Question about Philips DVP3982 DVD Player
Showing black an white when put in move - Philips DVP3982 DVD Player
  • 37 Answers
There must be a problem in the connection of the dvd player to the TV. Make sure that ALL the pins (or SCART) are connected the right way. If you're using a SCART (a.k.a EXT), it might be defective too. Try to move the SCART back and fro as SCARTS are a bit 'fragile'.
Posted on Dec 29, 2010
My TV is only showing in black in white.
If on both DVD and TV (unit here is indicated as a combo unit) it is a circuit problem in the set and may require the main board in the set being replaced--good luck with this brand for this issue.
Jun 12, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
I am trying to get the Mephisto, Master, to move as white first. I have set the operation mode at +top but it still opens up game playing computor as black
My name is Paul and I can answer your question about making the Mephisto Master Chess computer play the white pieces.
1. Set up the pieces so that you are playing black or have black pieces closest to you.
2. Push the option button and push your finger or a chess piece down on square G1 making sure that you have a symbol with the appearance of a cross to the left of the word top.
3. Push the clear button once and you will recognize that the display is showing that white has the turn.
4. push the enter button one time to force white to show its first move. Now what you see in the display will not be correct but stand up and look at the display lights horizontal and veritcal and you will see that they indicate the correct piece to be moved but the alphabetical and numerical information on the LCD or the display will not match.
Follow the display lights and look the the piece symbol and you will see what I am talking about.
I haven't figured out how to make the computer show the correct information yet but when I do I will let you know immediately.
Have fun
Jul 17, 2011 | Mephisto Master Chess Computer
I am trying to connect my new pool motor. I have 3 wires coming out of the box. a black one 120v a white one 120v and a copper (ground). How do I test if it has 240v? How can I connect the motor so works....
Most probable cause is that you have the black and white on the same phase, and that's why you have 120 volts from black to ground and from white to ground, but 0 across black and white. If the motor ran on 120 volts, why are you connecting it to 240?
In any event, in order to get 240 volts, move the white to a circuit breaker that is directly above or below the breaker that feed the black wire. You are supposed to use a 2 pole breaker for 240 volts anyway
Jul 23, 2009 | Pool & Spa
Show movies in black and white no color
unit is in a progresive mode. need to turn back to interlaced.
Jun 01, 2009 | Sony DVP-NS575P DVD Player
Only black and white picture on screen when showing DVD
its a PALSECAM mode. change mode to NTSC! that y black & white picture. click button PAL/NTSC.
May 25, 2009 | Sony Dream System DAVDX155 Theater System
0 and - keys fell out!!!!
hey
This could be a little difficult to explain.. coz the white ring acts as a spring and putting it back on is not hard but difficult to explain.
See first of all on an acer laptop a key has 3 components
the key
the white thing (which holds the key in place)
and a black soft thingy (which actually gets pressed wen u press a button and acts like a spring)
first of all the white ring can be removed and refixed easily .
Youll see 4 small hook like structures on the palce where key needs to be placed ... first place the white ring over there, the white ring has 2 things which come into one another. (try referring to the key where in the white ring is still in place).
now if the black spring like thingy is removed from its place, place it in the center of the ring and put the key on, try moving the key a little, if the key and white ring are put correctly, this will produce a click like sound showing the key is locked by the white ring .. if the white ring is dismantled into 2 parts it could be a little tricky to put them back on.. in that case i guess ull have to check a fixed ring and try and replicate the same for this key
for further assistance feel free to mail me on:
kushalagarwal22@gmail.com
Cheers
Kushal
Aug 27, 2008 | Acer NSK8458AN Keyboard
Ceiling fans..
Are you talking about the receiver? If so connect wires from fan, White, black,blue to receiver white, black, blue. White to white and so on. Then connect the two wires from other side of receiver, white and black(or Red) to corresponding colors from ceiling. Then store receiver just above the ball in the ceiling mount plate, you will have to move the wires to the side and push it in. Hope this helps
Aug 16, 2008 | Dryers
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Black and white picture on the JVC TH-505
If you hold the VFP button while a movie is on, you will get a small box on the corner that shows your color. My default color also turned black and white. I just moved over to a user1 color setting (push the right arrow on your remote), and it allows to the change the colors. You might be able to put the colors to come out through here. Hope this helps.
Jan 28, 2007 | JVC TH-M505 System
Philips DVP3982 DVD Player Logo
19 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
