Need to replace the two convergence IC's in my 65" mitsubishi DLP. Other than unplugging it, any other safety measures I need to take such as discharging the CRT's, etc.?
    Sergeant:
    Champion:
  • 250 Answers
As long as you don't touch anything like the crts, the flyback transformer etc you are fine to unsolder the ic's and replace them. No high voltage current is in that area. Just be smart and take your time and always watch where you are putting your hands and your tools. Also, do not wear rings, or watches while working in the tv. IC's are a very easy removal and if you simply stay away from the high voltage components you'll be fine.
Posted on Jul 07, 2008
My 65 in mitsubishi medallion hdtv 1080 wont turn
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Jun 07, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Convergence is off... factory reset does not reset..... red--blue will not adjust as instructions show....
the convergence ic wnet out , it need to be replace , i would recoment to take to a repair shop because after they replace this ic they may need todo aligment , call around repair cost about $250 - 350
Aug 25, 2010 | Mitsubishi WS-65712 65" Rear Projection...
The colors are blurry and will not converge
This model uses a Single convergence IC---a STK-393-110.
If convergence is skewed and will not adjust the chip needs to be replaced.
Most shops get 300 or more for this repair---you can buy the IC on Ebay for about 12 dollars--total parts cost should be under 30 dollars.
I have Start to finish, step by step instructions for this repair in this set--they tell you everything you will need and how to do the repair.
Let me know if you have questions or want the instructions.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 19, 2009 | Mitsubishi WS-65809 65" Rear Projection...
What is the best IC replacement for original IC part# STK393-110?
Sayo makes the best IC's, don't just settle for the cheap ones. I have see this ic for as low as $5.00 on the internet.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can try http://www.tvrepairkits.com/ they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
Oct 13, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi 1080 hd ws-65809 wont power up
This issue is almost always caused by a faulty Convergence IC inside your TV. These chips heat up and can become damaged over time. The most common cause I have seen for the picture distortion is the heat of the Convergence IC weakening the solder connection to the TV circuit board. If you look on various messages board you will see people rigging wooden dowels and other items to apply pressure to the chips in order to correct their picture issue. This works because when the solder joint is weakened the chip becomes loose and vibrations or pressure will cause it to work or not work correctly. Aside from all that information the correct fix is to have the IC chips replaces on your TV.
The solutions for this issue are as follows:
1. located a tv repair shop that will replace the parts for you. I had the same issue with my 65" Tv and the quote was $350 for the labor and parts.
2. You can ordered the IC replacements yourself online by going to google and looking up a reseller of the STK392-110 Convergence IC that is inside your model TV. You will need 2 of them and they cost around $6 each. If you have the soldering skills to remove the old chips and install the new ones this is by far the most cost effective route. It is a fairly simple process and guides can be found online.
Mar 17, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Our TV (Mitsubishi WS65711) is 6 years old, and has recently started showing a blue ghost image on everything. It stopped for a while for a week or two, but started back up, and has continued ever since. I...
You have convergence problem in your tv as your local repair shop told you. You need to replace convergence IC . YOu can get from the link below .
Convergence IC can be obtained from the link
You need to replace both convergence ICs .It will cost you around $30
If you can replace it by yourself . If you take to repair shop they will charge you around $200 for this job. .
The IC number is STK393-110 .
You can get some idea on how to replace convergence IC from the link below
http://www.fixya.com/support/r704766-convergence_solutions
Hope this helps .
Feb 19, 2009 | Mitsubishi WS-65511 65" Rear Projection...
CONVERGENCE WILL NOT PROPERLY CONVERGED
you only need one STK393-110 Convergence IC and two 5Amp pico fuses. You can get the IC and the two fuses for less than 35.00 at the following link and they provide free installation instructions with pictures so you can easially do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Jan 19, 2009 | Mitsubishi WS-65712 65" Rear Projection...
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red and Green
check video IC or tv convergence sometimes yoke
Aug 12, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
