Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Heat won't stay on using Hunter programmable thermostat 44272. One thermostat installed downstairs, one upstairs. Warm air will blow out of the vents during the day but vents blow cool air throughout the night causing fan to run constantly never achieving the set temp
  • 52 Answers
SOURCE: Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Posted on Jan 29, 2008
  • 52 Answers
SOURCE: hunter fan programmable thermostat
Need more information about tstat model number what type of a/c and heater do you have..heat pump, gas furnace, electric heat. Also what wires are connected to the tstat and to what position on the tstat. I have included a link to hunter's user manual page for tstats. The wiring diagrams are there just enter your model number and click submit. Good luck Kevin
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
SOURCE: Programmable Hunter Thermostat
Our progammable thermostat continues to flash
Posted on Mar 25, 2008
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
heatman101
  • 43501 Answers
SOURCE: Why won't our blower turn off?
It seems that you have the emergency heat running all the time. On some t-stats there is a switch that runs the emergency heat all the time.
The other thing that could be happening is that the out door unit is stuck in defrost so the backup heat is trying to run any time you are in heating mode.
Without checking what is energizing the heat coils with an electric meter it is impossible to tell what exactly is going on.
I can tell you that I'm sure that it is related to the emergency heat, though and if you can shut off the breaker that runs that for now it will help you out till you can get it looked at futher.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 20, 2009
Rheem Heat Pump Thermostat Replacement (#41-20804-15)
you need a 2 stage heat and cool t-stat hunter t-stat is not 2 stage
Feb 19, 2013 | Heating & Cooling
Hunter 44272 Not turning on heater
i am recommending you try again to call to the service man. The reason is simple you change it and they have all the wiring diagram for do it quickly. Get support via ONLINE or chat or phone.
Maybe you have some wrong wires connect
God bless you
Oct 08, 2012 | Hunter 44272 5-Minute 5-1-1 Day...
Where can I get user manual
I need a manual for my model 44272 Hunter programmable thermostat. Please tell me how to obtain one.
Feb 21, 2011 | Hunter Fan Company 5/1/1 Programmable...
I have 2 Thermostat's in my home. My heat works well upstairs but not downstairs. My thermostat downstairs won't come on but I unhooked the thermostat from downstairs and tried it upstairs and it worked...
Hi, sounds like you determined the problem is not with the thermostat. That leaves the furnace that serves downstairs. What type heating system do you have?
Jan 13, 2010 | Honeywell Programmable Thermostat Heater
Electric Heater Only works on Emergency Heat Setting.
I would say that you are on the right track.
Jan 11, 2010 | Heating & Cooling
Flashing snowflake symbol and a/c is not blowing upstairs
flashing snowflake normally means it is in a time delay. give it five minutes and see if it continues.
Jul 20, 2009 | Honeywell Electronic Programmable...
2 zone sytem main floor cooler than what i set it to
Warm air rises and if the upstairs thermostat is on it will onerride to lower the temp upstairs. To have the dowstairs thermostat govern, the up stairs must be off . The whole house will balance to the controlling thermostat.
Jun 02, 2009 | Honeywell Programmable Thermostat Heater
Heating blowing coo air downstairs and warm upstairs?
Some of this depends on where the air handler/furnace is located. Most often in two story houses, it's in the attic upstairs, or in a closet upstairs. A duct routes air from the furnace to the downstairs supply duct, so it is a distance from the air handler.
When the unit first initiates a heating cycle, that duct is going to be full of cool air, and the duct itself will be cool. So the furnace has to run long enough to push the cool air out, as well as warm the duct up, before your going to feel warm air at the registers downstairs.
Keep in mind, heat rises. And, your thermostat only monitors the immediate area where it's located. In your case, upstairs.
Two story houses are problematic because of this. And one way around it is to have a damper system installed that distributes the air upstairs or downstairs based on a thermostat located in those spaces. There would be 2 dampers, and 2 thermostats (one upstairs, one downstairs). Each stat would control a damper, and the call for heat or cooling.
Let me know if you would like to consider a system like this, and I can point you to components to use. I've put several system like this in.
Jan 26, 2009 | Kitchen Appliances - Others
High Electrical bill - Appears to be heatpump problem.
Sound like there are running on emergency heat which is elrctric.Have the system checked out buy a local heating and cooling company. Have they checked the filter and changed them.
Jan 14, 2009 | Honeywell Electronic Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
207 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
