Question about Sony BDP-S350 Blu-Ray Player
HAS SOUND BUT NO PICTURE BLUE RAY BDP-S350 - Sony BDP-S350 Blu-Ray Player
4 Suggested Answers
  • 3 Answers
SOURCE: SONY BDP-S350 MULTIREGIONAL PROB
You should get Asian firmware.
They are (despite printed DVD Region 3, BD Region A) all DVD region free. Tested on mine (bought in Thailand).
Panasonic BD30 was also DVD Region free. The firmware for that one is available from Panasonic website. Not sure if there's another way than automatic update from inside BD player to upgrade Sony.
Posted on Apr 15, 2009
SOURCE: Will not play any disc that it use to play.
I had the same problem with mine and took a chance. it would read dvds but not blu-ray disc. i have done this procedure before with a regular dvd player so i tried it with my blu-ray and it worked. First you must open the blu-ray and take the blu-ray/dvd drive out open it up expose the lazer eye reader (make sure the blu-ray player is unpluged) and clean the eye with cotton swab diped in rubing alcohol.i would recommend using a flashlight when doing so. do this lightly and dry the eyes with the other side of the swab. you will see the difference once you clean it. I opened mine up after cleaning it with a dvd cleaner and the eye was still dirty. the eyes had a light film on it. I seen this on my dvd players that i have cleaned before. the film was enough to make the player not read the bul-ray disc. do not try this if you are not comfortable taking stuff apart and putting it back togetter. i hope this fixes your problem.
Posted on Dec 28, 2010
PhilwithDISH
  • 123 Answers
SOURCE: need code for Sony BDP-S350 for a Dish Network 622 remote
We would be happy to help you with that. Here is a list of codes that should address your DISH Network remote to your Sony Blu-ray player: 629, 671, 868, 617, 501, and 768.
Press and hold the DVD/VCR button located on the top of the remote until all the mode buttons at the top of the remote light up, then release. Use the number buttons to enter one of the codes for your Sony Blu-ray player, then press the pound (#) button. If the code entered is valid for the remote, the mode light flashes three times. Phillip Chang
DISH Network Customer Service Representative
Posted on Feb 22, 2011
My sony blue ray player is only playing DVD's but will not play blue ray disks. i have tried multiple disks
I'm having the same problem. My BDP-S350 Blu-Ray Player used to play blu-ray DVD's but suddenly is unable to. Regular DVD's I can play. Please help!
Nov 25, 2010 | Sony BDP-S350 Blu-Ray Player
BLUE RAY ONLY SHOWS IN SMALL SQUARE. THE PICTURE ONLY SHOWS IN THE MIDDLE OF THE SCREEN IN A SMALL BOX. NO MATTER WHAT IS TRIED THE PICTURE SIZE WILL NOT INCREASE. THE PLAYER KEEPS READING LOADING. I'VE...
This problem is easily fixed! I also have a BDP-S350, and had the same issue on "Crank 2-High Voltage". The fix is to put a USB memory stick into the port at the back of the player, 1GB is plenty big enough. This film and others play fine on PS3's or anything that has internal memory, but the 350 needs a memory stick permanently fitted. Also, make sure you have the latest firmware update on your player. Happy viewing!
Oct 10, 2010 | Sony BDP-S350 Blu-Ray Player
Just bought the sony bdp s350, bought the cable
What type of TV? Plasma / LED / LCD.. ?
Typically you should run through your HDMI ... most of the 5 RGB etc.. in the back can only be used on one of the inputs only for high def... HDMI is easier but more expensive cables..
May 12, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Sometimes doesnt even start playing dvd othertimes sound goes off mid movie
The most likely cause of your frustration with the BDP-S350 is that your player's firmware is not the most current. I have the same model, and had similar problems with Blue Ray Discs like 'Wall-E'.
The solution is to go to sony's website, download the firmware upgrade, burn it to a disc and then load the disc into the player to fix it.
I hope that helps.
Dec 23, 2009 | Sony BDP-S350 Blu-Ray Player
Will not play blue-ray discs
The most likely cause of your frustration with the BDP-S350 is that your player's firmware is not the most current. I have the same model, and had similar problems with newer Blue Ray Discs.
I hope that helps.
Nov 29, 2009 | Sony BDP-S350 Blu-Ray Player
Wont play blu ray disck any more
The most likely cause of your frustration with the BDP-S350 is thatyour player's firmware is not the most current. I have the same model,and had similar problems with newer Blue Ray Discs.
I hope that helps.
Sony blue ray bdp_350 no picture or sound
press and hold stop button returns player to factory reset which solved my problem.
Sep 29, 2009 | Sony BDP-S350 Blu-Ray Player
When a disc is insterted, the screen flutters slides laterally. Sound is ok but the picture makes us dizzy. Have tried multiple discs and use of the TV with cable and VHS. It is isolated to the blue ray...
  • probably the problem is with the disc
  • try 2 play it in another player
  • if there is no problem with the disc ,check if the drive is dusty
  • if so clean it using the cleaner disc
Jul 18, 2009 | Sony BDP-S350 Blu-Ray Player
Remotecontrol-codes
I got lucky and found one at my local markedplace :-)
Jan 05, 2009 | Sony BDP-S350 Blu-Ray Player
Sony BDP-S350 Blu-Ray Player Logo
386 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
