Question about Singer 7442 Mechanical Sewing Machine
Black bobbin case
My black bobbin case came out of my machine while I was sewing. I tryed to put back in and broke back off. So I have replaced it. But I am unable to get it back in. And I don't want to break this one. HELP. I have spent many hours trying to get this one in.
  • 323 Answers
If this is the machine I think it is the bobbin case is completely round as opposed to half round. If it is half round ignore the following.
Remove the presser foot and then the two screws which hold the needle plate. Lift off the needle plate and then lift out the old bobbin case. Clean all the lint out and then insert the bobbin case so that the less round part of it is to the back and the lip around the bobbin case is resting on the lip around the hook. Turn the hand wheel a few times to be sure it is working smoothly and not binding. Replace the Needle plate , bobbin and presser foot. Insert a new needle,thread the machine, Check your tension to be sure it is working correctly, turn the hand wheel again to be sure it is picking up the thread without binding and sew.
sewman7
Posted on Jul 09, 2008
MY BOBBIN CASE HAS FALLEN APART AND I'M NOT SURE HOW TO PUT THE PIECES BACK TOGETHER.
Sounds like you are describing the hook. Perhaps the owner's manual would be assistance. We don't know the make/model of your machine so are really unable to help. There are some videos on YouTube that show how to install a shuttle and bobbin case, but machines differ.
Set up the shuttle race for RS2000 Series
Brother LS30 Inserting Bobbin Vertical Shuttle Hook
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
Mar 14, 2016 | Sewing Machines
The black plastic piece the bobbin fit in is broken.
You may have a timing problem or bent needle. You will need to replace the bobbin basket if it is damaged.
Jan 28, 2014 | Singer 7466 Mechanical Sewing Machine
I have a singer 7468. THE BOBB IN CASE KEEPS POPPING OUT. CAN THIS BE FIX?
the sewing machine may need a new bobbin case,, but I would
suggest take the sewing machine to a repair shop to see if there
is something wrong with the hook & hook race,,that may be why
the bobbin case is coming out.
Oct 06, 2012 | Singer 7468 Mechanical Sewing Machine
My kenmore is about 30yrs old .Never had a problem till now. I was sewing and stitched over a pin, broke needle,replaced needle. Now the problem is that the top thread bunches up underneath,also after i...
Sounds like the timing adjustment of the bobbin case has been upset. Have that checked, it involves an adjustment on the gear that drives the bobbin case.
Feb 22, 2011 | Kenmore Sewing Machines
How to you put back the bobbin case into the machine?
There is a black lever that holds in the case (look for it at around the 10-11 o'clock area on the circle where the bobbin case fits into. You need to use a screw driver (the one that came with the machine) and push and hold it back enough to wedge the bobbin case back in. the little black lever is spring loaded so it will go back to its normal position.
Jan 24, 2010 | Singer Inspiration 4210 Mechanical Sewing...
Want pick up my bobbin
re-thread the top thread
when putting in the bobbin, make sure you put it in right,
hold the bobbin between you thumb and first finger of your right hand when you pull the thread with left hand it should rotate the bobbin counter clockwise.
If you run your machine all day you need to clean under the bobbin case,
Take the cover plate off, take out the bobbin case and clean under, i take a q-tip with machine oil and rub around the inside of the metal case and around the bobbin case,
replace the plastic bobbin case making sure it's in right, turn the hand wheel by hand, the case should stay still and the inside will move, the needle should not hit anything
put all back together and try again
if the bobbin turns clockwise you are going to have problems
if this helps please rate it
thanks,
good luck
moni
May 09, 2009 | White Sewing White 4400 Computerized...
Broken plastic black peice sits down by bobbin (singer 81 on it)
This is an Apollo bobbin case and most sewing machine dealers will have them. Costs less than $20.
When you install it you will find a finger with a slot in it(located about 10'clock) that must be turned to the left to open it before the case will go back in.
sewman7
Mar 20, 2009 | Singer 3116 Simple
Bobbin Case
ok Sim this is a bit tricky but not to tricky first turn the handwheel toward you until the hook is at one o clock postion then slide the case without the bobbin in into the hook area you may have to work the handwheel back and forth alittle but it should slide in just remember that the case should ride in the rim. also take the needle out first that way you wont get stuck trust me it happiens.
Dec 19, 2008 | Brother CS-6000
Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Jun 20, 2008 | Sewing Machines
Bobbin case is moving out of place
I was having the same problem with my machine and finally the spring broke. I couldn't find any parts for this so my husband made me a new spring out of a coke can! LOL!! Anyway, he messed with it for a while and it kept doing it. He figured out that it was not the spring but the other piece under the spring was not pushed up far enough to keep the bobbin case in place so he took a screw driver and pushed it forward toward the bobbin case and now my bobbin case does not move!! And the machine is sewing perfect! At least for now. Anyway, it's not the spring or the thread adjusting screw!
Jun 06, 2008 | Brother CS6000i Computerized Sewing...
Singer 7442 Mechanical Sewing Machine Logo
133 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
