Question about HHP Dolphin 7200
I have a Dolphin 7200 scanner that I've created an autoexec.bat program for in order to have it immediately run an executable file produced from a compiled Visual C++ 1.52 program. Unfortunately, my C++ program had an error in it, and now when I reboot the scanner it hangs up after starting my executable program, I can't get back to the DOS prompt. What do I need to do to get back to the DOS prompt so I can download the program fix?
3 Suggested Answers
  • 65 Answers
SOURCE: I have a old 7200 hhp scanner with a program
Correct, but you need a HHP software to reflash this to original factory settings. Please be advised that currently loaded program might prevent from going to A:/ Prompt. I can help you get this done properly. . You can always contact me directly or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Posted on Jan 25, 2010
  • 1851 Answers
SOURCE: Hi, I buy an scanner
You must have the disk that come with the unit when it is new - please go here and read more:
We prepared this just for you:
I would be able to be more specific if I knew more about what all you have. The hand held unit is reset and programed through a windows program that comes with it. If you have your please read the above and proceed as ordered.
Posted on Apr 03, 2010
What is the mean auto exe c bat in dos files??
An AUTOEXEC.BAT file contains MS-DOS commands which are executed automatically when a Personal Computer boots. This file is usually located in the root directory of the hard drive or floppy from which the computer boots (or starts) up. The AUTOEXEC.BAT file is used to set various default settings and to run programs that should be executed upon startup. Below you will find a list of executable statements (commands) that typically go into an AUTOEXEC.BAT file, along with explanations their.
The AUTOEXEC.BAT file is one form of a batch file, and it is used to automate functions in MS-DOS. In their simplest form, batch files contain MS-DOS commands (batch file language) which includes commands for such things as loops and execution branches and the like.
Example: @ECHO OFF
This optional command will suppress the display of subsequent commands while the AUTOEXEC.BAT file is being executed
Dec 09, 2010 | Computers & Internet
I have a old 7200 hhp scanner with a program running on it. I need to stop the boot up of the scanner before autoexec.bat runs as I was wanting to to update autoexec.bat. The existing program doesnt have...
Jan 12, 2010 | Computers & Internet
I have GA-8iD533 motherboard. One of my friend tried to flushing the bios, but during the flushing the electricity was gone. After the electricity come i power on the computer,now it shows nothing and i...
To recover your motherboard bios and bring it back to life, you will need this following things:
1. Floppy Drive: It is needed to load the Boot Disk and the new BIOS update.
2. Boot Floppy: It is needed to load the basic operating system, preferably MS DOS.
3. ISA Video Card: Optional, but can simply the recovery process.
A startup disk can be automatically built from the Add/Remove Programs applet within the control panel. The boot disk is a vital part of this guide, though users with WinNT/2K will need to build this boot disk from a system running MS-DOS or Win9x/ME.
You can obtain it also from this website:
Be sure to copy all needed BIOS utilities and update/backup files used during the original flash process to this disk as well.
After making the boot disk, delete the config.sys and autoexec.bat in the boot disk. It can be found in the disk primary directory path.
Create your own autoexec,bat. Using a notepad, build the autoexec.bat file by putting all the command lines in flashing a BIOS.
The approach for using flash utility from AMI or Phoenix is similar, but be sure to read the provided help information about each command line option before building the autoexec.bat entry. Create the text command entry, and then save to the file "autoexec.bat" in drive A: . This will load the command at floppy boot time, regardless of whether an ISA video card is available.
Dec 16, 2009 | Gigabyte GA-8ID533 Motherboard
Hi i'm A ojt technician of computer and I encomtered the problem of computer the problem is system halted... what is the possible deffect of that problem. . .
it cannot find COMMAND.COM
Explanation: When you boot up DOS, you are placed at what is commonly called the "C: prompt", where you can type commands or run programs. The part of DOS that reads what you type and executes commands is called the command interpreter, which is stored in the file "COMMAND.COM". This interpreter is loaded when you start the system or when you start an MS-DOS session under Windows 95, and is also reloaded in some cases when you finish running a program. In this case, the system was unable to find COMMAND.COM and therefore halted the system.
try this
  • Make sure that COMMAND.COM is in the C:\ root directory, or if it somewhere else, that there is a line in AUTOEXEC.BAT that reads "COMSPEC=X:\PATH" where "X:\PATH" is wherever COMMAND.COM resides.
