Question about HP Laserjet M2727nf Multifunction Printer
Received fax only prints top half of page - HP Laserjet M2727nf Multifunction Printer
  • thedialyzer Dec 29, 2010
    The suggestion to set paper size correctly solution is not correct. The first page of a multi-page fax prints the full page then all following pages only print the first half of the page.
    I powered the device off/on and this appears to have corrected the malfunction.
  • 77 Answers
Make sure the paper size is set correctly.......
Posted on Dec 29, 2010
I get plain paper or double when I received fax from my uf5300 laser fax.it print one page from 5 pages that sent and I got empty pages and double somtimes
Paper feed rollers and sheet feed pad dirty. Feed roller on top pad should be just below. Clean with alcohol. Papers have clay in them. Recycled is worst. It will glaze the pick up roller and pad.
Sep 21, 2014 | Panasonic PanaFax UF-8000 Laser Fax
I would like to have the device print a Fax Confirmation for all fax sent and received. HP Officejet J4680 All-In-One
Follow the steps below to enable the Fax confirmation on Sent and recieved.
On the printer :
  1. Press Setup (c01461502.gif ).
  2. Press the right arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  3. Press the right arrow button (c01185072.jpg ) to select one of the following options:
    • On Fax Send: Print a confirmation page every time you send a fax.
    • On Fax Receive: Print a confirmation page every time you receive a fax.
    • Send & Receive: Print a confirmation page every time you send or receive a fax.
  4. Press OK .
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 24, 2010 | HP J4680 Office Jet All-In-One Printer
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Blank print top 1 inch has print Toner cartidge has been changed
I need more information. If you make 20 copies do you still notice the problem or only when you receive a fax. What is your copy count (press life 1). Does it jam or make noises. At first glance I would say phone line problem. .
May 26, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sharp Inkjet UX A 1000
I had the same problem and, like you, went to the internet to find a solution. One answer I found was to unplug the vax, wait one minute and then replug it. This didn't solve the problem for me. Out of desperation, I printed the fax "Help" pagea nd, lo and behold, after it printed my Sharp 510 Fax was back to normal.
Nov 04, 2008 | Sharp INKJET FAX UX-A1000
Receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Problem with printing...
First and most important with Brother machines is , you need to use genuine brother supplies. Almost every time I service a brother and I find generic toner and drums cause the print quality issues. New supplies cost as much as a new machine. If not the supplies then it is laser or power supply.
Aug 06, 2007 | Brother IntelliFAX 2800 Laser Fax
HP Laserjet M2727nf Multifunction Printer Logo
219 people viewed this question
Seeker5211
Seeker5211
