Question about Bruder Cat Skid Steer Loader
Have a 751 f bobcat hydrolics for bucket and arms do not work , looked at the bics control blinks 3 times looked in book said hydr. valve went short to ground,do not no where valve is located or how to fix
5 Suggested Answers
SOURCE: Bobcat 553 f - traction lock problem...help
sounds to me like a bad connection or a weak solenoid causing the voltage drop. a good alt charges at 14.25-14.50. it takes voltage to open solenoids not close them.
Posted on Sep 05, 2009
  • 31 Answers
SOURCE: hydrolic problem on bobcat
it may be broken
Posted on Jul 14, 2010
  • 4 Answers
SOURCE: Bobcat 751 loses power after running for only
it might be that the fuel line inside the fuel tank is clogged, its fairly easy just have to be careful with the grommet when you pull it out. Could also be that you need a new hand primer ball(pump).They seem to go bad.
Posted on Sep 10, 2010
SOURCE: 1998 751 Bobcat ! How do you remove fuel tank ?
hi i had the same problem . lift the cab up and look back by the hydrulic pump the tank is under it but you do not need to pull it out there is a 90 degree fitting for the supply line pry out the fitting and the tank strainer is hooked to it , if not it fell off in the tank .if it is there it is must likely cloged up it is a cheap part to replace . well i hope this helps you
Posted on Sep 26, 2010
How do you bleed the hydraulics on a Bobcat 751 skid steer loader?
Hi Joseph:
Usually hydraulic components will "self clear" any air in the system just by trying to cycle through the functions a few times.
Have to ask the question............
Did you remove and replace the hoses one at a time, or did you take them all off at the same time?
The reason I ask is............ Could there be a remote possibility that any of the hose onnection locations were switched?
Sep 23, 2015 | Toys
Is there an easy way to change the alternator on my 2000 751 bobcat skidsteer? I am having a hard time accessing it and I need to replace the alternator bracket.
about the easyest way is to have very long arms or you'll have to remove the radiator just like the rest of us short'tys
Jan 01, 2015 | Bobcat Garden
Bobcat V518 electrical hydrolic controls for bucket only goes down and won't come back up
Check all the sealing O rings for damage on control leavers.
Nov 03, 2014 | Dehumidifiers
773n bobcat will move forward and back but wont raise bucket
Bics coil on control valve not unlocking. Broken wire, bad connection or bad coil
Sep 25, 2012 | Bruder Cat Skid Steer Loader
Hydrolic arms wont lift up or down on Bobcat skidsteer 873
CHECK ALL THE SAFTEY SWITCHES ON THE SAFTEY BAR . IF THE UNIT MOVES FORWARD AND BACKWARDS THE SWITCHES AREN'T THE PROBLEM
Aug 23, 2009 | Danfoss Sundstrand-sauer-danfoss Hydraulic...
No vertical movement of hydrolic arms when pushing pedal
You will have to bleed the rams to get all the air out just crack the hose's open at the connector and have a person help you open the hoses on both sides and try raising the bucket when you get clear fluid coming out close the nuts on the lines then do the same thing for down position. Check hydraulic fluid level to make sure it does not get so low that you put air in the system. Be sure when you are bleeding to pay attention to fluid flow coming out of the rams is it even? If not you may have a hose that has collapsed. To know if it is look at how much fluid flows out of the hose the one with the lest amount of oil is suspect. Next if it still does not raise pull the pressure valve out of the control Block where the arm is for raising it crack the outer locking nut then remove the valve and see if you have a piece of dirt in the valve seat. If you need more help post it here and Give me the Year and model Number for more precise help for this unit.
Aug 23, 2009 | Garden
Jul 19, 2009 | Bruder Cat Skid Steer Loader
Bruder Cat Skid Steer Loader Logo
270 people viewed this question
Top Bruder Toys Experts
ptpumpman
Marc Taylor
Colin Stickland
Colin Stickland
Are you a Bruder Toy Expert? Answer questions, earn points and help others
