Question about Nikon Coolpix 5000 Digital Camera
When the CF card is loaded it says no memory.
  • 10,865 Answers
Hello jesser..... Remove the card and look around the edge of the card for the wee lock. Open the lock. Reinsert the card. Turn on the camera and go into the menu. Find the format function. When you format the card it will erase any photos that are currently on the card and set it up to be used in your camera. Joe
Thanks for choosing Fixya!
Posted on Dec 29, 2010
Photos not loading onto pc from memory card when they have previously ?
Hi.
Some notebooks all of a sudden begins not recognize the camera due to drivers problems.i
n order not to worry about this problem any more and TO MAKE IT SIMPLE ,WHY DON'T YOU USE "A Memory CARD READER" THAT COMPATIBLE WITH YOUR MEMORY CARD..
IT IS ABOUT 5.00-7.00 USD..WITH THAT CARD READER-WRITER YOU CAN DO ANYTHING YOU NEED LIKE YOU ARE DOING WITH "USB FLASH MEMORY UNITS"..
THIS IS THE EASIEST WAY TO DOWNLOAD YOUR PHOTOS/VIDEOS to PC ..
As an example of this unit pls visit the URL below....you can buy it any electronic Market too...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
26-IN-1 USB 2.0 MEMORY CARD READER FOR CF/xD/SD/MS/SDHC
http://cgi.ebay.com/26-IN-1-USB-2-0-MEMORY-CARD-READER-CF-xD-SD-MS-SDHC-/290583009260?pt=PCC_Drives_Storage_Internal&hash=item43a818d7ec
Jul 11, 2011 | Fuji FinePix Z10fd Digital Camera
THE CAMERA BRINGING A NOTICE ON A SCREEN ERROR CF.WHAT IS POSSIBLE THE PROBLEM.
Digital Camera: How to Fix Compact Flash Memory Cards ErrorIt is not very typical for compact flash memory cards to give you an error. If you do receive an error, it most likely means that a pin within your CF card slot is bent, or your CF card has become corrupted. Unfortunately, if your CF card has become corrupted, you will need to reformat the memory card, which means that you may lose any pictures that were located on the card.
Fixing Your Flash Memory Card
You will want to remove your CF card and the batteries. Take a look inside the CF card slot to see if there is a bent pin. If you find a bent pin, you can correct this problem using a very small and skinny flat screwdriver. Moving very slowly, use the screwdriver to bend the pin back into place. You do not want to use enough force to make the pin back in one shot.
The pin does not have to be perfectly straight, but get it as close to straight as possible. Insert your CF card back into the slow very slowly. You should see the in align itself with the card. You can turn your digital camera on to verify that the compact flash memory card is now working.
Mar 11, 2011 | Cameras
I took the CF card out of my Rebel XTi EOS camera to look at the pictures on my computer. When I put the CF card back in the camera I am getting the message "There is a problem with the CF card. ...
This is an old posting but I'd like to comment that once the memory card is used in a computer it won't read in the camera again until you format the memory card. Make sure you have all your pictures on the computer before formatting the memory card. A memory card must be formatted in the camera it is going to be used in.
Jan 01, 2011 | Canon EOS Rebel XSi Digital Camera
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
What kind of CF card do I need for the Qt 6000?
For IPL loading you must need CF card. This card is available in market with the name of COMPACT FLASH MEMORY Card.It is available from 2 GB to 16 GB Size. The QT-6000 or QT-6600 has capability to format only upto 2 GB size capacity.If more you have to formate through your PC and then use it for Loading and unloading programme in QT-6000
May 09, 2010 | Casio QT 6000 Point of Sale Terminal
After deleting pictures I never get 40GB of memory space back
I found the same thing. Had to go to "my computer" , load up the photobank icon.
Click on the cards folder and then delete each folder.
THEN ,after clearing off the photobank, go to the desktop and empty the recycle bin. You will get the 40gigs back.
Feb 09, 2010 | SmartDisk PhotoBank PB40 40 GB USB 2.0...
Navionics gold sd card
Make sure that you go into MAP data and select this chart as the map info. You might just be using the internal base map right now.
Mitch
Aug 05, 2008 | Navionics Gold United States East...
Need flash card data
only the counties loaded on the CF card would be lost - the main base map is in the units' main memory. If you have both disks simply copy the wMap program over to your PC to download counties to the CF card. See Whistler's FAQ page for more info on Galileo GPS unit.
Jun 13, 2008 | Whistler GPS100 Galileo GPS Receiver
No CF card
The camera body has a tiny switch marked "CF" in one position and Sony's "memory stick" symbol in the other. Apparently I accidentally reset the switch from "memory stick" to "CF" while slipping the camera body into (or out of) its carrying-case. Once I had set this switch from "CF" back to the "memory stick" position, everything worked fine. Solution:  read the user's manual more carefully next time!!
May 08, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
Memory card error - E50
Error Code "E50" (CF card formatting error) When a camera error occurs, an error code like "Exx" will be displayed, where the x's represent numbers. The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. If the same error occurs when you are using the CF card supplied with the camera, please contact the retailer where you purchased the camera or the nearest Canon service center. If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded. Precautions for handling a CF card: - Do not remove a CF card or disconnect the camera's power source while the camera is recording, loading, or erasing data on a CF card. - CF cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration. - Do not attempt to disassemble or alter a CF card. - Place the CF card in the supplied case for storage. - Moving a CF card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the CF card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature. If condensation forms on the CF card, put it aside until the water droplets have evaporated completely. - Do not use or store CF cards in the locations subject to dust or sand, high humidity, or high temperatures.
Aug 11, 2005 | Canon PowerShot A85 Digital Camera
Nikon Coolpix 5000 Digital Camera Logo
64 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
