Question about ACE CK01 Halogen Heater
How do I get into my DRW halogen heater to replace the element that has expired ?
Im in Adelaidle South Australia and wnant to know where can I purchase Elements for Halogen Heater Model JNSB-120Y2S
research shows that bunnings are agents for halogen heaters so go to the special orders counter and ask who the service agents are for halogen heaters
failing that the web site www.cheapaschips.com list all of the shops in Adelaide that sells halogen heaters so surely one of them will have the address of an authorized service agent
unfortunately only the suburb shops are listed and no phone numbers
Dec 22, 2017 | Heating & Cooling
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Just bought my house and the water heater will not turn on is there a common problem with these that I can fix my self
Did they turn the power off to the heater before you bought the house?
Check there first. I used to shut the power off to ours when going on vacation. Check curcuit breaker if its hydro and if its gas make sure the the gas is turned on and pilot is lit.
Mar 28, 2015 | Water Water Heaters
Heating element does not function dishwaster is just over 1 year old of course 1 year warranty has expired
Contact service center. Fault could be- heater element fault, thermostat, or power not switched to the heater from the programme control board.
May 18, 2010 | Dishwashers
Drum heater lamps
All you really have to do is go to any store that sells halogen lamps and purchase 2,, 150 watt halogen bulbs. That is what the drum heaters are.
I can send you instructions on how to replace them.
rak458@aol.com
I would suggest, if you can find them. Sylvania halogens rated for 130 volts with vibration protection.
If you cant, thats fine, they just seem to not fail.
But any 150 watt halogen will work.
Mar 09, 2010 | Xerox Phaser 8400 Laser Printer
Printer error Contact service Report fault 15,004.45:40227
There are 2 , 150 watt halogen lamps in the drum heater assembly. One or both are burned out.
I can send you instructions on how to replace them. Xerox will want over $250 for an entire heater assembly. You can buy the lamps at Lowes or any place that sells Halogen lamps for around $15 for a set.
May 05, 2009 | Xerox Phaser 8200 Laser Printer
Halogen ring not working
Hi .
It sounds like the temp control is faulty.
Either way you are going to have to remove the hob top to access the controls and elements, Then you can check if the element is getting a feed to it.
Sometimes you can see if the element has gone, .
If you need any further help, let me know.Good luck.
Nov 23, 2008 | Ovens
Ascaso, Innova, Dream Heater not working
If you are confident that your heating element is dead and are filling adventurous enough to replace it- you can get one at:
http://www.1st-line.net/cgi-bin/category.cgi?category=review&item=i365&type=store
I saved myself shipping and repair costs by having it replaced by a friend. He took pictures and marked wires & connectors before removing the broken heater.
Yeah,, this looks to be systematic failure with this machine. Very disappointing- for this kind of money, one would expect the machine to work a bit longer after warranty expires.
Oct 18, 2008 | Ascaso Dream Espresso Machine
ACE CK01 Halogen Heater Logo
Top ACE Heating & Cooling Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
Tim Whalen
Are you an ACE Heating and Cooling Expert? Answer questions, earn points and help others
