Question about Jandy Laars Lt 250,000 Btu Heater
Heater doesn't heat all the way the spa - Jandy Laars Lt 250,000 Btu Heater
    Top Expert:
  • Jandy Master
  • 8,688 Answers
If aqua link turn heater all the way up then see if works ok
Posted on Apr 29, 2016
4 Suggested Answers
SOURCE: SPA Filter on while Spa is Heating
you have one jandy valve ( the suction valve in front of the pump) that is not working right when you press spa mode. have someone watch the valves to see if they move when you press spa mode and heat inside the house. if the one in front of the pump does not move and the switch is in operating mode then that valve is bad and will have to be replaced.
Posted on Aug 06, 2009
  • 990 Answers
SOURCE: I have an aqualink rs
If the Aqualink is calling for heat then the problem is most likley in the heater. Without more information I can't tell you much more but if nothing has changed in the last couple of days. Before you call anyone be sure to clean your filter and baskets. The heater need a set amount of pressure to run and if things are dirty it won't get that pressure. Good luck.
Posted on Mar 13, 2010
Testimonial: "The burner is lighting but won't stay on, more than a minute or so. I tend to think the problem is water flow, like you say. Thanks...DC"
Daniel S
  • 4323 Answers
SOURCE: The spa heater says the
Hi
1. Turn off the power to both the pool/spa control system and the heater unit.
2. Remove the front panel door from the front of the heater to access the raceway.
3. Run the wires from the pool/spa control system through the opening, Thermostat is located on the lower right or left hand side of the heater.
Please check this link for more details---
Jandy LXI 300 POOL HEATER Manual
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 21, 2010
How to trouble-shoot a heating problem on a cal spas "supra" above ground tub ?
what' s the problem? is the spa running but the temp doesn' t go up. is it set on vacation mode? can't help without knowing exactly what the issue is.
Sep 27, 2014 | Pool & Spa
Balboa vl700s
itheats when circ pump is on.
Jun 22, 2013 | Pool & Spa
Tylo sauna heater won't heat
if not calling for heat check temp sensor
Jan 19, 2012 | Tylo COMBI-U7 Sauna Heater
How do I disable the pool heater so that it doesn't keep heating up the water.
The obvious solution to this is to turn off the "fireman's switch" that is on the heater. You could also close the gas valve to the heater if it is gas but some heaters would keep turning the ignitor on and reduce its lifespan.
For a more definitive answer I recommend you call the Jandy technical supportat 800-822-7933 and they should be able to help you figure this issue out.
I hope this helps.
Sep 16, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I have a Hayward H100IH pool heater. With the pool filter on the heater starts to heat up when I turn up the thermostat, but the heat turns off after a few seconds.
That doesn't sound fun. You could call the Hayward technical support number at 908-355-7995 and they might be able to figure this out. I hope this helps.
Please vote for this answer. Thank you.
Aug 23, 2011 | Hayward Gas Swimming Pool Heater 100k Btu...
Pool not getting warm so bought a new regulator. The heater worked for 5 days and now it doesn't heat again..
You might call the Hayward technical support number at 908-355-7995, I hope this helps.
Aug 15, 2011 | Hayward Pool & Spa
Jandy Laars Lt 250,000 Btu Heater Logo
52 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
