How do i set the color on the tv - Televison & Video
  • 10,421 Answers
Just go setting menu of your TV, then choose the picture the color sub menu. You should also find there the contrast, sharpness etc.
Regards
Posted on Dec 29, 2010
My philips dvp3560 will only playback in black and white
Check the TV System menu:
[TV System]
Change this setting if the video does not appear
correctly. By default, this setting matches the most
common setting for TVs in your country.
• [PAL] - For a PAL-system TV. (European TVs)
• [Multi] - For TV that is compatible with both
PAL and NTSC.
• [NTSC] - For an NTSC-system TV. (American TVs)
Also try:
[Picture Setting]
Select a predefined set of picture color settings or
customize the personal setting.
• [Standard] - Original color setting.
• [Bright] - Vibrant color setting.
• [Soft] - Warm color setting.
• [Personal] - Customize the color setting. Set
the level of brightness, contrast, tint and color
saturation, then press OK
Mar 05, 2011 | Philips DVP3560 DVD Player
What are the menu settings supposed to be at for the color, picture, what do I do if the color is not right, pickish and green
Go to tv menu go to screen setting turn screen contrast to the max and screen brightness half midway point like 55.Tv real old like around ten years?Watches alots daily like 6 or 7 hrs a day?The tv CRT-(tv tube) might be to old,the radiation colors guns R,G,B insisde might not work as well as before.Have a reset setting in the colors setting?Go down to that press that,to restting for the factory colors setting.Or tries add more blue,a bit less green and red,see how that turn out?
Feb 05, 2011 | Panasonic CT-32G23 32" TV
What is the perfect calibration for this television.
Go into the tv menu setting,at the picture setting go down to reset it back for the factory setting.Now,go to the color setting turn the colors setting down anothter 20 precentage for reductiion of colors.The picture should great now,because this is factory setting,but it just a bit to much colors on the screen pictures.
Dec 15, 2010 | LG 32LE5400 32 in LCD TV
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
Its glittery white because i briten the color but when darken it gets green
you must re-adjust in the RGB (Red-Green-Blue) setting. depending on the brand of your TV, because there are set manually from the TV (you must open the cover of the rear of the TV). and there is a set directly from the remote only, with the open "factory settings", then you can re-adjust RGB color, especially green, not too dominant with the other colors (RED-BLUE). how to set is that you need to neutralize the color, (color TV sets to zero level) so that the image becomes black and white. if the green is too dominant, then Decrease the level of Green Bias or Green Cut off/ G-drive.
Aug 05, 2010 | Televison & Video
Vo370M no color on dvd color on tv godd but only
Please change the display settings on DVD, the settings is not NTSC only set PAL then color Display will apear
Jan 28, 2010 | Televison & Video
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Sep 10, 2009 | RCA 32F531T 32" TV
Toshiba 36AF41 36" TV no red color
Go to your menu/settings from the remote (or buttons on the tv, if applicable). And find the color or saturation settings, play around with those. If that doesn't work, your tv is dead, get a new one.
Mar 07, 2009 | Toshiba 36AF41 36" TV
Color setting
MOST likely, use remote [maybe set] for <menu[setup]> <video>. This is normally where <brightness><contrast><color> and so forth live.
Jul 27, 2008 | Philips Magnavox 20MT133S 20" TV
Samsung DLP HL-R5667W
Your set has a defective color wheel. This is the noise you hear and why the set wont even come on now. The colors were bleeding because the color wheel was getting stuck and when you hit the set you unstuck it. You need to call a tech to put in a color wheel the part is about 100 dollars plus labor.
Feb 05, 2008 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
