Question about Admiral AW22 Top Load Washer
Admiral Washer not spinning
Sir,
Seems like you have helped a lot of people with success. I have Admiral lg capacity, 22 lb, washer that is Not draining the water and is not spinning. It was fine until I activated the extra rinse cycle. Now when I turn it on, there is just a humming sound and no action. I guess it is stuck somewhere in the cycle.
Secondly, I can move the agitator freelly counter clockwise. When the machine is turned on however, it moves clockwise, gets stuck and the hums. It requires quite a bit of force to disengage and to free it up to move anticlockwise again.
Model # on this one is LNC6761A71. Although it does not say AW22 anywhere, tis is the only choice I am given here. It says designer series, giant capacity. It is a top load and does NOT have a belt driven system.Thanks in advance.
  • 1 more comment
  • Anonymous Sep 18, 2008
    I have the same problem... is it worth trying to fix or should I just replace?
  • dmckray Oct 19, 2008
    I have the same Admiral model LNC6764A71, top load, large capacity washer.
    I am experiencing problems with the spin cycle, too..the water drains, but the clothes are still too wet. I checked various cycles...the agitator works, water fills and drains. But during the spin cycle, though something is spinning (sounds as if working normally)...it's not the inner tub (which contains the clothing) spinning. The belt looks to be in good condition, as well.
    How do I check for correct belt tension or whether inner tub is connected correctly?
  • Anonymous Oct 26, 2008
    Yes I have the same problem - none of the spin cycles work and water remains in the tub.
    Problem Solver:
  • 10 Answers
Broken or slipping drive belt, ( motor) to spin pulley , losse pulley, defitive drive clutch, spin brake fails to release, or transmission is frozzen
Posted on Oct 08, 2008
I have an Admiral 20 lb. capacity heavy duty washer, not sure what model. Machine fills up with water but does nothing aftet that, all controlls seem to work fine. Before this issue it would rinse and in...
There should be a module that does the agitation bit for the washer motor(Spins one way shuts off and reverses the spin etc) There may be a capacitor under the control panel that is not working any more so the motor will not start.
Jun 04, 2013 | Washing Machines
What is the machines capacity
9.97 KG, (22 lbs) is the capacity
Feb 04, 2011 | Admiral AW22 Top Load Washer
Won't agitate
Ours did this and it was because the bearings had busted. I called a local repair guy and he told me over the phone just by listening to the sound. Maybe you could do the same. I do know this, if it is your bearings, buy a new washer. It's not worth the repair...trust me.
Jul 24, 2008 | Admiral AW22 Top Load Washer
Admiral Designer Series Super Capacity Washing Machine
This machine will rotate the motor to agitate in one direction and then reverse to activate the pump and the clutch for spin. I would remove the inspection plate and watch the motor and pump in action in both wash and spin, go to www.apdepot.com and dig around you will find parts and a wire schematic on this machine.
Jul 23, 2008 | Admiral AAV7000A
My admiral super capacity washing machine
remove the front panel and check the securing springs at the bottom, probably one has snapped, replace the set.
Check for dust - evidence that the snubber washer has worn also
Jun 02, 2008 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
639 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
