Question about Quartet gbc (660S) Projector Screen
Need a gooseneck for quartet 460S projector screen
Singer futura quartet connection error
I need more information to answer this question. Is this a error message on your computer screen? Or on the machine? I know Singer Futura machines require a USB cable connection to work; check USB drivers are installed properly on the compatible version of windows as well.
Cheers,
Embroidery Services
San Diego, CA
Jul 08, 2016 | Singer Sewing Machines
Raising handlebars
There is a single central connection to the handlebars This is called the "gooseneck". (Ther handlebars slide through the goosenect and then the gooseneck is tightened to hold the handlebars. The connector to tighten is in the front (so you do not get "injured" if you have a collison). Loosten the connector (it may be allen, or perhaps hex nut.). Raise or adjust the handlebars, then tighten. Make sure it is really tight (do not strip the threads). The handlebar has serrations to lock on to the gooseneck so the handlebar - gooseneck bolt will have to be loosened quite a bit to allow the serrations to "jump" to the next serration.
Sep 20, 2014 | Trek 7100
What is a gooseneck Hitch?
A gooseneck hitch is a
Feb 18, 2013 | Cars & Trucks
I pull down a Quartet projection screen 70" and it will not stay down.
Someone familiar with this will likely find a latch or tension part is bad or bent in some way, not unlike the old style window shades.
Dec 18, 2012 | GrandView Elegant Pull Down Screen...
I have an elmo overhead projector, Model #HP-L11. We need a new lense for the gooseneck area. It was round. Any thoughts
It might be easier to find a differnt overhead at a thrift store or ebay than the work to find that lens. It was a good unit, but overheads are a dime a dozen these days
Apr 21, 2010 | Cameras
My quartet projection screen will not go back up.
Go to the manufacture website,or Ebay.com or Amazon.com have many electronics acessories.
Sep 28, 2009 | Quartet gbc 550S 71" 1:1 Projector Screen
My quartet projection screen will not go back up. I think someone pulled it down too far.
The problem is most likely a damaged spring end cap. As you face the screen from the front, this is the cap that covers the right end of the cylinder that encloses the screen material. The cap is held in place by 3 Phillips head screws. If you remove the spring end cap, you will see a slot in it that is designed to hold the spring assembly stationary as you pull down on the screen. If this slot is damaged, then the internal spring inside the roller will lose tension. The fix is to pull out the screen & roller assembly, roll it back up manually, then replace the spring end cap with a new one. (I believe the part # from Quartet Apollo is K0329). The cap at the other end has a cup receiver designed to accept the pin end that is on the left side of the cylinder that houses the screen material. The tricky part is fitting the pin end back into the pin end end cap. It is easier with 2 people. If you fashion a short hook out of a coat hanger. you can use it to lift the pin end into the pin end cap. There are part #'s and exploded diagrams on the Pegasus part sales website: http://shopping.netsuite.com/s.nl?c=440001. The site is down now for maintenence, but it should be back up soon. HTH
Mar 13, 2009 | Quartet gbc 550S 71" 1:1 Projector Screen
Quartet gbc (660S) Projector Screen Logo
109 people viewed this question
Top Quartet gbc Televison & Video Experts
Electro Med Services...
Are you a Quartet gbc Televison and Video Expert? Answer questions, earn points and help others
