Question about Toys
Cant stop seat moving on green machine 20x and the bolt wont go any tighter
I added a 2x4 between the seat bars and the cross brace, then used a long screw, fender washer, lock nut to secure the lower plastic and seat together. It was a terrible design to clamp two plastic items between a smooth metal bar in the first place, then on top of this to use a nut that is molded into the plastic and stretches out of the plastic with each stroke of the pedal.
Posted on Jun 12, 2012
Seat won't move forward, cant get to the rear bolts to remove seat because seat is back as far as it can go is there any way to move the seat manually
You must remove the seat from the power seat transmission then remove the drive motor from the seat transmission, move the seat to the desired position and reinstall the motor to lock it in place. The seat transmission is bolted to the seat mounting bracket/rails.
Feb 01, 2017 | Seat Cars & Trucks
1997 Jaguar XK8 Cant move seat forward to get to bolts
found you are not the only owner with this problem
Seat removal frustration Jaguar Forums Jaguar Enthusiasts Forum
from this diagram
I cant see any way of dis- engaging the motors
to get movement on the rail
Nov 10, 2016 | Jaguar Cars & Trucks
We have a maxi cosi car seat. The seat belt has suddenly stopped from being able to be extended. It is too tight for my son and we cant seem to be able to make the belt any looser. It can be made tighter,...
Good Evening
Sorry to hear about this inconveniance. Please contact your retailer with your proof of purchase and discuss with them having your carseat repaired.
Jan 15, 2011 | Maxi-Cosi 22476PNG Convertible Car Seat
I need to cahnge the power seat track on a 99 town car. Mine will not go front or back. I need to remove a replacement from a pick and pull. I can get to three nuts but cant get to the one iin the rear...
The seat track you need will have to either need power or be aligned so you can reach its' mounting bolts too. You will be able to see how the gear drive is attached on the replacement seat track. You may be able to unbolt the gear drive from the track on your damaged part. Then the seat should slide either way without the drive gears stopping you from moving the seat. Sometimes there is only room for a air ratchet to fit as the bolt can spin without having to move the ratchet handle.
Oct 01, 2017 | 1999 Lincoln Town Car
Seat belt locked wont pull out
Check if the roll is in the right position,untight the bolt and move it back and forvard a little and pull the belt gently at the same time,if you are lucky it might come loose.
Jul 25, 2009 | 2005 Jeep Grand Cherokee
Power seat still wont move
uys what I found on mine was under the fuse box panel, Ford did a factory splice.Orange w green stripe wire or vice versa been a while, that splice turned green and coroded inside.All i had to do was replace that splice with my own and all three worked again.Quite an easy fix.Good luck.
Apparently you are not the only one with this problem!
Dec 21, 2008 | 2005 Ford F-150
Toys Logo
234 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
