Question about Kenmore Kitchen Ranges
I have a Gas stove Model #911.7359180 Kenmore with a code F-1 I've hit clear but it still keeps beeping?
  • 172 Answers
SOURCE: f3 code kenmore model# 911-4552090
Hi pickerrauto7,
The f-3 code code indicates a bad or open temperature sensor in the oven. It is the little metal rod in the top of the oven about the size of a pencil.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
You will have to remove the back panel of the range to correct the problem. The temp probe is held into place with two 1/4 inch screws. If the connections are good then the probe is bad. Good luck to you on your repair. I am sure this will FixYa. Please dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 30, 2008
huuum
  • 750 Answers
SOURCE: stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Posted on Jan 31, 2009
Maytag317
  • 1136 Answers
SOURCE: F-1 code keeps comming up on my Kenmore Gas Range
The information I found today says to replace the keypad or the clock assembly. The ket pad is around $60.00 and the clock I can sell for $245.00. This will give an idea on cost.
Posted on May 13, 2009
  • 13 Answers
SOURCE: Kenmore oven control beeps and shows F1
According to Kenmore's list of error codes, F1 means EOC (Electronic Oven Control) failure, and the solution is to replace the EOC. You might look into that. The part itself costs around $80, as far as I can see.
Posted on Aug 24, 2009
  • 969 Answers
SOURCE: My kenmore gas stove oven door will not open and
http://www.applianceaid.com/fault_codes.html
Posted on Nov 12, 2009
Kenmore Gas Stove model 911.3652191
If you can't get the part you are sunk here, sorry,. I do suggest you go on line and try all the parts sources you can find, get the part number and type it in the search window and see what shows up, if you don't have the part number of the panel then call the repair service and ask for it.
Sep 04, 2012 | Kenmore Kitchen Ranges
I have a 19 year od kenmore electric stove and it keeps beeping F1. I can hit cancel and it will be od for alittle while then goes back to beeping. Any ideas?
You have either a bad ERC (clock) or a bad touch pad.
Disconnect power to stove
Gain access to the back of the clock (electronic range control or ERC).
Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
Make sure everything is clear and will not short out when power is turned back on.
Turn power back on to stove.
Watch for the F1 and listen for the beep.
If you get the F1 and beep, replace the ERC.
If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
May 22, 2011 | Kenmore Kitchen Ranges
Getting beeps and f1 error code after canceling cleaning mode a little early.
Hi dear.According to your explanation,Getting beeps & F1 code meaning: F1
Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced.
Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC
I hope that helps.Thanks.
Sep 03, 2010 | Maytag MER5775Q Electric Kitchen Range
I can't find my model number on my Sears Kenmore Gas stove. Several times now the stove has beeped then kicked out with EO and F2 showing in the clock area. The stove was bought in 2000 or 1999. Can you...
The tag with the model number is usually located on the rail that is visible with the lower drawer open.
The code you are getting is an indication that the oven got too hot or the control thinks the oven got too hot. It is usually do to one of two parts that have failed.
If the oven did not get too hot and you got the failure code, then the sensor would be bad.
If the oven did get too hot then the ERC (electronic range control) is bad.
May 17, 2010 | Kenmore 75012 / 75014 Gas Kitchen Range
Oven heats up and keeps heating up doesn't stop.
there is a shut down switch it this stove it is not working. stop using it and save your life or home,..
Sep 21, 2009 | Kitchen Ranges
Aug 24, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Electric panel on stove displays
check the sears kenmore site they have info on error codes.
Aug 22, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
CODE F90
I have the same problem. my model number is Kenmore 970-556322. the whole stove is not working.
Oven door is not locked but got the message "door locked" on the control panel and won't allow reset via clear/off. and it shows F11 and F90 on the display, and the machine keep on beeping the whole day, tried to unplug and restart it next day, but didn't work.
Please help!
Jan 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore drop in range code F7
Oven control beeps and Electronic control as detected fault condition.
Press CLEAR to clear the display and stop displaysF1,F3, F7 ,or F9 beeping.
Program oven again.If fault recurs,record fault number.
Press CLEAR and contact your Sears authorized qualified service agency.
Oct 17, 2008 | Kenmore Kitchen Ranges
Kitchen Ranges Logo
52 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
