Question about Ariston Technologies AW149NA Washer
Ariston AVTL 89 washing machine power led plus other two leds flashing?
The machine will start filling with water and then start emptying, then two lights starts flashing along with the power light.
Is there anything I can do to fix this?
Please advise
Many thanks
dazmaraz
  • 67 Answers
SOURCE: Ariston Washing machine A1636 - Flashing lights
what 2 lights are flashing each light that flashes gives a differant fault code . Get back to me
Posted on Jun 25, 2007
always reset your machine ;turn your dial to the end of the cycle [ the dot] it should flash 3 times quickly, then turn off the machine and on again. then start washing again ...hopefully..worth a try.
Posted on Aug 15, 2007
SOURCE: Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Posted on Jan 11, 2008
SOURCE: ariston avxl105 washing machine power
reset button
Posted on Jun 29, 2008
  • 78 Answers
SOURCE: Hi, my dishwasher type ariston LI 420 does not
you might have a blockage in your filter or in the pump,first i would find out where your waste pipe goes out to if it is plumbed out through ur sink take the hose off and hold it in a bucket and turn the unit on you should hear a sucking sound and if the does now drain then have a look in the sink waste trap it is very common for the sink waste to get blocked
Posted on Oct 21, 2009
Why Ariston lbf51 washing and drying light rapid flash
AL03 - Drain Timeout (drain problems)
LED 1 (washing) and LED 2 (drying) flashing.
Probably the siphon of the apartment is clogged.
  • Remove the drain hose and make sure that is not clogged.
  • Drain water in a bucket.
  • If the dishwasher drains the water, clean the siphon of the apartment.
Dado
May 25, 2014 | Ariston Technologies LL65 Built-in...
How to repair - no water is entering the dish waterr
Your dishwasher is equipped with a safety system which is able to detect any operating problems. These anomalies are reported by
one or two wash cycle indicator lights "E" will flash rapidly.
Any flashing combination of LED diodes (Intensive wash, Regular wash, Eco wash, Rapid wash, Soak and Crystal care) means different error code. Take a note of which lights are flashing?
If you have problem with fill water than following two LED should be flashing.24428775-0h3kxpflbez5mdeb5anq3st4-3-0.jpg
In this case could be:
  • Water valve disabled
  • Turbine disabled
  • Control board faulty
Dado
May 15, 2014 | Ariston Technologies LL65 Built-in...
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
LED lights flashing
maybe the washing machine is ok . there is something wrong with led light . the switch can't in a good contact .
home led lights
May 22, 2012 | Zanussi ZWF1420W Front Load Washer
The 4th green light on my Ariston dishwasher flashes. What does this mean?
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Mar 02, 2011 | Dishwashers
We just bought a second hand Ariston Washing Machine model AVL 95. It works fine all programs, but when it goes to spin, it starts to spin, speed up, and then stops with an error (Delay Timer flashes and...
its the drain pump see if you can take it out there small and easy to get to,also you see a black ribbed hose that goes to the drum to the pump see if there any thing in it.The drum is inclosed.try running 2xclorox through machine.
Jul 05, 2010 | Ariston Technologies AWD120 13 lb. Washer...
End led blinks 3 times
Had this exact problem (fills, empties and then light blinks three times) and found that the heating element was burnt out. Very easy to replace.
Nov 06, 2008 | AEG Lavamat W1050 Front Load Washer
Jun 20, 2007 | Ariston Technologies AW149NA Washer
Washing Machines Logo
191 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
