Question about Freeplay Energy BayGen AM/FM/SW Radio
Original Freeplay windup radio.
Aerial broken and winder is noisy when winding down. I live in Surrey. Any idea where I can get my radio repaired and serviced?
  • Anonymous Mar 18, 2009
    Freeplay radio - model "ranger"
    charger not/stopped working
  • AlisonG Mar 24, 2009
    Broken antennae, and I am afraid to open the box!
Tony,
Can't help you with the aerial. Mine made the same noise when winding down and I fixed that by pouring talcum powder around the windup section. Let it unwind and allow the talcum to go in,,,, and presto.......no more grinding noises.
Carlo
Posted on Oct 01, 2008
  • shrewz92
    shrewz92 Jan 26, 2013
    Carlo, did you open the case, or just pour the talcum around the edges of the crank-form?
It sounds like your drive belt has worn out. Check ebay, there is a guy who sells the belts. it is a thin O ring type drive belt and is simple to fix. Search for "baygen belt".
Posted on Jul 29, 2008
Bobbin winder is engaged and shows up on screen correctly, but sewing mode is still engaged and bobbin winding keeps stopping.
check the drive knob on the end of the machine
it should be loose when winding a bobbin
if it is tight or seized then that will drive the needle
Sep 20, 2015 | Janome Sewing Machines
Toyota corolla professional aerial problem, reception on radio
Some tints have metal in them so it might cause you grief but how is the radio when you wind down the windows ?
A power aerial might fix the problem put in the front fender and then run to the radio via a coaxial cable.
However in my car it was the radio that was the cause of the same bad reception and it worked on one channel only.
I have since replaced the radio but this may not be the cause of your problem and you would want to really know if the radio was the cause before incurring an expense of a new car radio.
May 28, 2017 | Cars & Trucks
When turning the crank, the spring slips, and the crank flies back to original position. Spring will not wind up.
One day while cranking the freeplay PLUS Radio on a job site with no power, something inside snapped, and made a horrid grinding noise. All of my co - workers laughed. From then on I only used the radio with the AC plug in adapter.
After 8 years of keeping the freeplay plugged in to listen to it I finally decided to open it up and take a look.
Low, and behold I found some broken pieces that looked like a belt. HMMM?
After a little more investigating I found the 2 drive wheels that power the generator... with no belt on them. I looked in my junk drawer, and found a small blue rubber band amongst the others that I save from packaging items. It looked suitable to do the task. After stretching it around the generator drive wheels, I cranked it up, and IT WORKED!
I'm still waiting to see how long this fix works, but in a pinch... keep some rubber bands and a phillips head screwdriver around. This may be the same problem your having. I'm now getting the long lost last laugh.
Hope this helps! KMT
KMT
Feb 19, 2011 | Freeplay Energy BayGen AM/FM/SW Radio
Broken winder [stem]
mcdevito75 Here, I may be able to repair your Timex watch but I will need more info and of course the watch here with me in Florida, I am RITE TIME BASIC here in the service directory at Fixya. Is your Timex a quartz / Windup?? did the stem simply pull out of the watch?? Contact me at mcdevito@netzero.com or here at Fixya.com
Feb 09, 2011 | Timex 27191 Wristwatch
What is the purpose of the nodule labled "kinetec" just above the winder? why does tmahe second hand move twice as it sweeps?
mcdevito75 here, Kinetic means motion, energy, with watches I'm not sure, although it could mean your watch is a windup-----------OR!! if you watch is AUTOMATIC it could mean, any motion of the watch will wind it, or it could mean if you watch is automatic and stops, un-winds completely after say 30 hours you can wind it to get an initial start then wear your watch to keep it wound. In your travels visit a small watch repair shop in your area for more info.
Nov 19, 2010 | Watches
Bobbin winder will not wind
The bobbin winder will not activate to turn the bobbin or the thread will not wind onto the bobbin spool?
Sewing machines vary in the method used for bobbin winding.
You can find threading and bobbin winding guides at sewusa.com.
If the winder is broken, you can get it repaired or check into getting a Sidewinder Bobbin Winder as an auxiliary for winding the bobbins, which would be less expensive than the repair.
Mar 13, 2010 | Kenmore Sewing Machines
I have an original freeplay clockwork radio which has died. Help!
Hi , you have probably expired the battery life out of the radio [ they have a recharge battery life ] but all you have to do is replace those recharge batteries with new recharge batteries and your as good as new
Jun 12, 2009 | Freeplay Energy BayGen AM/FM/SW Radio
Spring broken?
Solution #2 is correct. My Baygen Freeplay radio was running fast and mine had a broken belt. I could not find a belt on eBay. After hours of searching the internet, I fond a replacement belt at http://www.kenselectronics.com/lists/belts.htm I have the older large Baygen Freeplay radio without solar power and this is the belt that fit my radio... AV-SBS9.5 Replaces SBX9.5 & 1407-36 & SCX9.5 square 9.5 x .047" belt, Baygen Freeplay. Just search the website above... they also have a second size Baygen belt that might fit the newer Baygen Freeplay radios???
Feb 27, 2008 | Freeplay Energy BayGen AM/FM/SW Radio
Crank problem
the drive mechanism has failed. try this. ensure it is fully unwound. then open it. then look for some part of the drive gears or belt that has broken or has slipped off. caution, you MUST ensure it is fully unwound prior to opening it.
Jun 03, 2007 | Freeplay Energy Plus AM/FM/SW Radio
Dynamo problem
In the original big black Baygen radio there is a blue wire with a solder joint that breaks. This wire shunts part of the load back to the generator and prevents it from running to fast and going over-voltage. I am guessing that a similar problem is affecting your newer smaller radio. On the original radio after you take the two halves of the case apart there is a blue wire that comes from the 3v input jack on the back half of the case and goes to the radio circuit board near the top corner. The solder joint where the wire is soldered breaks easily. With this wire broken the generator will run to fast because there is very little load. The radio will still play if you slow the generator with your hand as it is playing back. If you resolder this wire the radio will work and the generator will run at the proper speed. This takes only a moment or two.
Good luck.
Jan 03, 2007 | Freeplay Energy BayGen AM/FM/SW Radio
Freeplay Energy BayGen AM/FM/SW Radio Logo
1,736 people viewed this question
Top Freeplay Energy Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Freeplay Energy Audio Player and Recorder Expert? Answer questions, earn points and help others
