Question about KitchenAid KBNS271TSS Gas Grill
Need inition switch for this model Kitchen aid, the old one has some numbers on it: The label says: 1.5V Guang Long Qd1.5-3E V=1.5VDC 0846
  • 142 Answers
SOURCE: Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Posted on Oct 01, 2008
  • 145 Answers
SOURCE: I need a coupling for
The piece that you need is referred to as the coupler. The coupler is a breakway part that is designed to shear and/or wear down in the event that the blender is overloaded. This is to avoid damage to the motor.
The coupler may be purchased individually and is an easy repair that can be done at home. You may purchase the part and access step-by-step replacement instructions at the following link:
http://www.mendingshed.com/kacoupling.html
Posted on Jul 07, 2009
jsrock516
  • 5911 Answers
SOURCE: How Old is Kitchen Aid Washer model#KAWE577BWH1
Your washer was manufactured in 1995 and is made by Whirlpool. If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you have questions, or my advice does not match your symptoms, please let me know. I hope this helps you.
Posted on Jul 09, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Posted on Aug 04, 2009
  • 246 Answers
SOURCE: Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Posted on Feb 25, 2010
What is the current replacement for this?
Hello Robert;
My name is Peter. I am a retired field service refrigeration technician.
The information you need is on a label, upper inside wall of your fresh food section; model number, cubic feet, ect.
Stay away from Samsung and LG units, bottom freezers and ice dispensers that are mounted on the door.
Kenmore is a good unit. Why are you going to replace it? I have serviced and repaired a Kenmore that was 30 years old. My Kitchen Aid is 24 years old.
Jan 15, 2016 | Kenmore Refrigerators
Is this a Kitchen Aid? Is it possible to buy this circuit board from somewhere?
This is a kitchen aid. BUT!!!! it is an international model that was sold in countries with 220 volts. Look underneath the mixer for a white tag it should have a model number and a serial number, if you can get us those numbers then we can help with the parts. Hope this helps.
Nov 05, 2014 | Food Mixers
Where do you find the serial number for a 5 quart glas bowl for the Artisan mixer
The serial number for all KitchenAid mixers is located under the base of the mixer. You will need to carefully tilt the mixer over, and underneath the mixer you will find a label with the model number and serial number.
Feb 16, 2013 | Kitchenaid 5 Quart Glass Bowl Artisan...
Kitchen Aid Manual for RRK90 mixer I need one
http://forum.kitchenaid.com/forums/pdfs/u_c_classic4.5_5qtmodels.pdf
old model k5ss
http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf
Mar 16, 2010 | KitchenAid K5SS Heavy Duty Commercial...
My 10 year old Kitchen Aid convection smooth surface range has a broken dual element switch on LF element. My Canadian Whirlpool contact provided a replacement switch # as 8203538, which I purchased. The...
your model calls for the pt # 8203538 and is a good # the sw 688 may be alright but I would use the 8203529 / this is a 15 amp sw. and is the correct replacement .it's blue in color and comes with instructions to install . . we use this sw alot and it does not cause porblems . / you should ck other things like tight connections at the power cord as loose or bad wire connectons will burn out the sw . ck all the wire ends for discoloring and if so replace them with hi tempt crome ones . they work best .. hope this helps **** .. .
Jan 10, 2010 | KitchenAid KERC507 Electric Kitchen Range
Trying to locate heating element on kitchen aid dryer
Do you have the part number, is so Put in (Find kitchen aid dryer Part# 111111* ) Or( Find kitchen aid dryer heating element* ). If this is a old dryer some parts are not made anymore. Any Dryer over 7 years old is no longer energy efficient. Hope This Helps.
Zipher
Oct 03, 2009 | KitchenAid Dryers
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Wiring hookup for a replacement part
hopefull yyou havent disconnect old switch yet. whirpool and kit aid are same Co. same parts used. assuming the correct part was sent for the corrrect burner. diffrerent element will require different rated swties(ie. small , large, dual and so forth.), the indivudal switches are labeled, on the swithc itself ( L1,L2,H1 H2, P1 andso forth, so although the switches looke differnet they should stil have the same lettered terminal to plug into .
Mar 15, 2008 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KBNS271TSS Gas Grill Logo
346 people viewed this question
Top KitchenAid Grilling Experts
Paul Carew
Paul Bade
Bill Boyd
Are you a KitchenAid Grilling Expert? Answer questions, earn points and help others
