Question about Refrigerators
The fridge wont get cold, the inside light comes on
  • 425 Answers
First check on the thermostat setting of your ref, may be it is set to off or high temp setting or maybe it is on the defrost mode.
next, observe if the compressor is running, if not, then most probably you have trouble on the compressor.
if the compressor is working, then we may suspect a leak in the system and we need to rectify the leak and charge additional freon.
Posted on Dec 29, 2010
Fridge part working freezer not
The fridge is just the end of the freezer evaporator. If the freezer isn't cold inside, check the rear panel. It is probably frozen solid with no air getting through. Switch off, leave doors open for 24 hours and be prepared for lots of water to come out. Clean the condenser and make sure the fan inside is ok. Reset the thermostat to middle of the range and be sure to come back to tell us how you get on.
May 17, 2012 | Hotpoint Refrigerators
Thetford fridge wont work on mains power
start by putting the fridge in a cold place or if that don't work then turn the temp down inside the fridge
Dec 19, 2009 | Thetford Porta Potti
My fridge wont stay cold.
it is not frost free , there is no fan , this fridge for light office use , also make sure gasket is ok , good luck:)
Sep 12, 2009 | Haier (B000194UBA) Compact Refrigerator
Freezer cold, fridge part cold at first then warming
hi friend
it is fan problem check it....it may also be a thermostat not working proper,,check them both ,
thank u,,,,,,,,
May 03, 2009 | Estate TT18TKXKQ Top Freezer Refrigerator
Top of refrigerator wont stay cold
The light should go off when you close the door. The fanmotor does not operate if the door is open. If it is a frost free unit, it is possible that your defrost system is not working and therefore building up ice in the freezer section and preventing the circulation of cold air to the fridge part.
Mar 08, 2009 | Refrigerators
Kenmore coldspot
hi thanks for the question i would check the cold control what is happening is that the fridge gets cold enough but because of this bad control it wont send power to the rest of the fridge replace cold control thanks the appliance doc
Sep 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The power works and the interior lights work but it wont get cold. It's a DEC fridge and it's about 2 years old
Hi Boatgc,
You say, the power works and the interior lights work but it wont get cold. It's a DEC fridge and it's about 2 years old.
Is the freezer also not cold?
If the fridge is not cold and the freexer is!!!
There are a couple things to sheck.
Let me know!
Huuum
Sep 21, 2008 | Refrigerators
GE side by side Refrigerator approx. 8 years old. Fridge side barely cold.
With your fridge, does the light go out when you shut the refrigerator door?
That could be your issue, that light running inside will create Alot of heat.
Also check to see if there is air circulating from the freezer to the fridge side through the damper. The damper is on the Fridge side left wall up towards the top. That is where the cold air gets to the fridge side. If that damper doesn't open that will also cause your problem, Let me know how you make out.
Bill
May 14, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
