ring its supposed to be tapped in make a jig by getting a 2x6 board and 2 2x4s they dont have to be long screw the boards together with the 2 2x4 standing 4 inch up across from each other about the size of the blender head
the wood is to support mixer while on its head and to keep from teetering around
put down down a piece of foam
put the mixer on its head upside down
now you have to find an old plastic sturdy made cup the size of the ring its gotta be able to take a beating (the cup)
but not a hard beating this will help in seating the panetary ring
now get another piece of foam
glue to top of cup let dry then trim around the cup evenly out side and on the inside leave a little foam over the inside edge
place ring on planetary drive where it goes put cup over ring make sure the cup matches size of ring
now get a wood rubber or small pin hammer and tap lightly on the cup till the ring sits itself back into position this is the safest way to place the ring
use a little appliance greese on inside ring lightly to help ease into place
now if any part of the ring is bent i dont recommend placing of old ring i would suggest buying a new ring for mixer
Jun 11, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
249 people viewed this question
Top Univex Food Mixers Experts
Oscar Netto
Oscar Netto
Are you an Univex Food Mixer Expert? Answer questions, earn points and help others
