The last time I used my scotch TL901 thermal laminator, the page I was laminating got stuck in the machine and some of the laminating paper melted onto the inside rollers. After 30 minutes, I was able to get the screws out and get the top cover off so that I could see the rollers. I need to know if and how there is a way to get the melted pieces off or to clean the rollers so that I can laminate again w/o another sheet getting stuck and melting. I can't find the manual as this product was purchased before I took over this dept at work. Any help would be appreciated. Thanks! --Erica BHM, AL.
    New Friend:
I found manual on amazon, so take a look there: Amazon com thermador manual I hope this was helpful. cheers
Posted on Nov 30, 2014
There are two screws on the bottom which are visible. Leave them alone. The four screws that hold the bottom on are UNDER the rubber feet. Gently lift one edge of the rubber feet and then carefully peel them off. You will need a long thin Phillips screw driver to remove the four screws, UNPLUG the unit before opening it.
In most cases the plastic will be wrapped around the orange/red colored roller. This roller cannot be turned unless you push the "Release" lever. Using a tweezers, try to grasp a corner of the end of the rolled up plastic. Pull firmly and steadily on the corner until you have enough free to grasp with a needle nose pliers or a forceps, Then work your way across the entire end of the plastic sheet until its free. Finally, reposition the pliers or forceps toward the middle of the freed end and firmly pull to unroll completely.
Remember, you must be pushing on the "Release" while doing this or the roller will not turn. When you start, you may have to move the roller to get it to a position where you can try to grab an end corner of the plastic sheet. You should be able to do this if you a pushing on the Release lever.
Finally, if you have left the rolled up plastic sheets on the roller so long the are fused into one mass, my directions my not work. In that case, try slitting the entire length of the rolled up plastic with something like an xacto knife, BUT DON'T **** THE RUBBER ROLLER. That's tricky, but at this point you have nothing to lose.
Took me 20 minutes to figure out how to open the unit. Ten minutes to take out the wrapped up plastic sheets
Posted on Mar 14, 2011
  • tsfhome May 29, 2013
    I accidentally put the wrong end in first and the paper wrapped around the rollers. I followed your instructions and got the paper off and put the machine back together and now it works fine. Thank you so much!!!
  • Elaine Willingham
    Elaine Willingham Jun 08, 2014
    I got the whole thing apart but the laminator sheet was stuck so badly to that roller that there was no way it would budge. It's my own fault. I was in a hurry and didn't use the protector and I had to trash my laminator. Hope I can find one for $16.99 like I heard some man say on You Tube. I actually got this one with credit card points. Godd luck and conrats if this worked for you.
Thanks this helped a lot
Posted on Dec 26, 2012
I jammed the laminating machine, so I unscrewed and opened the machine...but now I don't know how to roll out the paper? Please help me find a way to take this out without breaking the machine!
Carefully try to turn the roller one direction and then the next. If they move, you will see the feed direction the paper loaded from. Carefully move the rollers in the opposite direction letting the paper unwind. Do not force the gears. Hopefully the paper is not fused to the rollers.
Mar 03, 2015 | Scotch 9" Tl901 Hot Laminating Machine /...
Scotch Thermal Laminator not heating up.
well it sounds like you may have cut a wire or pull one somewhere. i would go ahead and take it apart carefully and check everything. may have unplugged something hopfully! let me know whwat happens!
Jan 31, 2014 | 3M TL902VP Scotch 9" Thermal Laminator...
What is the difference between cold and hot laminators?
Hot laminators are the most common types of laminators. They use heat (220 to 300 degrees F) to apply the lamination. Hot laminators provide a better quality lamination that is more resistant to wear and tear. This is the preferred method of lamination for materials that are not effected by heat.
Cold laminators use pressure sensitive adhesives to bind the lamination film when the material being laminated is sensitive to heat. Certain inks in standard ink jet printers are known to have the ink melt in the machine. There are other types of printers that use heat sensitive paper. For these types of applications the cold laminator is the best choice.
Jan 28, 2013 | Office Equipment & Supplies
DO YOU HAVE A MANUAL
I do not have a manual for that laminating machine. Over the years I have used a number of different units, and dismantled a few as well.
Essentially to use it, you let it warm up, and if you are pulling the laminate off a single roll, it should be folded over on itself, you roll an edge to see which side opens and slide in the item you want laminated.
