Question about Microsoft Xbox 360 Console
Do i need a new hard drive if the one i have gives me the e68 error when it it in the xbox when it isn't in it turns on no red light but when i plug it back in i gives me it again. thank you.
    Problem Solver:
  • 10 Answers
Hello! no need to worry! the E68 error code is one of the more simple things to fix. most of the time it's just simply a hardware fluke. Attached you will find detailed instructions on how to successfully restore your hard drive and eliminate the e68 error code. If unfortunately, you must purchase a new hard drive, you can find reasonably priced drives at your local electronics or computer store.
If the steps listed in the link fail, the contact information for Microsoft is included as well. Good Luck!!
How to Fix The E68 Error Code
Posted on Dec 29, 2010
ctf1800
  • 4402 Answers
SOURCE: System error E68
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans.
Posted on Feb 25, 2008
repairtech99
  • 767 Answers
SOURCE: the xbox comes up with one red light and error
Yes that is true its easy to get a D.I.Y kit/book/video
but they leave out certain critical step and or give hazardous
instructions
The Hardware ( x clamps) are faulty and need to be replaced.
this will fix your box permanently from r.r.o.d ,no video, freezing up ,1 red,even the laser stoped cutting circles after I x clamp modded it.
So that's it The Truth
Posted on Jul 01, 2009
sardanadixit
  • 813 Answers
SOURCE: e68 error on xbox 360 HELP PLEASE
A Working Solution.
Remove any disk from the DVD drive.
Remove the hard drive and turn on. When you get to the dashboard turn it off again by holding the X button on the controller and select 'Turn off console'.
Wait 10 seconds and then turn on again by pushing the X button on the controller. When you get to the dashboard turn off again via the X button.
Remove the AV / Video plug from the back of your Xbox.
Replace the hard drive correctly.
Switch on the Xbox via the power button on the console. 4 red lights should flash.
Wait 10 seconds and re-insert the AV / Video cable.
You should now load into the dashboard with your hard drive profiles - wait theres more!
Turn off and on via the X button as before another 2 times with all leads and the hard drive in place.
After you power it off the second time, remove the power lead for 20 minutes and then turn on again any way you feel like it and it should be cured.
Posted on Aug 06, 2009
micromatikal
  • 2777 Answers
SOURCE: XBOX 360 e68 all hard drives
Unfortunately you can not fix that problem on your own, you need to call Microsoft at 1-800-4-My-Xbox
Posted on Aug 31, 2009
localwonder
  • 6784 Answers
SOURCE: Xbox error e68, 1010
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans. This error will normally require you to send the unit in for repair, due to the fact that, this is a basic internal connection breakdown.(cold solder break).The only know remedy to this issue, if you are not considering sending it in, is to locate all the solder breaks on the main board and hard drive connections bay,a nd re-solder all the bad connections you can find. Check the fans for there operational value as well.
Posted on Oct 15, 2009
Gives me an error E 68 what is that? New xbox is only 10 months old.
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem, much like all of the problems in the "e6x" family of error codes on the Xbox 360 platform. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
May 21, 2011 | Video Game Consoles & Games
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
One red ring, erra 68.
What you need to do is try using the console without the hard drive or with a different hard drive, one red ring means a hardware failure, and the error code e68 is in relation to the hard drive. If using the console with a different hard drive, or none at all doesnt work, ensure that the fans are working as they often also cause the e68 error and a single flashing red light.
I hope this helps. Good luck.
Sep 03, 2010 | Microsoft Xbox 360 Console
Error e68
Remove any disk from the DVD drive2_bing.gif.
Apr 20, 2010 | Microsoft Xbox Console
The xbox360elite the red light flashes and e68 comes up on the screen with different language on the tv screen is also showing.
E68 means that you have a bad hard drive. Take out your hard drive and turn the unit on to confirm. Once this is done just buy a new hard drive and your good to go! Or now Microsoft just released where you can use a Flash drive :]
Apr 05, 2010 | Microsoft Xbox 360 Elite Console
1 red ring E68
The single red light on the Xbox shows that there is a hardware failure.
The E68 error is linked to a problem with the Xbox 360 Hard drive. Try removing the hard drive from the Xbox and attempt to use the Xbox again.
If the error does not occur when the hard drive is not connected then you will need to replace the hard drive.
If the error still occurs then the console will need to be repaired.
Nov 17, 2009 | Microsoft Video Game Consoles & Games
E68 error on xbox 360 HELP PLEASE
A Working Solution.
Aug 06, 2009 | Microsoft Xbox 360 Console
System error E68
Feb 25, 2008 | Video Game Consoles & Games
Xboxe 360 console arcade
you got the red lights of doom #1 suggestion make sure your harddrive is plugged in all the way #2 make sure all cables are pluuged in if thats not it go onto the web fin da video of how to get three red light instead of one nd send it into microsoft becuase your warranty cover three lights not 1 or 2
Jan 02, 2008 | Microsoft Xbox 360 Console
E68 error
Sorry to say you got a bad hard  drive. Call MS or take the system back to walmart for a new 1 because I dont think they will give you a new hard drive. Who knows they might, call and ask!
Oct 12, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
281 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
