Question about Bontempi Speak and Play Computer Organ
The wiring to the jack was pulled out of the bottom of the microphone for the Bontempi Speak and Play Computer Organ. I'm trying to reconnect the two wires (one red, one green) to the switch inside the microphone. I tried connecting one wire to each the two screw/post that secure the switch inside the microphone. That didn't work. Do you have any schematics or diagrams of how I should reconnect the wires?
  • mpalm97557 Dec 29, 2010
    I'll get a soldering kit and try it. Thanks.
  • 22,156 Answers
No the wires are soldered on to two connections under the switch ,but if its been pulled out it may have pulled the connection out with the cable ??
Posted on Dec 29, 2010
I believe organ hasn't been played or even turned on in over 10 years. The top keyboard plays if I turn on a setting such as piano or trumpet however I can't just get the organ keys to play.
Since the organ has not been used for a long time, I suspect that there can be degradation of the electronics, specially with electrolytic capacitors. hence I request you to switch on the Organ continuously and allow it to warm up, it there is improvement , then it will be worth to remove the bottom panel and clean up the boards,dry the PCB with a hair dryer and reconnect the boards.
Hope this will help.
Jan 23, 2016 | Music
How do i fix my iPhone so the receiver can here me when i talk
1.Unplug anything plugged into the headset jack.
2.If you're on a call and holding your phone next to your ear, speak into the microphone and make sure you don't block it with your fingers or shoulder.
3.If you're using a screen protector or case that covers the microphone, remove it. Clear any debris from the microphones.
4.Restart your device.
5.Update to the latest version of iOS.
Test the microphone
To find out if there is an issue with the microphone itself-and not the app you're using or your cellular connection-test the microphone with the built-in Voice Memos app. Speak into the microphone and then play back the recording. You should be able to hear your voice clearly.
*If you can't hear your own voice the microphone is not working properly, you should replace the piece of hardware.
Jan 27, 2015 | Apple iPhone 4 Black Smartphone
Mixer will only play through one speaker; this is same with organ, microphone and ipod connected. Swopping jacks results in speakers swopping proving that woring is good, but mixer will not play both...
Sounds to me like either an open wire or a blown speaker. I would highly recommend not operating it until it is fixed before you blow the amp. Tapping a 9V battery across the speaker (disconnected from amp) will cause a noise in the speaker, if not it is a broken wire or bad speaker. Good Luck
Jun 06, 2013 | Behringer XENYX X1832 USB Mixer
My microphone not working
Dear,
Hardware troubleshooting Depending on whether you are using an internal or an external microphone, follow the steps below to see if the problem is with the hardware.Show all ' Hide allcollapse_individual_default.pngTest the internal microphoneThe internal microphone is located near the top of the notebook LCD display or near the bottom of the LCD display near the hinge. Use the following best practices to capture sound more easily.
  1. Adjust the notebook screen to place the microphone in the best direction for receiving sound.
  2. Click Start , enter sound in the search field and select Sound Recorder from the list.
  3. Click Record and speak into the microphone. Save the file to an easily-accessible location, such as the desktop.
  4. To play back the recorded sound, open the file using Windows Media Player.
  5. When using the internal microphone, choose an environment without background noise.
  6. If the recorded sound does not play back, continue to the next section of this document.
collapse_individual_default.pngTest the external microphoneVerify that the microphone port and the microphone are working properly.
  1. Test the microphone on a known, working portable tape recorder, another computer, or a device that accepts the microphone connector.
  5. If the recorded sound does not play back, continue to the next section of this document.
  6. If the microphone successfully records the voice, test the record function on the computer. If the microphone does not work properly on another computer or on a tape recorder, try using a different microphone.
collapse_individual_default.pngSet the default microphoneIf the external microphone is set as the default recording device, uninstall and reinstall the audio driver to change the default recording device to the internal microphone. The internal microphone should be the default recording device.To change the default recording device:
  1. Click Start , enter device into the search field, and then select Device Manager from the list.
  2. Expand the Sound, video and game controllers list.
  3. Right-click the audio driver , select Uninstall from the drop-down menu, and then click OK to confirm that you want to uninstall the audio driver.
  4. After the audio driver is uninstalled, click Start , enter backup into the search field, and then select HP Backup and Recovery Manager from the list.
  5. Follow the on-screen instructions to reinstall the audio driver.
The internal microphone is now set as the default recording device. Basic troubleshooting
The following are some basic troubleshooting tools that you can use to restore your microphone's functionality, depending on your operating system and/or software preferences. However, it is recommended that you first run the HP Support Assistant as it can scan your current system configuration to automatically determine if your notebook requires updated software and device drivers.
Mar 09, 2012 | HP Compaq d530 SFF PC Desktop
My head phone works very good but the microphone doesn't work
When you say headphones do you mean the music headphones, like speakers, because they go in the headphone jack in the computer while microphones go in the microphone jack. The microphone is normally a pink color and the headphone jack is normally green. If you already knew this try wiggling the microphone to see if there is a brake in the wire, if that dose not make it fissile in and out then its something wrong with the microphone its self and should be replaced
May 03, 2011 | Logitech (980240-0403) Microphone
Broken volume pedal on bontempi 24110008 organ.pedal wont stay in up position.
There MAY be a counterbalance spring that is missing or broken AND there HAS to be a friction device to hold the position. You should be able to remove the pedal assembly to analyze and repair it.
It may involve just tightening whatever is suppose to create the friction to hold the pedal.
Apr 24, 2010 | Music
How to play minor chords on Bontempi MS40?
easy:
- the lowest key gives the chord C for C major (do majeur)
- add a key on the right (up) for exemample D or E or (it doesn't a matter) gives you the minor chord.. (here Cm = do mineur)
- add a third one ( always on the right side) gives you the 7 here C7 (do septieme)
enjoy!
what a pity we can't easily disable this auto chord function in orfer to get real notes for the left hand!!!
Jan 22, 2010 | Bontempi Toys
I can hear music but I cant speak? I want too tak too family on line
You need to plug in a microphone to the microphone jack line in of your computer in order to to that.
Your computer doesn't have a built in microphone.
Jul 31, 2009 | Dell Dimension E310 PC Desktop
Wont record blank cassettes? Any ideas?
it probably does need a microphone. check for an input plug on it.
Jun 05, 2017 | Spectra Hello Kitty KT2028...
PROPER MICROPHONE FOR A CHURCH CHOIR
What you want is a directional microphone.More specific, probably a microphone with what is called a super-cardioid pattern...it only picks up what is directly in front of it. A couple of these may help. As far as filtering out the organ, this is difficult to do with just a microphone,..that is moe a job of a mixing engineer who runs a sound board, and even with the proper equipment, and knowledge, still isn't easy. best thing to do is have the organist turn down the volume a little, to get a well balanced mix between the vocalists and the organ...
Mar 11, 2009 | Audio Players & Recorders
Bontempi Speak and Play Computer Organ Logo
144 people viewed this question
Top Bontempi Toys Experts
ray gallant
Are you a Bontempi Toy Expert? Answer questions, earn points and help others