The one thing that may be a source of bubbles in the finished product is you need to lightly roll a perforator over the item to pierce the laminating plastic so air can escape. Also make sure to have about 2 inches of extra palstic at each end for consistent results.
Feed it in straight, that 2 inches will allow you only a little room for adjustment- if at all possible, just feed it in, supporting the document so it does not flop over, and once it is feeding, you can see it come out.
Because it is nothing more than a heating element, and in the case of the smaller types, it is just a long halogen light bulb for the heater. It will always smell hot when in operation, because it is, and small amounts of plastic do peel off from time to time. So it is susceptable to damage if jarred while heating or in operation, and the tube can break if the laminator hits the floor.
To clean rollers of the laminator, normally they have a cleaning sheet, but not always, and if you do not have one, you can improvise by taking a section of craft paper bag, fod it over and trim to width of the laminating material. Feed it through and once it feeds, with gentle resistance held against the paper, this will help clean the rollers. Once through, open and refold so the inside is now outside and feed it through again with same procedure. Repeat with a new sheet until it feeds through clean.
If unit does not heat, check fuse if it does not turn on at , no motor, no light; and It may be an internal fuse on a circuit board. There is also a thermal fuse in the heater circuit as well- these can fail if the unit is left on all the time and not used. They should be powered down between uses. The exception is the industrial sized laminators used by many of the office supply stores as they take a while to heat. Otherwise the lamp is the chief suspect for no heat. If you plan to service it at hone, or to at least check the condition of the ttube, with an Ohm meter, you should be able to measure across the filament. It should be less than 20 Ohms resistance. Finding a replacement halogen is not cheap, and it may just be more cost effective to replace unit than try repair it if you are in an office type setting. It also requires you wear cotton gloves so not to leave any trace of oil or contaminant on the glass as they will fail at that point if there is any oil or other residue.left on tube when it lights up.
Jan 10, 2012 | Scotch 9" Tl901 Hot Laminating Machine /...
My new TL901 just stopped working. A few days ago when I first got it I lminated a piece of paper to try it. Then today went and turned it on to laminate again and it just shut off? what can I do
It is probable the heating element burned out. The heating element is just a long tubulat incandescent lamp.
You could try returning it to the store and exchanging it for another one. Otherwise in the documentation there is a contact information page, probably the phone number would be the best, and work with them that way should you get any issues from the store.
Dec 22, 2011 | Scotch 9" Tl901 Hot Laminating Machine /...
Some one at work tried to laminate a card. when it did not come out she put in another sleeve thinking it would push the other out. smart uh! how do we get the 2 pages out?
If you were using GBC brand laminating pouches they don't need a carrier, if you were using another brand of laminating pouches, then a carrier is needed (something they don't clearly specify) and that's why the laminating pouch got stuck.
If you have had the laminator under a year, it should be under warranty, and you can call the company, and they will send a replacement, and they will probably then inform you of the above listed laminating pouch issue.
You may also want to try using the reverse button, but many times the pouches will get stuck between several rollers, and you risk destruction of the entire machine by attempting to take them out manually.
May 31, 2011 | Gbc HeatSeal H425 Laminator
SCOTCH TL901 MANUAL
I have a scotch tl901. The laminating sleeve went into the machine and must have rolled around the roller inside. Is there a way to get it out? Is there a way to open the machine? I must have put the sleeve in open side first.
Oct 03, 2010 | Office Equipment & Supplies
I have a scotch brand laminator tl901- it is jammed...and making a clicking noise...is there a way to open the system and try to unjam it?
First, make sure that the unit is unplugged and has sufficient time to cool off. Then remove six screws on the bottom of the laminator. The screw driver shaft must be thin enough to fit into the holes where the screws are located. Two are very easy to find -- one on each side in deep holes. The other four are hidden under small black rubber disks that the laminator rests on. peel up the rubber disks and remove the rest of the screws. At this point it is easy to remove the cover and remove the jam. To replace the cover you must use a thin tool to pull back the release level so it will fit into its opening in the cover. Replace the six screws and you should be able to ready to laminate again.
Jul 10, 2010 | Office Equipment & Supplies
5,485 people viewed this question
k24674
jasbo
jasbo
