Question about HP Pavilion dv6000z Notebook
Unit will not turn on after power down for 3 days.
    Genius:
  • 1,288 Answers
Assuming you are running on mains, remove battery and try without battery installed.
Try removing mains and battery power and press down on the power button for 30 secs then reconnect mains power and try again.
If this does not work and you know the Power adaptor to be working, I'd suggest its a main fuse in the laptop gone
Posted on Dec 29, 2010
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Continuous ignition failure code comes up every day have to shut off powervent switch and on and unit will instantly turn on. problem began intermittently now happens every day. tired of resetting switch...
Hello
You need to unlock disply by holding down the up and down buttons until the lock flashes then goes away.
Once inlocked you can press mode button to resume normal operation.
Here is a link for your HW heater.Note pgs 22 to 24.
http://globalimageserver.com/fetchDocument.aspx?id=a92c7d0e-8a95-48ba-8810-cd714f33d47a
Aug 26, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
My ps3 turns on and I can hear it running, but nothing shows up on my screen. This just happened from 1 day to another. What steps should I take to try to fix it?
try holding down power button while its turning on. you will here the first beep the a second beep. release the power after second beep. the unit will revert resolution setting back to factory.
Mar 24, 2011 | Sony Playstation 3 (PS3) Console
I powered off my dlink DI 704P and internet modem by turning off switch on surge suppressor (which I have do several times) and just powered back up after 3 days and my dlink will not come back up no...
1. if you have a power adapter connected to this router it may have burn out when restoring power several times in the way you shut down.
2. When visiting the manufacturer website and researching your unit I found that the unit is "discontinued" and there is no other support for it.
3. I suggest that a new router be purchase with update technology to get the most from your internet experience.
I hope this helps. Have a great day!
Aug 23, 2010 | D-Link DI-704P Router
Freezer thermostat was set at 0 degrees unit went down to -30 degrees. I increased temp on thermostat 3 degrees 3 times each over a 3 day period. The thermostat is not responding. I have the thermostat set...
I would start there. If the thermostat has an off setting, turn it there and see if it goes off. If not, try turning it to it's warmest setting while the box is cold to see if it turns off. To test to see if the relay/ contactor is stuck/bad, kill power to the unit (Unplug or turn off breaker). Disconnect one wire to the thermostat. Restore power. If unit runs, bad relay/contactor. If unit does not run, I'd replace the thermostat. Make sure the sensing bulb of the thermostat is in the conditioned space of the box or in the return air (intake) side of the evap so it can sense the box temp.
Aug 02, 2010 | Nor-Lake KLF7766C Commercial Freezer
I was playing music off PS3 HDD when we had a power cut for approx 0.5sec. Surge/spike protecter was fitted to power source, but no power back up was fitted. Error msg was on screen saying to turn off PS3...
This is a processor error. There is no way to get to the restore screen when you have the yellow light issue. Try CPR in NYC. They usually have a 1-3 day turnaround time, and are pretty cost effective. You can easily ship them your unit. They are faster and cheaper than Sony!
website is www.cpr-nyc.com
Hope it helps!
Mar 30, 2010 | Sony Playstation 3 (PS3) Console
Samsung fpt5884 plasma TV power issues
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
Remember there are leathl Voltages inside TV's, and generally these days don't contain any "User Servicable parts" like in the "Old" days, instead Board Replacment is all that is generally done.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 24, 2010 | Televison & Video
Unit turns off when hot
Hi, this is a defective power board fan in this device. the power board fan should be replaced in order to prevent the down time due to over heating. i will post a link to the replacement fan below.
CLICK HERE TO PURCHASE YOUR NEW REPLACEMENT FAN
May 20, 2009 | JVC DR-MV1S DVD Recorder/VCR
Setting the clock
hold source button down to turn the units power off
once the unit is off hold down the F (function button) till you hear a beep from the unit once this has beeped press the F(function) button 2 or 3 times the clock should display flashing numbers
once you have this press the buttons to skip the songs to the hr once hrs are set press F (function) button one more time to select minute settings after this has been set..........hold down the source button till the unit powers back on and clock will be set on this unit
hope i was able to help you
have a great day
Mar 04, 2009 | Pioneer DEH-P2000 CD Player
Won't power on
This is a sign that the power board has failed, If you post the model number, we can find out about parts.
Apr 14, 2017 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
HP Pavilion dv6000z Notebook Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
