Question about HP Compaq Presario SR2150NX PC Desktop
Windows won't load, tried everything. No option for startup repair comes up in Advanced bootup, Any help?
  • 89 Answers
Check Bios, Make sure your Hard drive attached.
Posted on Dec 29, 2010
Windows 8 wont recognize datel game controller
Try this Access Startup Settings When the Choose an option screen appears, click or tap the Troubleshoot tile.
Next, click or tap the Advanced options tile.
Select the Startup Settings tile on the Advanced options screen.
Click the Restart button on the Startup Settings screen to reboot your computer again.
Disable Driver Signature Enforcement On the Startup Settings screen, tap the F7 or 7 key on your keyboard to select the "Disable driver signature enforcement" option.
Windows 8 will immediately boot to its typical lock screen. Sign into Windows 8 as you normally would - everything will look the same, except Windows will no longer demand driver signatures until you next reboot.
You can now install unsigned drivers as you would on previous versions of Windows. Windows will alert you if you try to install a driver that isn't properly signed, but you'll see an "install this driver software anyway" option you can choose.
Reboot When you're done installing the unsigned drivers, reboot your computer. Windows will keep using any unsigned drivers you've already loaded, even as it enforces signature requirements for new drivers.
Nov 15, 2013 | Datel Xbox 360 Turbo Fire 2 Wireless...
Blue screen
Which operating system you are using??
You can follow the given steps to avoid blue screen error..
Start Windows in Safe Mode:
Step1: Turn on your computer and press the F8 key repeatedly from your keyboard. You must press F8 before the Windows logo appears. It will display the Advanced Boot Options screen.
Step2: From Advanced Boot Options screen, choose Safe Mode option then press Enter.
Step3: If Windows loads and works fine in Safe Mode, a bad driver is probably causing the error. Uninstall device drivers and reinstall them. If Windows experiences issues in Safe Mode also, repair your hardware.
Startup repair:
Step1: Shut down your computer and then restart it in Safe Mode (see step1).
Step2: From Advanced Boot Options screen, select "Repair Your Computer" and hit Enter. Choose your preferred keyboard layout and then click "Next."
Step1: Click "Startup Repair", and follow the on-screen instruction .Startup repair can solve this problem.
System Repair:
Step1: Follow step1 and step2 from Startup repair section.
Step3: Now select system restore from the System Recovery Options menu. And follow the on-screen instruction to select a restore point.
**If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Jan 24, 2013 | Acer Aspire Computers & Internet
Dell Inspiron 1440 notebook failed to start windows
You probably have a mbr virus. Try this:
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
Aug 17, 2012 | Dell Inspiron 1440 Notebook
Hi everyone, I'm having the same problem too.. Everytime I start my laptop, It show these two option: Startup repair or Start Windows normally. I "Start Windows normally" and then it comes...
Hi.
It looks like your going to have to perform a full system recovery as you are not getting anywhere with start-up repair or safe mode.
For a full system restoration, press the F11 key during bootup and then select "Recover PC" from the menu.
Regards.
Jan 25, 2011 | HP Mini 1000 Netbook
Everything was fine then computer froze so I manually shut it down. Now I hear and see the computer boot-up with the Windows Insignia & Gateway logo and the mouse pointer but then it's black, except...
Restart the computer and press F8 key after you hear a beep or before it gives you the Windows logo on Startup. It will give you then the Advanced Startup Options.
You could try the option 'Last Known Good Configuration'.
You may also try Safe Mode option and do a System Restore. On Safe Mode, System Restore will automatically loads up at startup. You can then choose the date and time where you had it last working before.
If those can't be done, you may want to run scan file checker and fix system errors for you. Do this from Start> All Programs> Accessories> right click on Command Prompt. Then select Run as Administrator.
On the Command Prompt, enter sfc /scannow
That will automatically repair system files. However, it may ask for Windows Setup CD.
Oct 14, 2009 | Samsung SyncMaster 2253LW Monitor
Windows fails to start and startup repair does not work.
Your startup repair option in Windows Install indicates a hardware conflict. Go to your System Setup in startup mode, by pressing Del, F2 or F10 whichever the hint is on screen during bootup. Once inside system setup, turn off almost everything, disable Speed Stepping in EPower, set monitor off to disable, Standby and Hibernation off as well. Turn off the modem and Network adapter if yo can. Just about everything that affects a device on the laptop. This would also include the Touch Pad if you're using a mouse.
And, in the long run, you may need to do a full Windows Install if the repair option continues to fail. Many of these failures are due to the Virtual Memory file size for Drive C being too low. If you can get into Safe Mode change this setting, right click My Computer, select Properties, go to Advanced, advance and change Virtual Memory on C to a fixed size about 1024Meg for min and max.
Also, should you be low on free space for drive C this could cause the same problem. You would have to choose a Full Install as an Option unfortunately.
In the absence of anything along these lines working, you should be able to choose Restore Acer option (or words to this affect), you would want to tap on F8 while booting, sometimes its F10, but this gives you a 'boot from what source' option, CDROM, Hard Drive or Restore Partition. Choose the Restore Partition and start over from scratch again.
Sorry, but this often happens and you and I have to live with this.
If you need any clarifications on what I've just stated, use the Comment Box Text Entry box below to send me a message. I'll get an email alert and will get back to you as soon as I can.
Regards,
Worldvet
Nov 06, 2008 | Acer Aspire 5500 5570-2609 Laptop
MSI K8TNeo2-F v2.0
This is not too uncommon scorcher63.
From what you stated, when windows does start it only goes so far & than re-starts it's self, like loading in a loop. Than at times it loads the start up options.
For reasons unknown, your windows (startup files) are corrupted. Easyest way to fix this is. Put you windows CD in the cdrom, shut down the system. Start the PC & press the F8 key every 2 seconds. A boot menue will load. Use the up & down arror keys & choose the cdrom drive. You will see (to boot from cd press any key), press the space bar. The cdrom will startup. Windows will start to load. You want to repair windows. This option will re-install windows but will leave most of your personal data alone. Like My Documents your username. Some programs "may" need to be re-installed. After installation is complete remove the windows cd & shut off the PC. Start the Pc, windows should load. Run Windows Update. If you have a antivirus program please do a full system scan. Run windows Defrag program.
scorcher63, if you have more question just post them here.
Feb 21, 2008 | MSI K8T Neo2-F Motherboard
Computer will not boot
Chances are if you load the windows CD into the CD player it wil boot to the CD. You can opt to repair the current version of windows without a format. You will not loose your data.
Jan 02, 2008 | Compaq Presario 5000 PC Desktop
HP Compaq Presario SR2150NX PC Desktop Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
