Question about Watches
How do i get the back off my ladies omax watch
How do u change the battery in a gossip small ladies watch
  • Remove back
  • Locate battery and note how it is installed
  • Identify battery
  • Obtain replacement battery
  • Remove old battery
  • Install new battery
  • Check operation
  • Reinstall back
  • Set functions
  • Return to small lady
Oct 14, 2016 | The Watches
Cannot snap cover back on
Usually you would have to press really hard to get the case back on the watch, especially if it's a large dial. If you still can't get it back on, I suggest taking it to a watch repair person. They might charge a couple dollars or do it for free. If you prefer to do it yourself you can purchase a watch tool presser for around $15, just be carefull when using the tool , make sure you have the right size dial and you are all set. You can try it on a cheap watch first, just so you can practice. I hope this helps! Marcelo
Oct 28, 2013 | DKNY watch - NY8160 Ladies Ladies
I cannot open rhe back of a 3950 lady watch DKNY
most of this kind of watch can be open by a skilled repair man using a knife, you can try it. but the hard part is not opening it but closing in the cover. it is close by pressing in at the sides of the watch. Better to see a repair man for this.
Dec 13, 2010 | DKNY Modern Edge Lady Watch # NY3901
My dkny ladies watch stops when I take it off. After resetting and putting back on, it works again. Why does it do this?
mcdevito75 here, It"s possible the battery could be so ever slightly loose, or the battery could be weak and need changeing. Also possible, the quartz mechanism could be going bad and movement of the watch while wearing it keeps it going, with the watch off your wrist and at rest, it's just to weak to keep moving on it"s own. Best Bet is to look for a small watch repair shop in your area and have them check out your watch.
Aug 22, 2010 | DKNY Modern Edge Lady Watch # NY3901
What do the number on the back of the Geneve Diamond ladies watch mean.
There may be three number on the back of a watch.
1) The case number.
2) the movement number.
3) the serial number for the case +watch assembly.
Apr 29, 2010 | Geneve 14K Diamond Cut Gold Face Watch...
I have lost the back of a gold ladies geneve watch. can I get a replacement back? Gold case, white dial with black clear numbers , gold brick link type bracelet. 9ct.Quartz model.
Best bet here is to go to a dealer that carries that brand and seeing if they can order you a new caseback.
Or, you can look for the same model online or EBAY that is broken or in disrepair, then just scrap it for the caseback. (It is not always possible to find one, but i recommend trying as this is the least expensive way to obtain small parts).
Oct 17, 2009 | Watches
Removing links to shorten watch for a ladies Wallmart watch brand is white stag #Ws50880w
I just removed links from one of the white stag watches today. The answer is in the link below.
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Friction pins are used to hold the links together. I used a jeweler's screwdriver and a small hammer to tap them out in the direction of the arrow. I put them back in the same way.
Dec 28, 2008 | Pulsar Ladies Watch
Open back
Hi cinannh,i have sample video guide of how to open ,tell me whatever the result ,so i can assist...
How to replace a watch battery - Watch
hope this may help;
Regards,
VOTIT
Jul 30, 2008 | Pulsar PPG672 Ladies
Reymond weil ladies watch automatic
hi guys heres my pic ty not very clear644ef545-133c-4e4c-823f-750b9fd2175a.jpg
Jun 11, 2008 | Watches
Watches Logo
48 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
