Question about Mitsubishi VS-45605 50" Rear Projection Television
Ws-55809 when i turn tv on it turn's back off
    Sergeant:
    Champion:
  • 250 Answers
Your flyback transformer is going bad. It will likely need to be replaced.
Posted on Jul 07, 2008
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WS 55809
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Feb 21, 2008
Slinteriors
  • 8617 Answers
SOURCE: my mitsubishi ws-55809 wont turn
Does the LED light up when you press power? have to tried to enter the self diagnostic blink code by pressing menu and input on the front of the set both in together for 8 seconds and see if the LED will blink a two digit code? If so let me know what the blink code is.
Posted on Jun 18, 2008
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi ws-55809 needs new red tube
you can get a red mitsubishi tube at the following link and it comes with free shipping. If youre not sure which one to order, leave them a email and they will respond quickly, just let them know your model number and what youre needing. they are listed under the projection CRT catagory on the left side of their page. Here's the link.
http://servicemanuals.vstore.ca/
Posted on Jun 22, 2008
SOURCE: Mitsubishi tv model WS-55809
that happened to me and i just gently hit it on the top and it fixed itself
Posted on Jun 30, 2008
praky16
  • 744 Answers
SOURCE: My mitsubishi ws-55809 will not turn on
hi..
The problem is the Convergence circuit and the reason it does not power up is that one or two of the 5a pico fuses have opened when the Convergence IC failed. It is either going to be a pair of STK392-570's or a single IC STK393-110. That is as long as this set is a Mitsubishi made in the last 7 to 9 years.
I would estimate the cost to repair 280.00 plus service call fee if any, plus tax on parts.
Let the Tech check it out. If if it cost less than 400.00 to repair, it may well be worth taking the chance.
thank u
rate me
Posted on Jul 21, 2009
My HD 1080 WS-55809 won't turn on - little green light comes on for 2 - 3 seconds, then nothing. It was fine - we were watching a DVD but had it on pause - the tv turned itself off - then it won't turn...
Hi
Thanks for using FixYa. Error code 2-2 means short protect which is either caused by bad convergence ICs and/or 2 Pico fuses (F9A05 and F9A04). You’ll need to open the back of the unit and replace the parts that have gone bad to resolve this issue.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Where is the STK393-110
This TV uses 2 STK392-570's.
You will not find any STK393-110 inside your TV.
Jul 25, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Cobwebs behind the screen of a 55" projection screen. How do I remove screen to clean the TV? I have a Mitisubishi WS-55809.
Hello morsec,
You will need to remove the screws on the back of the top half of the TV set. This will allow you to remove the top rear half of the TV and give you access to the screen. Make sure you do not break the mirror that is attached to the rear of the TV set. Clean the screen with a damp non-abrasive cloth dry with a dry non-abrasive cloth. When finish replace the back of the TV and tighten the screws to hand tightness.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 Shadow
check the "close caption" option on the menu should be of
Oct 14, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55809
Sounds like moisture got into control surface.. Try hairdryer around buttons to dry it out..
Jun 30, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Connecting PS3 to Mitsubishi WS-55809
On the back of the TV you should find three sets of the component sockets, only one can produce 1080, the one that is labeled dtv (should be the one on the farthest right of the three sets).
May 13, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55 inCH tv
best way i would trouble shoot this would be to get a can of freeze from radio shack and spay the tuner if the problem comes back you know it's the tuner if not spray IC one at a time till the problem happens.
Dec 11, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55809
Looks like you are going to be working with the following:
1080i (HDTV) • 480p (EDTV) • 480i (SDTV)
Hook up depends on what else you have connected to the TV.  If you have nothing connected to the DTV component inputs, I suggest using those, as it will allow up to 1080i.  Otherwise, use the 2 other component connections directly to the left of the DTV connections.
Oct 19, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