  • Edit the PATH command in your AUTOEXEC.BAT file, if you are trying to run a command in another directory that should be accessible from anywhere.
please send me a feed back if this works out thnk you.
Dec 12, 2008 | ASUS A7N8X-E Deluxe Motherboard
To make .bat file
Here is a site that has all of the information that you will need including the autorun.inf and autorun.bat. It is included in the sample and should be rather strait forward. If you need any assistance, please let me know.
Jun 14, 2008 | Microsoft Windows Vista Ultimate Edition
Format a floppy, in xp, set the "create an MSDOS startup disk" check box. copy the bios file & program to floppy then boot. follow mfr instructions. If it is an intel made board, download "Express BIOS" and run in windows.
Jun 05, 2008 | Intel Motherboard
How do i reboot windows vista. i knwo theres a way to do it not from the CD and it returns it to how u go it out of the box. please let me know thanks
If you are using MS-DOS 6.0 or later, you can use multiple configuration menus or the CHOICE.COM program to configure your system. For more information on using these options under MS-DOS 6.0 or later, type HELP MULTI-CONFIG or HELP CHOICE at the MS-DOS command prompt and then press ENTER. To create the files to automatically restart your computer with the appropriate configuration, do the following:
Create a directory on your hard drive called C:\CONFIGS. Create the CONFIG.SYS and AUTOEXEC.BAT files you need to boot your system for HIMEM.SYS and applications that require it, with the following names: c:\configs\config.dos c:\configs\autoexec.dos Create the CONFIG.SYS and AUTOEXEC.BAT files you need to start your system for the program that conflicts with HIMEM.SYS. Any unique file extension can be used. The following example uses 386: c:\configs\config.386 c:\configs\autoexec.386 The following DEBUG script can be used to create a small executable file called REBOOT.COM. This file, when executed, will cause your system to restart. To create the file, change to the DOS directory, and type the following: debug reboot.comEnter the following information, pressing ENTER key after each line: A 100 ; Debug instruction for assemble MOV AH,0D ; Disk Reset INT 21h ; causes SmartDrv 4.x to write cache MOV AX, 40 ; set up segment addressing MOV DS,AX DS: OR BYTE PTR [17],0C ; equivalent of pressing CTRL+ALT MOV AX,4F53 ; Issue a "DEL" (53h = DEL scan code) INT 15h ; EMM386 sees this & shuts down. DS: MOV WORD PTR [72],1234 ; Set REBOOT flag to Warm-Boot (0=cold) JMP F000:FFF0 ; Execute the internal restart routine <CR> ; This line must be blank (just hit ENTER) R CX 20 ; File size to be written to disk (in hex) N REBOOT.COM ; Filename W ; Write the file to disk Q ; Quit Debug NOTE: The REBOOT.COM file created with this debug script is compatible with SMARTDrive and its write-behind cache feature. The instructions in REBOOT.COM cause SMARTDrive to write (flush) its write-behind cache to disk before the computer is rebooted.
The following commands can be used to copy and rename the configuration files to the root directory of the C drive and restart the computer. To simplify the process, you can put these commands into batch files.
To start your machine for Windows, use the following commands: copy c:\configs\autoexec.dos c:\autoexec.bat copy c:\configs\config.dos c:\config.sys To start your machine for the 386 application, use the following commands: copy c:\configs\autoexec.386 c:\autoexec.bat copy c:\configs\config.386 c:\config.sys
Apr 29, 2008 | Computers & Internet
How to edit registry
1) to edit registry go to start / select run and type regedit. from there you are able to edit registry values. BEWARE because editing registry values may make your windows stop working. you should know what you are doing and you are responsible of the cosnequenses 2) a bat file is a batch file. Batch files are files that allow MS-DOS and Microsoft Windows users to create a lists of commands and/or programs to run once the batch file has been executed. 3) create a file called autorun.inf and type inside [autorun] open=file.exe save your file and write it in the cd you want to autorun the file.exe part must be replaced with the executable you want to load when your CD autoruns
Oct 08, 2007 | Microsoft Windows XP Professional With...
HHP Dolphin 7200 Logo
113 people viewed this question
Top HHP Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Don A
Don A
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
